Old 09-20-2015, 07:57 PM   #1639
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I will replace mine because the pipe is not fitting correctly in the stock intake, I notice it was almost out the other day and kinda fix it. Also I kinda destroyed the Perrin filter trying to get it in place -__-
I want the AVO intake but I'm not sure if it will fit with the Robispec sandwich plate.
Originally Posted by DesertFrs View Post
I'm using the DEI Titanium Blanket T25/T28 kit. Fits perfect with the shield.
https://www.designengineering.com//c...rbo-shield-kit
thanks!
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 09-20-2015, 07:59 PM   #1640
Astroboy
Astroboy's Avatar
Drives: None
The perrin intake is made of some foam type material, why not just replace it with a more durable k&n intake?
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 09-20-2015, 08:05 PM   #1641
Draco_PR23
Fiebru
Draco_PR23's Avatar
I could but then I will still have problems with the pipe and stock intake not getting align as it should be.
I will wait until i decide what to do, I don't mind getting the bumper off since I removed it a couple times now so Im kinda used to it.
Current Cars:
Old 09-20-2015, 10:38 PM   #1642
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
I don't think it will. One your going to need a reducer and/or pipe to attach the inlet silicon to the intake. Second the bolt that attaches the the back of the intake will need some modifications due to the post turbo pipe going to the intercooler is attached to that section. Till this day I still have the stock intake with just upgraded filter. It's not until I hit 419whp and 352wtq where it became an issue. AVO intake kit is already on order.
Is your car still stock motor?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 09-20-2015, 11:22 PM   #1643
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
I'm in the process of having the motor built. Car ran perfectly fine and never gave me any issues. Decided I wanted more power so I decided to save money in the long run and prevent it from going boom and built it. Custom motor build and stage 4 kit will be in for the next dyno tune. Looking in pushing the car to its limit. I think 375whp is the safe line when it comes to a good tune. Anything passed that on a factory motor is just a ticking time bomb.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following User Says Thank You to DesertFrs For This Useful Post:
ChrisD (09-21-2015)
Old 09-20-2015, 11:24 PM   #1644
DesertFrs
DesertFrs's Avatar
thanks!
It might fit, does it look similar to the sandwich plate used in the AVO oil cooler kit?
Old 09-20-2015, 11:41 PM   #1645
evo4g63
evo4g63's Avatar
Agreed about the power level. I was well above that on my turbo setup and that didn't go very well.
-2016 Subaru WRX
Old 09-20-2015, 11:55 PM   #1646
Draco_PR23
Fiebru
Draco_PR23's Avatar
I think it might fit but that box is huge.
The lines in my kit are vertical, so I will have to move them closer to the oil cap.
Looks like this: http://www.ft86club.com/forums/showp...59&postcount=4
Current Cars:
Old 09-21-2015, 12:51 PM   #1647
ChrisD
ChrisD's Avatar
Drives: GT86
What happened with your car once you went above that sort of power? I'm currently on the stage 3 AVO kit and waiting for my forged pistons, con rods, and stronger valve springs to be installed so that I can run more boost. But I'm interested to hear what gave up on your motor in case that's something else that I might need to strenghten
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
Old 09-21-2015, 12:55 PM   #1648
ChrisD
ChrisD's Avatar
Drives: GT86
I'm in a similar position - AVO turbo and waiting for motor to be built so I can run more boost, but I'm not running quite as much power as you at the moment (probably only about 300 whp). Did you have any issues with the gearbox at all at over 400 whp? I see a lot of people saying the tranny is going to destroy itself at that kind of power, but not that many actual real world experiences from people who are running over 400 whp
Old 09-21-2015, 01:57 PM   #1649
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
I have around 400. Replaced tranny once already with about 7000miles turboed. Car inop right now, but its brake related.
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Astroboy (09-21-2015)
Old 09-21-2015, 10:49 PM   #1650
AVOturboworld
I've got 6 normal tickets and two premium tickets available to AVO Turbokit customers for 86fest in California. I'm giving away the two premium tickets to people that will put their cars in our booth (two cars total) and the rest for free to owners of the kit!
I need to know asap so I can get it set up.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Draco_PR23 (09-21-2015), gdrider77 (09-25-2015)
Old 09-24-2015, 06:40 PM   #1651
evo4g63
evo4g63's Avatar
Wrist pin let go on the dyno. Somewhere around 440whp mid pull
-2016 Subaru WRX
Old 09-24-2015, 06:48 PM   #1652
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
How did the transmission grenade? I remember reading somewhere that it's 4th gear that lets go on a hard shift, but who knows
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
