Old 09-04-2015, 11:15 PM   #645
s2d4
s2d4's Avatar
Any word on Edelbrock coming out with a FMIC for this for people with increased boost levels?
You need to spend some time looking at components of water to air intercooler setups.
Old 09-05-2015, 02:35 AM   #646
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Originally Posted by 350matt View Post
It'll be interesting to see how much boost this thing runs to get its target power as if you're too short on runner length you need more boost to get the power up as th engine tune speed is out of sync with the maximum engine speed
The CARB tune includes the 3.25” supercharger pulley and will start at 6 psi @ 3500rpm and taper up to 11 psi by 7000 rpm.
Above told to me when I was at the Edelbrock Factory.
Lunatic is offline   Reply With Quote
Old 09-05-2015, 04:28 AM   #647
j123ic
Drives: Evo 9
Originally Posted by Jaden View Post
Longer runners are typically so that you get more lower end torque, not so you get more top end power...
Jaden
Just want to emphasize "typically" is indeed the case for runner length. However, in forced induction applications, longer runners can also contribute to an increase in plenum volume. Which has a significant effect on peak power. There is a specific length and equivalent diameter for peak efficiency.
Think of each runner as a reservoir of air. Similar to an air compressor tank used to power pneumatic tools. Bigger tank means you get more capacity for consistent pressure. You'll have that higher pressure for a longer duration than a smaller tank, which means more boost all the way to redline. This is where turbo applications shine, because they have all that charge piping to account for. The downside is, the bigger the reservoir, the longer it takes to fill. Hence, turbo lag.
Longer runners also helps in certain NA applications as well. Bottom line is, intake manifold design cannot be generalized by runner length alone. There are plenty of subtle details an phenomena that are impossible to model with even today's most sophisticated CFD programs. Sometimes it just takes brute force trial and error to get the best results. We're talking about a company that was founded on intake manifold design nearly 80 years ago! Edelbrock really knows their shit when it comes to intake manifolds and cannot even be compared to these newer companies, some which have never even designed an aluminum casting, let alone an intake manifold.
j123ic is offline   Reply With Quote
Old 09-05-2015, 05:43 AM   #648
350matt
Drives: toyota mr2/ Toyota GT86
Jaden
aah yes but there's still a correct length for 7000rpm on this engine which is the about where the stock manifold leg length is
go much shorter than this and you then need to rev to 8500 + to reach peak power
below that speed you're not operating at peak volumetric efficency and so need more boost than you would otherwise to reach your goal
350matt is offline   Reply With Quote
Old 09-11-2015, 01:34 PM   #649
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Wow, been awfully quiet in here lately... @FuzzyFunk did they figure out what was up with your bad fuel economy? Was is an auto specific problem?
Old 09-12-2015, 06:44 PM   #650
FuzzyFunk
Drives: FRS Monogram
It's the power enrichment threshold I was told. Should be addressed when I return it to them later this month for the emissions test. Other than that everything has been running perfectly fine love the power and torque down under.
FuzzyFunk is offline   Reply With Quote
Old 09-14-2015, 02:31 PM   #651
sato
sato's Avatar
Drives: Dodge Patitas
Video or bust
Sent from my A1P using Tapatalk
sato is offline   Reply With Quote
Old 09-16-2015, 07:48 PM   #652
djdnz
1337
Drives: 2013 BRZ WRB S/C
This thread is dead... theres gotta be some news.
djdnz is offline   Reply With Quote
Old 09-16-2015, 08:18 PM   #653
dmyers
dmyers's Avatar
Drives: Subaru BRZ 2013 Dark Gray
Ya seems to have fizzed out. We had posts every other day until the "release" and then nothing... No video or photos from the "tester" that has it. No shipping dates... pretty much nothing?
dmyers is offline   Reply With Quote
Old 09-16-2015, 08:32 PM   #654
ravisraval
Drives: 2013 FRS
Any other owners? Would love to hear more experiences with this s/c.
ravisraval is offline   Reply With Quote
Old 09-16-2015, 09:30 PM   #655
SPCorBUST
SPCorBUST's Avatar
The owner's thread might get a better response. (http://www.ft86club.com/forums/showthread.php?t=93718)
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 09-16-2015, 09:42 PM   #656
CSG Mike
CSG Mike's Avatar
Initial demand was larger than expected; we're just waiting on the final release from Edelbrock so all the preorders can ship!
Old 09-16-2015, 10:40 PM   #657
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
It's the supercharger which broke the FT86 internets lol
kuczynskika is offline   Reply With Quote
Old 09-17-2015, 01:42 AM   #658
BigFatFlip
BigFatFlip's Avatar
Not an owner but did get a chance to ride in one. I've also driven a JRSC equipped car, the two are very different, while the JR is impressive, the power is more of a progressive build up vs the "knock your head back" low end torque you get from the E-force.
During the factory tour, they mentioned they were aiming for a late Sept release, but after the fuel economy issue, I'm guessing they are trying to make final tweaks to the tuning before release. Its much more critical for such a large company like Edelbrock to get it right the first time around instead of having to do a bunch of updates.
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
