Old 09-19-2015, 02:28 AM   #1
Astroboy
Astroboy's Avatar
Drives: None
Yet another oil leak....
So not to long ago I encountered oil on my under tray and, well, I'll let the pictures do the talking... Its right behind the valve cover. Any recommendations on how to fix it? I was thinking of taking the bolt out and putting a washer there... Will that help?
Astroboy is offline   Reply With Quote
Old 09-19-2015, 02:31 AM   #2
Astroboy
Astroboy's Avatar
Drives: None
Old 09-19-2015, 02:32 AM   #3
Astroboy
Astroboy's Avatar
Drives: None
Old 09-19-2015, 09:34 AM   #4
sam69
Drives: GT 86
Maybe they didn't use enough silicone
sam69 is offline   Reply With Quote
Old 09-19-2015, 04:47 PM   #5
hmmmm.........I'm not sure what I'm looking at .....??
What is the bolt holding on .. ??
How much is it leaking .. ??
Have you tried torqueing the bold down .. ??
Old 09-19-2015, 05:12 PM   #6
Astroboy
Astroboy's Avatar
Drives: None
It's behind the passenger side valve cover.
It leaks a little, but still.
No I havnt torqued it down.
Sent from my LG-D850 using Tapatalk
Old 09-19-2015, 05:46 PM   #7
It's not the old cam plate leak is it .. ??
[ame="https://www.youtube.com/watch?v=Mn1OVvswySI"]BRZ GT86 FRS oil leak from cam plate. - YouTube[/ame]
First, I'd clean up the oil from the area, then tighten down that bolt, then see if it still leaks.
Old 09-19-2015, 06:53 PM   #8
Astroboy
Astroboy's Avatar
Drives: None
Nope... I wish that was the case
Old 09-19-2015, 09:26 PM   #9
Well, try tightening it down.
Can you ID your bolt in this picture (it may be on the other side) ... ??
Astroboy (09-19-2015)
Old 09-19-2015, 10:34 PM   #10
Astroboy
Astroboy's Avatar
Drives: None
I can when I get home, thanks for the idea!
Old 09-20-2015, 06:59 PM   #11
Astroboy
Astroboy's Avatar
Drives: None
It's circled in red on the bottom right
Old 09-20-2015, 11:15 PM   #12
Well, @Astroboy, your picture shows the bolt head alright.
I don't know enough about that engine to know what the bolt is helping to hold in place ....... it could be holding the thing that carries one of the camshafts ..... or, it might be a head bolt ..... or a bolt holding something else .......
I would wager that the oil is not coming from around that bolt (in other words, the bolt is not a sealing type (like a drain plug).
The oil may be coming from somewhere else and dripping off the bolt .... ??
However, I'd tighten up the bolt (just for the heck of it), clean up the oil from around the area and see it the oil leak returns.
What we need here is for someone to chime in that has had this engine apart ..... and knows what he/she is talking about.....
Astroboy (09-20-2015)
Old 09-23-2015, 10:28 PM   #13
Astroboy
Astroboy's Avatar
Drives: None
Any other recommendations
Old 09-24-2015, 12:17 AM   #14
Well, @Astroboy, I'm not going to give you any more suggestions until you have told me you have cleaned up the oil and tightened up that bolt ..... and if the oil leak returned .......
And THEN, ...... I'll guess again ......
(jest ah messen wich ya ...... )
Astroboy (09-24-2015)
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 10:40 AM
oil leak ! frsqc Issues | Warranty | Recalls / TSB 5 07-01-2015 08:08 PM
Help - oil leak tlim Engine, Exhaust, Transmission 4 04-10-2015 09:40 AM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 02:31 AM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 11:31 PM
