Old 08-01-2015, 08:23 AM   #309
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Confirmed OEM 17's fit with a 20mm spacer. That means its a safe bet that anything 17x7+28 and wider or higher offset should fit. KEEP IN MIND THAT ALL WHEELS ARE DIFFERENT.
I have sets of rebuilt brembos already set up for the twins available over in the classifieds section if anyone needs a set.
xkalelx is offline   Reply With Quote
Old 08-05-2015, 07:59 AM   #310
P86RAVES
Drives: 08 WRB WRX STi / NA Miata
Can you post a picture up when you get a chance?
It's based on a RWD Corolla, what do you expect?
P86RAVES is offline   Reply With Quote
Old 08-05-2015, 10:23 AM   #311
xkalelx
xkalelx's Avatar
@P86RAVES
Old 09-10-2015, 06:14 PM   #312
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Anyone know of some cheap winter wheels + Tire setup that will fit over the brembo conversion? I am assuming I would need at least a 48mm offset to clear, but so far I have not found anything. Thoughts?
kuczynskika is offline   Reply With Quote
Old 09-10-2015, 08:44 PM   #313
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Search for a winter wheel setup for a 2004 Subaru STI.
Old 09-10-2015, 11:18 PM   #314
Vten
Drives: Too heavy
I'm thinking to get those xxr 550 17x9.25 et36 with 235/45/17 blizzaks lm60s ... I have the sparco asseto gara 17x7.5 et48 w/ 225/45/17 blizzaks lm60, but I have to use 20mm spacers to clear my brembo .
Vten is offline   Reply With Quote
Old 05-01-2016, 03:09 AM   #315
greg.bowring
Drives:
Originally Posted by Hachiroku14 View Post
hey mate can i ask what the wheel specs & offset are on there - im looking to do the exact same set up thanks
greg.bowring is offline   Reply With Quote
Old 05-01-2016, 06:04 PM   #316
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
just wanted to check in, i'm still alive-brembos haven't killed me yet LOL
Jive Turkey is offline   Reply With Quote
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
