Old 09-11-2015, 02:02 PM   #1
aquaman
aquaman's Avatar
FR-S shut off while driving and will not start
hopefully someone can help me or atleast put me in the right dirrection. when driving today (notmally, not spirited) the car shut off. i was coasting and still had power steering. when i pulled over and turned the key off and then tried to start the car, nothing happened. I connected my laptop to the car to try and read the diagnostic codes, my software couldn't detect my ECU... i'm thinking a short somewhere... and idea where to start or anything else i should look at...also any way to easilly test my ECU
aquaman is offline   Reply With Quote
Old 09-11-2015, 02:21 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Could your altornator have died? It doesn't get any power so it's something with your electrical.. I would test the connection of your battery and see if it's charged. Or even try jump starting the car. That would be the first thing i test.
Instagram: trevor.parque
Old 09-11-2015, 02:24 PM   #3
aquaman
aquaman's Avatar
i wouldn't think the alternator would cause the car to shut the motor off while driving...
The Following User Says Thank You to aquaman For This Useful Post:
Muaddib (09-12-2015)
Old 09-11-2015, 02:28 PM   #4
MisterSheep
Killed Scion
If your alternator is going bad it will not charge your battery. If you have no battery and it runs out of juice it'll shut off your car (including the motor.)
Same exact thing happened to my Mother's mustang. Died while she was driving.
I was also giving you a sugestion on where to start. Not "the problem IS the alternator"
The Following 5 Users Say Thank You to MisterSheep For This Useful Post:
aquaman (09-11-2015), DieselDog (09-12-2015), humfrz (09-12-2015), radroach (10-13-2015), raven1231 (10-18-2015)
Old 09-12-2015, 01:58 AM   #5
@aquaman ....... this may help.
http://www.aa1car.com/library/battery_runs_down.htm
Old 09-12-2015, 04:28 AM   #6
steve99
Drives: FT86
measure the battery volts
does anththing else electrical work ie interior lights ect
if battery volts good check fuses especially ecu and efi fuses, their is also fuse for obd port power.
i seem to remember another guy with similar problem car just stopped blew ecu\efi fuse think cause was shorted coil pack or short in fuel injector wiring due pinched during car assembley was under bonnet somewhere, finding which fuse is blown will trach down which circuit to trace.
if your car is modded check any changed wiring eg wiring to o2 sensors or flex fuel kits ect
Old 09-12-2015, 11:05 AM   #7
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Maybe this will help.
http://www.ft86club.com/forums/showthread.php?t=30517
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 09-23-2015, 07:04 PM   #8
aquaman
aquaman's Avatar
I replaced the fuse and I haven't had the issue since. i looked for a short but couldn't find one.
Old 09-23-2015, 10:18 PM   #9
Good you are up and running.
Which fuse did you replace ..... ??
Old 10-05-2015, 03:29 PM   #10
aquaman
aquaman's Avatar
it was the EFI [CTRL] it's a 15A circuit
humfrz (10-05-2015)
Old 10-13-2015, 09:08 PM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Have you ever figured out why that fuse even blew ? What mods are on the car?
Old 10-18-2015, 03:04 PM   #12
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
Did you ever find out what caused it to blow? Mine was I had appearnlty pinched the plastic insulation for the wires the go to the injectors. It will short on the black metal cover and blow the fuse. If you just replaced the fuse. It will short out again eventually unless you fix the insulation.
RD1428 is offline   Reply With Quote
The Following User Says Thank You to RD1428 For This Useful Post:
TheBRZsKnees (05-23-2017)
Old 10-18-2015, 03:06 PM   #13
RD1428
RD1428's Avatar
I had removed my intake manifold to clamp evap hoses.. And that's how I did it ..
Old 10-18-2015, 03:16 PM   #14
stugray
Drives: 2013 GBS BRZ Limited
This is one of those cases where the OP did not tell the whole story.
His car broke down on the side of the road, and he just happened to have a laptop that was capable of connecting to the ECU??
Sounds like he was using a Tactrix, and something blew the fuse magically?
Just a Wild Ass Guess, but perhaps plugging in a tactrix had something to do with blowing the fuse?
Engine shut off by itself! Astroboy Issues | Warranty | Recalls / TSB 34 08-13-2018 01:57 PM
A/C completely shut off... Scikotic Issues | Warranty | Recalls / TSB 6 08-01-2015 05:28 PM
Rattling from front of car when you shut the engine off djdrugga24 Issues | Warranty | Recalls / TSB 8 04-01-2014 01:03 AM
Car Shut Down ScionFR-S Issues | Warranty | Recalls / TSB 10 11-22-2013 01:07 PM
Automatic shut-off whitefrs Scion FR-S / Toyota 86 GT86 General Forum 23 10-01-2012 05:47 PM
