Old 08-30-2015, 10:56 AM   #99
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Originally Posted by APEX Race Parts View Post
Printed out RR Racing's templates on Monday, confirmed they fit our 17x9s.
Just to be clear, the stage II RR kit (front and rear) will clear the BRZ-fitment ARC-8? About to jump on the Apex group buy today or tomorrow and want to be sure as the RR kit is on my short list of brake upgrade options.
Thanks!
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline
Old 08-30-2015, 10:58 AM   #100
Alan
Alan's Avatar
@Rafi@RR-racing
I have been using CarboTech XP10 all around on stock brakes this season and have been very happy with the performance and ability to drive to and from the track on them. Do you know what CarboTech template the stage II front and rear kit uses so I can compare prices? Stage 1 as well, just to keep my options open.
Thanks,
Alan
Alan is offline
Old 08-31-2015, 04:08 PM   #101
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
Thumbs up
Thanks!
Allan, I found the RR Racing templates clear the barrel and the spokes. You should have no problems according to them on stages 1-through-4, front or rear.
(6spd Silverstone M5 huh? Nice setup! We have a 19" E60 M5 fitment finally as well)
APEX Race Parts is offline
Old 09-02-2015, 03:58 AM   #102
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
I'm wondering if rears make a significant difference on occasional weekend HPDE purposes. I sometimes participate in drift practice days for fun so I'd like to keep the e-brake functional.
Rookie84 is offline
Old 09-05-2015, 08:01 PM   #103
ModinJapan
ModinJapan's Avatar
Drives: 2013 SCION FRS
Bump Bump Bump!
ModinJapan is offline
Old 09-14-2015, 05:07 AM   #104
Panman
Panman's Avatar
Drives: 86 GTS
Took the RR Racing Stage I kit to the track at Top Gear today at Lakeside International today – Went faster in every session, and fastest in every session. Very happy with the result.
Great session to get familiar with the new brakes + new headers and adjust my technique not my quickest times at Lakeside so far, but certainly my quckest consistent times - and consistent is good it means I'm not generally overdriving. If I can sort my lines through the Carousel and get Eastern loop consistent I'll be happier.
Brakes were great - once I got my modulation right. In the first session I was engaging ABS too much which was smashing the pads and generating too much heat. Once I worked out my pedal pressures it was much more consistent, balance was absolutely spot on, the fact that times dropped all day and there was no fade at all (once I was braking properly) was very positive.
40 (4x10 Lap sessions) Laps on Australia’s fastest racetrack - speed at the braking marker for turn is 190Km/h and brake bias felt perfect.
Panman is offline
The Following 2 Users Say Thank You to Panman For This Useful Post:
MaximeT (09-14-2015), Rookie84 (09-14-2015)
Old 09-14-2015, 09:54 AM   #105
Rookie84
Thanks for the review! So you only have Stg. 1 fronts and no rears, correct? What brake pads were you running(front and rear)? If these work well with stock rears and maintains good brake bias, I'm just gonna go with Stg.2 fronts as I want to be able to participate in drift events time to time.
Rookie84 is offline
Old 09-14-2015, 05:38 PM   #106
Panman
Panman's Avatar
Drives: 86 GTS
Correct, Stg. 1 fronts, no rears. I went with the recommendation from Rafi and Simon of BP20s up front, and Hawk HP+ at the rear, and bias is fine for my needs - I also do a reasonable amount of drift so this was the ideal compromise for me. If I was doing longer races, less other stuff like motorkhana and drift I'd probably go to the rear kit but for me and my needs this is the perfect setup.
I've also got a set of PMU pads on order (front and rear) for daily to extend the life of pads and rotors.
Panman is offline
The Following User Says Thank You to Panman For This Useful Post:
Rookie84 (09-15-2015)
Old 09-14-2015, 09:10 PM   #107
HSC
Drives: Whiteout FR-S
Hi Panman,
Quick question - your rotors look like DBA's but I believe the kit comes with slotted Centrics. Slightly confused cause I see various iterations of calipers (coating & RR logo) and rotors when images are posted of this kit. Thanks!
HSC is offline
Old 09-14-2015, 10:44 PM   #108
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Good options!
gdrider77 is offline
Old 09-15-2015, 09:46 AM   #109
Rookie84
Thanks a lot! It looks like I will go with the same setup in the future, then
Rookie84 is offline
Old 09-29-2015, 12:32 PM   #110
Blizzard
Drives: '13 FR-S Whiteout
Track Tested, Track Approved
Hey guys. Just wanted to give you my impression of the RR Racing BBK Stage IV front and Stage I rear. I started tracking my car a lot more this year. As I became faster and as I modified my car more I needed to upgrade my cars stopping abilities. I tracked first completely stock. The stock fluid did not fare too well, nor the stock pads. I put in Torque RT700 fluid and Winmax W3 pads. This helped, but the W3 pads would overheat. I should mention my local track is Miller Motorsports Park and is notoriously hard on brakes. My next set of pads were Winmax W6's. These pads were good. However, I was going through pads and fluid so fast due to the heat. I knew I needed something else. I looked at the other kits available and there were a few good options out there, but the RR Racing kit appealed most to me. The combination of quality, function, and price made it the right choice. Installation was very straightforward. I only had one issue because I did not tighten the elbow fitting on the back of the caliper enough. I am using the BP20 pad compound from Wilwood front and rear. I just finished a 3 day event at the track and I am impressed even more with the kit. The pads do not have the initial bite of the W6's, but the setup was so consistent and easy to modulate. I set personal best times and finally eliminated the worry of what my brakes would do in each corner. My wheel weights didn't even melt off like before haha. Also, the balance of the front and rear kit is excellent. Where I like to trail brake into some of the corners never upset the car too much. BTW I am on WedSport TC105N 17x9 +35 and plenty of clearance. I also run Maxxis RC1 r comps and a Jackson Racing Supercharger so my car is harder on brakes than a stock FR-S. Here are some pictures. I highly recommend these brakes.
Blizzard is offline
The Following 7 Users Say Thank You to Blizzard For This Useful Post:
Ammunition (10-18-2015), DAEMANO (09-29-2015), fika84 (09-29-2015), MaximeT (09-29-2015), OkieSnuffBox (09-29-2015), phastafrican (09-29-2015), The Racers Line (09-29-2015)
Old 09-30-2015, 05:34 AM   #111
Panman
Panman's Avatar
Drives: 86 GTS
Originally Posted by HSC View Post
Hi Panman,
Hi @HSC - The Guys at RR shipped the kit without rotors to me in Australia (To save weight, money and postage). I sourced a set of DBA rotors locally.
The guys were very flexible in helping me get the kit here at the best price - great support.
Panman is offline
The Following 4 Users Say Thank You to Panman For This Useful Post:
DAEMANO (09-30-2015), fika84 (09-30-2015), HSC (09-30-2015), tgat86 (06-08-2016)
Old 09-30-2015, 09:18 PM   #112
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Would it be okay to run the stage II up front with BP20's, and keep my rear brake setup of: Centric blanks with Carbotech XP8's?
Need to mention that I'm supercharged too.
@Rafi@RR-racing
.ck
|| My Build Thread ||
ck-GT86 is offline
The Following 2 Users Say Thank You to ck-GT86 For This Useful Post:
ravisraval (10-01-2015), Rookie84 (10-01-2015)
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
