Old 09-18-2015, 03:07 AM   #673
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Originally Posted by stockysnail View Post
So basically swap engines (no replacement for displacement) or run e85 if I want more power is the basic moral of the story.
Bingo!!! Fully enlightened!!
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
stockysnail (09-18-2015)
Old 09-18-2015, 03:08 AM   #674
stockysnail
Just the tip
stockysnail's Avatar
Just read the Cosworth is the TVS 900 and the Edlebrock is the TVS 1320, making the 1320 just a little bit better/bigger.
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
CSG Mike (09-18-2015), dmyers (09-18-2015)
Old 09-18-2015, 04:18 PM   #675
350matt
Drives: toyota mr2/ Toyota GT86
all the TVS units have the smae pressure ratio so the bigger units make the same boost as the smaller units it just menas they reach this boost limit earlier in the rev range
and if you've got stock rods you can't use this boost anyway for fear of bending them..... so the throttle isn't fully opened to keep the boost at safe level
Still I too would like to see some back to back comparisons between all these new kits
350matt is offline   Reply With Quote
The Following User Says Thank You to 350matt For This Useful Post:
Old 09-19-2015, 06:15 PM   #676
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
they have the same pressure ratios and theoretically can make the same boost, saying that however, the bigger blower doesn't need as much boost pressure to make the same power due to it pushing a much larger volume of air per revolution. but the smaller units are more responsive and will generate better power torque under 2.5k rpms, the bigger blower doesn't get into its efficiency range until a little further in the rpm range. i think its been documented here on the site that the 1320 loses torque to the 900 but only in the very low rpm ranges. if I'm not mistaken the 1320 is a little more thermally efficient 73% vs 70%. but i haven't seen any tables for the TVS900 recently. so i could be wrong.
http://www.eatoncorp.com.au/Oceania/...ing/PCT_378413
The TVs 900 could feasibly be maxed out on the stock block, the TVS1320 or Sprintex 335 Definitely need a built motor or possibly just e85.
FreshFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to FreshFRS For This Useful Post:
CSG Mike (09-20-2015), stockysnail (09-20-2015)
Old 09-21-2015, 02:49 AM   #677
ajc209
Drives: GT86 Cosworth
From what I have heard the tvs900 is capable of >350hp which would surly bend and/or blow a rod out the side of the block on stock internals.
ajc209 is offline   Reply With Quote
Old 09-21-2015, 03:54 AM   #678
sw20kosh
Drives: 2013 Black FR-S
Rods start failing at 450-500 whp..
Old 09-21-2015, 04:05 AM   #679
ajc209
Perhaps for Dyno Queens that is true.
The lead engineer at Cosworth said they did alot of engine testing (including a full strip down of the engine) and were able determine with high accuracy that the rods will not be reliable with much more than 250WHP (with a roots blower), hence the stage 2 power. They would have fitted a smaller pulley if they could have got away with it! After all power sells....
The Following User Says Thank You to ajc209 For This Useful Post:
killboy (09-21-2015)
Old 09-21-2015, 04:13 AM   #680
CSG Mike
CSG Mike's Avatar
Torque bends rods, not horsepower. You keep mentioning that "Cosworth said this" and "Cosworth said that", but never actually cite your sources. Statements such as the bold above, tell me you either hear what you want, or make things up that are completely asinine.
If that were the case, ptuning wouldn't use a GT30, and Edelbrock wouldnt use a TVS 1320.
Toyota86.ir (02-11-2016)
Old 09-21-2015, 04:32 AM   #681
ajc209
I had a tour of the Cosworth headquarters and spoke with lead lead engineer, Matt when the SC was in development.
http://www.gt86ownersclub.co.uk/foru...333.html#94644
I even saw an FA20 on the engine dyno cell. It was fun.
Old 09-21-2015, 11:38 AM   #682
sato
sato's Avatar
Drives: Dodge Patitas
Access denied
Sent from my A1P using Tapatalk
sato is offline   Reply With Quote
Old 09-21-2015, 01:22 PM   #683
Kodename47
Kodename47's Avatar
Drives: UK GT86
I doubt either of those have done the analysis that Cosworth have done. BTW, I was also there on the same tour for the FA20 package launch and spent time talking to Matt, he even came out for a passenger in my car.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 3 Users Say Thank You to Kodename47 For This Useful Post:
ajc209 (09-21-2015), killboy (09-21-2015), Toyota86.ir (02-11-2016)
Old 09-21-2015, 03:21 PM   #684
350matt
it all depends on your definition of 'reliable'
after all most of use would be pretty pleased to get 20K + miles on a boosted setup and would then say that my boosted engine is reliable
but how was this milage achieved?
for 90% of owners the duty cycle is low as the car is a DD and used for tootling to the shops and sitting in traffic and only occasionally will all that 250, 300 350 RWHP be let rip .......
when Cosworth says its not reliable past 250RWHP then I thin kthey mean its not OEM levels of reliable ie 150K miles, doing 150hour full load tests on the dyno etc etc
lets be honest
we don't know how reliable these setups are going to be
and as an aside if you've got 350Rwhp you probably spend less time at full throttle than a 250HP setup as you're traction limited anyway......
ajc209 (09-21-2015)
Old 09-21-2015, 09:17 PM   #685
CSG Mike
CSG Mike's Avatar
lets be honest
Per my datalog from this weekend, I was in a 350whp BRZ, and was WOT for 78% of my lapping time, and I was lifting for a lot of sections due to a fueling issue that could not be addressed at the track.
I would think that means I'm not too traction limited, and I was driving on 200 TW street tires.
As for torque bending rods, either you're over the failure point, or under the failure point. It doesn't "bend over time". Your rings will wear, your bearings will wear, but your rods do not "bend" from extended use.
hmong337 (09-23-2015)
Old 09-21-2015, 09:22 PM   #686
sw20kosh
My friends track hard at 330+ whp nonstop in 86cup. I was 330 whp for roughly 15 track days before I took the kit off. No failure or signs of failure for any of us.
Id say cosworth is wrong in their assessment.
The Following User Says Thank You to sw20kosh For This Useful Post:
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
