Old 09-16-2015, 05:41 PM   #2717
Racecomp Engineering
Originally Posted by DerHauptDigga View Post
I am looking for a good coilover setup around 2k or under.
I daily my FRS, and have a 100 mile round trip commute for work everyday.
Am I a damn fool for even thinking about buying coilovers?
Or is there a well balanced comfort/performance based coilover someone could recommend to me?
Thanks guys, really appreciate it.
What are your goals? Any track or auto-x time? What kind and what size tires do you run?
- Andy
Racecomp Engineering is online now   Reply With Quote
Old 09-16-2015, 06:12 PM   #2718
CSG Mike
CSG Mike's Avatar
I generally like the way that the car handles with my only suspension mods being the RCE Yellows and also switching to 17x9 +45 wheels on 245/40 tires.
What I don't like is the fact that I had to run a 3mm spacer in front to fit these without hitting the oem spring perch. I'm hoping that with a coilover I can actually get a performance alignment and get some beneficial negative camber in front. Additionally, even though I want to only keep my drop around 20mm, I will be also picking up the SPC LCAs to adjust rear camber.
Regarding handling & damper performance, I don't like how "unsettled" the car feels over rough road conditions at high speeds or through mid corner bumps. If I only drove my car on the track I'd keep the Yellows with the oem dampers as they're great on perfectly smooth surfaces.
There's a few canyon roads that I drive on that I will bottom out/scrape the front of the car every time because the dampers can't rebound quickly enough to the changing road condition. So that's primarily what I'm looking to address.
And yes, I will take performance over comfort any day.
Based on your feedback, you'll want coilovers with a camber plate, or separate camber plates with coilovers that don't include them.
If you want the current "bang for the buck", the Flex Z is my current go-to. It's $870 MSRP, and includes camber plates, AND rides well, and performs above its price point, even disregarding that it includes camber plates. Pair this with the rear LCA, and you'll have a pretty solid entry level setup.
If you're tracking the car, you'll want to consider the SPL RLCA.
Old 09-16-2015, 06:25 PM   #2719
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I am also surprised by CSG's curt reply. However you guys are not asking anything that hasn't been asked before or discussed for hundreds of pages, I wouldn't take the posts today as final answers, go get a second opinion through your own research and evaluate your priorities to come up with a more accurate solution.
@yamsta I'm no expert but you're experiencing a lot more roll and I think CSG is correct in attributing it to more grip, however I would investigate some aftermarket sway bars as a first step before dropping $1k-$6k on coilovers. They won't be a wholesale replacement but since you're driving your car casually for fun it may get you what you're looking for. Another cost effective solution maybe the spring kits available although they do have their drawbacks, I know you say you don't want to lower the car but it may be the best compromise for what you want.
Precision will only come from stiffening everything up, removing the slop at the cost of NVH (bushings and stiff springs/coilovers) which I doubt you want to do. I'd have the alignment checked on the car, zero toe in the front (depending on what you had before) may give the car a little nudge in the responsiveness, some toe-out up front will make the front end very responsive but may be tiring for a DD and a minor increase in tire wear. Zero toe rear also helps the car rotate more readily but I found it darty on the freeway (others disagree) and have put a little toe-in to stabilize it.
Lots of variables are in play here
ineedyourdiddly
Old 09-16-2015, 06:26 PM   #2720
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Thanks. I'll look into the Flex Zs and also the difference between the SPC and SPL LCAs!
Originally Posted by humfrz
I'm old and lazy
Old 09-16-2015, 07:58 PM   #2721
Calum
That Guy
Drives: 2013 asphalt FRS MT
Depending on how much camber adjustment you need, you can get a half degree plus or minus from a set of 12mm camber bolts installed in the place of the rear inner lower control arm bolts.
Old 09-16-2015, 08:38 PM   #2722
OkieSnuffBox
Drives: '23 BRZ Limited
I'm very happy with my Ground Control setup (and have been with previous setups on other platforms as well).
I think $2200 gets you the whole package including rear mounts and camber plates. I bought mine used. 375/425 rates (still on stock sways) so it's a bit easy to rotate.
At some point I'll probably step up to ASTs with DDP option or RCE Tarmac 2s.
