Old 09-19-2015, 07:12 PM   #1
Hentai
Hentai's Avatar
Drives: 2015 Halo GT86
Hub Centric Rings Fitment?
So I bought 73.1 / 56.1 centric rings for my aftermarket wheels (xxr 527's - new)
Problem is, only 1 of the rings fitted snug and tight, all of the others were pretty loose, like i can lift them up without any problems. I check that all of them were the same size.
Just wondering, if I put on wheels with a loose hub centric, is that dangerous?
I mean tightening the lugnuts to the point where it shouldn't fall out should be ok... but i rather be safe to know first than do anything stupid.
Please let me know, thank you
Hentai is offline   Reply With Quote
Old 09-19-2015, 07:39 PM   #2
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
I put 3mm hubs on mine. they were all loose with about 4000 miles on them. no issues
mizzta21 is offline   Reply With Quote
Old 09-19-2015, 07:42 PM   #3
Hentai
Hentai's Avatar
thanks so much, figured it would be okay. just wanted to make sure
Old 09-19-2015, 10:09 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
How lose are we talking about? Is it lose enough you can fit a penny between them? Or lose enough you can put a couple of sheets of paper?
Depending on which kind of hub centric you got they will come with a lip that prevents the hub centric from coming through the wheel. So really the only way out is from the back side of the wheel. So when bolted to the car, the brake rotor prevents it from coming out.
Either way even a lose fitting hub centric is better than nothing. Just remember don't over tighten your lugs
Old 09-20-2015, 01:12 PM   #5
Hentai
Hentai's Avatar
It's loose to where I can only fit a few slits of paper in there, Not a penny for sure.
It fits perfectly, but just not snugged or tight.
Won't be falling through the front of the wheel, but when I do put the wheel up, it does fall from the back if theres enough motion to it.
And yes! I will not, using steel lugs to be extra safe
Old 09-20-2015, 01:42 PM   #6
Porcupint
Drives: 13 GBS BRZ
Should be just fine.
Porcupint is offline   Reply With Quote
WTB: 65mm to 56.1mm Hub Centric Rings alexvc Want-To-Buy Requests 1 01-24-2015 05:57 PM
WTB Hub centric rings 65mm-56.1 Brinks Want-To-Buy Requests 2 08-27-2014 10:11 PM
Hub Centric Rings on TSW Nurburgring 18x8? Readytoxplod Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-30-2013 02:18 PM
SSR Type C RS hub centric rings Justkiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-14-2013 08:34 PM
FS: Hub centric rings 63 > 56.1 mm JDMSushi Australia Classifieds 3 02-09-2013 08:52 PM
