Old 09-04-2015, 10:40 PM   #29
seant2h
Drives: 2013 BRZ 6MT LTD
Originally Posted by why? View Post
I wasn't expecting to see anything. I was pointing out the reality that there are no people on the planet that I've ever talked to or read that would take 1 dyno run and even think about reporting what it said as fact.
I was also pointing out this paid review cannot be used as evidence of anything at all, because there was no real test, and there was no real comparison.
It is disingenuous at best to try and use it as proof of anything at all. It does nothing to further our knowledge base about anything.
It is real data that says there is no statistical difference whatsoever between the three pulleys and nothing more. Not data you can draw any conclusions from.
And if a person can get consistent repeatable runs on a dyno then the data can be considered valid. No one will ever be able to perfectly repeat everything, which is why 2 or 3 hp is usually considered to be no gain at all.
The fact remains that no matter how much data and testing anyone wants to use to prove either side of this topic, it will not change the laws of physics which I dare anyone to try and disprove. If you don't understand the laws of physics then go get a book or ask a question.
seant2h is offline   Reply With Quote
The Following User Says Thank You to seant2h For This Useful Post:
stugray (09-05-2015)
Old 09-05-2015, 05:07 PM   #30
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
What's your point? I'm not even going to go into the arrogance of the human race here, but if you are saying there is no test possible that could ever give any data, you might as well just dump all science ever.
why? is offline   Reply With Quote
Old 09-05-2015, 05:23 PM   #31
replace it with a ZERO pound magic pulley.
link, please
GotBRZ1691 (10-26-2015)
Old 09-05-2015, 05:27 PM   #32
seant2h
My point is that there is a bigger picture here (physics) that some people are failing to account for because everyone just wants to see a dyno to prove the point. If you study the physics of what we are talking about here then it becomes clear that no dyno run will matter because Newton's laws of physics will be relevant until proven otherwise.
Old 09-05-2015, 05:41 PM   #33
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
If you study the physics of what we are talking about here then it becomes clear that no dyno run will matter [1] because Newton's laws of physics will be relevant until proven otherwise.[2]
1/ As I mentioned above it depends on the type of dyno being used. I am not suggesting changing the crank pulley would make a difference in reading. I am suggesting if one removed significant rotational mass in the drive train (flywheel,drive shaft and wheels) one would see an increase in power if one was using an inertia dyno. Is this increase real? According to the dyno it is. It is just the way inertia dynos works.
2/ I don't think people are arguing the physics; I think people are arguing the significance of changing the mass of just the crank pulley. @stugray's calculation showed that if you reduced drive train inertia you get a benefit. Because physics. It also showed just how insignificant that benefit was.
Old 09-05-2015, 05:44 PM   #34
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Lightweight crank pulley vs OEM vs Fluidampr by MotoIQ
Why are u guys using crank shaft as example... All that does is decrease the drivetrain lost.. So u get more whp but ur engine still makes the same power...O.O
Old 09-05-2015, 07:06 PM   #35
stugray
Drives: 2013 GBS BRZ Limited
My calculation did not say anything about measuring HP on a dyno.
It was specifically aimed at the argument that a lightweight driveline component might give you an advantage in a 0-100 MPH drag race.
In THAT case I showed that two identical cars, side by side, but one has a magic driveshaft that has the same weight as the other car, but "Magically" has a rotational inertia of ZERO, would make it to 100 MPH 32 milliseconds faster than the car with a driveshaft with "stock rotational inertia".
You STILL wont see a difference on a dyno.
I'll ask another (related) question:
When we look at dyno graphs do we EVER look at how many seconds it took the car to reach max RPM?
Seconds is nowhere to be found on a dyno sheet. (that I have noticed).
The Following User Says Thank You to stugray For This Useful Post:
why? (09-06-2015)
Old 09-05-2015, 07:30 PM   #36
He AGREES with you.
Captain Snooze (09-05-2015), GotBRZ1691 (10-26-2015), stugray (09-05-2015)
Old 09-05-2015, 07:37 PM   #37
OkieSnuffBox
Drives: '23 BRZ Limited
Yes, pointed out before. You aren't providing new knowledge.
ESL?
Old 09-05-2015, 07:54 PM   #38
stugray
He AGREES with you.
I was agreeing with his agreement, adding a caveat, and asking a totally new question, related, but a distant cousin...twice removed.
The Following 2 Users Say Thank You to stugray For This Useful Post:
Captain Snooze (09-05-2015), Ultramaroon (09-05-2015)
Old 09-05-2015, 07:57 PM   #39
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
ESL?
And you are? 😂 How about just hold your D & go play in private. Thank you. Fact is no one in this thread is gonna provide new knowledge but shoot loads off each other in an endless debut. 👍
Old 09-05-2015, 08:02 PM   #40
OkieSnuffBox
I just might, it feels good.
Old 09-05-2015, 08:09 PM   #41
Captain Snooze
Drives: Red Herring
Oh look!! It's the internet!!
The Following 3 Users Say Thank You to Captain Snooze For This Useful Post:
chaoskaze (09-05-2015), OkieSnuffBox (09-05-2015), stugray (09-05-2015)
Old 10-25-2015, 02:13 PM   #42
ka-t_240
So, would you think a product like the fluidampr is something that will help with longivity on these cars as it appear the common failure is starting to be the bearings?
ka-t_240 is offline   Reply With Quote
Perrin Lightweight Crank Pulley (RED) JarredH Canada Classifieds 1 08-12-2015 07:05 AM
Lightweight crank pulley Vlady Engine, Exhaust, Transmission 112 01-09-2014 09:28 PM
Lightweight Crank Pulley Vlady Want-To-Buy Requests 3 01-02-2014 11:31 AM
Perrin Lightweight Crank Pulley protpibe Engine, Exhaust, Bolt-Ons 4 12-04-2013 07:46 PM
FS: AgencyPower Lightweight Crank Pulley Firestorm_86 Engine, Exhaust, Bolt-Ons 0 11-22-2013 04:13 PM