Old 09-17-2015, 03:30 AM   #2723
DeaconRoc
Drives: GT86
Thanks, I will start researching the Fortune Auto options.
I'm in the UK so I'm going to assume that your canyon roads are probably like our B roads. I can whole heartedly recommend the Tein Flex A's with a set of uprated adjustable anti roll bars and geometry set up. - in the UK at least the Teins are about a third of the price of ohlins.
DeaconRoc is offline   Reply With Quote
Old 09-17-2015, 06:52 AM   #2724
churchx
churchx's Avatar
Drives: 2014 GT86
From me it looks like most are targeting tarmac daily driving or tarmac track racing suspension setups. I wonder what might be CSG/RCE views on advisable suspension tuning and/or aftermarket parts selection for gravel roads at reasonable budget (that is no-no for completely custom suspension like for eg. Nameless rally car )?
Am i right in my guess that for those preferred no clearance drop or even extra shocks travel and maybe softer springs? What coilovers might fit the bill for example? Any comments on these (@ forum. Low price makes me cautious on quality though), or Cusco something?
Old 09-17-2015, 03:50 PM   #2725
DerHauptDigga
DerHauptDigga's Avatar
Drives: 2016 FRS
- Andy
I may spend some time AutoXing, but not very much, so that isn't insanely crucial. I am looking at running 18x9.5 +38 or +40 on 265/35/18 for the Wheel/Tire setup.
I've heard good things about the KW V3s, but not sure if that setup would really be worth it, since I am not going to spend a lot of time AutoXing or Tracking the car (at least not yet).
Right now, I am more concerned with cost, reliability, and comfort.
DerHauptDigga is offline   Reply With Quote
Old 09-17-2015, 03:57 PM   #2726
You missed the most important question...what kind of tire?
How much lower do you want to go or is that not really important?
- Andrew
Old 09-18-2015, 08:17 AM   #2727
DerHauptDigga
Drives: 2016 FRS
- Andrew
Sorry about that. I will probably run an "extreme summer tire" I've been looking at Dunlop DZII Star Specs, Hankook RS3s, Yokohama Advan's, etc. So a similar tire to that.
Right now it's sitting on TRD springs, which is hardly an inch drop if that, I'd like to go down at least another inch.
Side note, if I bought 18x9.5 +40 wheels and wrapped them in 265/35/18 tires, would I rub? I know I would rub on stock Suspension, but since I have springs, would it still rub?
Thanks for all your help though, really appreciate it.
Old 09-21-2015, 01:05 AM   #2728
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Before I post, I searched this thread for "preload" and I couldn't find an explicit answer to this question. If this has been answered, please point me to it! Anyway, here goes:
What is the proper way to set up a suspension that has separate "preload" and "ride height" adjustments? A ubiquitous example of this type of coilover would be the Tein Flex.
With these coils, "preload" is typically set by moving the spring perch up or down, and "ride height" and/or shock length is set by threading the shock body further into or out of the lower mount "cup."
I've seen two methods proposed (though there may be more):
First method - use the spring perch to set ride height
1. With the suspension off the car, remove the spring.
2. Put the spring-less assembly on the car, and mount the wheel tire.
3. Jack up the control arms / wheel + tire and adjust shock length until the tire does no longer contacts the top of the wheel well at full compression.
4. Remove the shock assembly from the car, reinstall the spring, and set final ride height via spring perch aka "preloading the spring."
Second method - use shock length to set ride height
1. With the suspension out of the car, first set preload. If preload is set by the manufacturer, don't touch it. Otherwise, adjust lower perch until the spring is "snug," then tighten another 1/4 turn (varies).
2. Install the coilover assembly into the car then adjust ride height by turning the entire shock assembly into or out of the lower cup, careful not to move the spring perch / change preload amount.
I can see pros and cons of both methods, but they undeniably produce different results. Which way is the correct way?
sdemo is offline   Reply With Quote
Old 09-23-2015, 04:27 PM   #2729
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
@Racecomp Engineering
@CSG Mike
OEM '13 dampers vs. Koni's - Is the softest setting equal or stiffer on the Koni's?
drewbot is offline   Reply With Quote
Old 09-24-2015, 10:45 AM   #2730
@CSG Mike
It should be pretty close to stock, maybe a tiny bit firmer low piston speed.
- Andrew
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
