Drives: Scion FR-S Whiteout
Best springs+spacers for stock wheels?
I currently have 215/45/17 Michelin PSS on the stocks. I'm looking to get some springs based on the following requirements, in order of priority:
1. I want to get rid of the wheel gap, but I'm not planning on getting new wheels anytime soon. I don't want too much drop and scrape everywhere. 2. No need for expensive coilover setup. I'm not planning to track the car, maybe just once every 2 or 3 months. 3. The car is my daily driver, so comfort is also a factor. 4. I also want to make the wheels poke out a bit with spacers, but this isn't as important as the above points if it will add some stress to the suspension system. Which springs and spacers would be the best for my requirement? And what supporting mods do I need (camber bolts, etc)? PS: I'm new to suspension tuning.
2013 Scion FR-S
#2 |
Drives: FR-S Whiteout
Any of the 1" drop springs will do. I'd recommend the Swift FR-S spec lowering springs and a set of SPC camber bolts up front. Any CNC'ed hubcentric spacers 5mm or less will not required new studs. Not sure if you will get the "poke" you want but any more than 5mm spacers will require longer studs.
I'm running Swift BRZ spec springs, 2 sets of SPC camber bolts for approx. -2.6* of camber out front. And an ebay set of CNC 5mm hubcentric spacers for my RPF1 +45 with 245 wide tires. Only added spacers for clearance, not "poke".
Intent > Content
cowardice is the mother of cruelty. |
| The Following 2 Users Say Thank You to solidONE For This Useful Post: | cslntuee (10-03-2013), retrosmiths (10-03-2013) |
#3 |
Drives: 2013 Whiteout Scion FR-S 6MT
RCE Yellows.
/thread But seriously, I made a thread about spacers on these springs awhile ago. http://www.ft86club.com/forums/showthread.php?t=31339 Hope that helps. |
| The Following 2 Users Say Thank You to husker741 For This Useful Post: | Racecomp Engineering (10-04-2013), retrosmiths (10-03-2013) |
#4 | |
Time Traveller
http://www.ft86club.com/forums/showt...04#post1147904 Here's my setup on Springs and Spacers (posted a few months back (drop is now 1.25" all the way around). Stock wheels and tires. More pics? PM me. I bought the b2autodesigns BRZ spacer/adapter kit for my FRS. The spacers are hubcentric and B2 is a vendor on the board. They shipped FAST. Got spacers from FL to CA in 2 days. I was very happy with the purchase. http://www.ft86club.com/forums/showt...ghlight=b2auto Then I dropped it on RS-R SuperDowns yesterday, it looks OEM+++ and I'm quite happy. Car is being detailed today, but here is a pic I snapped late last night. Specs: 20mm front 25mm rear -1" front -1.125' rear (as of this morning)
| The Following User Says Thank You to DAEMANO For This Useful Post: | retrosmiths (10-03-2013) |
#5 |
If I choose to add the spacers later after the springs have settled, will I get "camber" from those and then have to realign again? Should I just install both at the same time?
2013 Scion FR-S
#6 |
I really like this setup...
2013 Scion FR-S
| The Following User Says Thank You to retrosmiths For This Useful Post: | Calin (10-06-2013) |
#7 | |
Time Traveller
or Springs and spacers, align right away, then align again in a few months (add camber bolts to the front if you want it to match the rear's natural camber at your new ride height (probably about -1 to -1.5 camber). |
#8 | |
Drives: Subaru BRZ Limited
Do I need to cut the OEM bump stops or I need to buy a new one? Any suggestion which should buy? How about the headlight level? Needed to buy some set for adjustment? Thanks. |
#9 | |
I personally cut the bumpstops when I installed my springs. The headlight level is fine. I did not make any adjustments.
Intent > Content
#10 |
Ok, rephrasing my question, I think I will go with springs for now, then add spacers later on. Are the specified drop rates by the manufacturers accurate? I heard Sportlines says 2.0" drop in the box but someone has them and only dropped 1.4".
2013 Scion FR-S
#11 | |
Drives: FR-S & BRZ
They are perfectly coupled with the V3 spacers that we carry! Most of our customers like the 20+25mm combo for front and rear. |
#12 |
is better than you
Drives: 2013 raven FRS
i run the frs swifts, and the drop is perfect, but i dont like running spacers so idk.
#13 |
Drives: None
Would I need to get an alignment if I were to put on 20mm spacers on the rear of my car? I plan on getting just getting an alignment for my trd springs and adding the spacers afterwards... Would that be ok?
| Eibach Sportline springs with 20mm front and 25mm rear spacers on stock wheels | Calin | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 60 | 12-12-2014 02:25 PM |
| Stock Wheels on Tein Springs: Camber? | Ammonia | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 03-30-2014 06:30 PM |
| Stock Wheels Need Spacers? | theom | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-17-2013 11:49 AM |
| Anyone have pics with eibach lower springs and stock wheels | Mrqb22 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 03-20-2013 04:24 AM |
| Spacers with Stock Wheels | Starscream15 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-05-2012 01:31 PM |
