Old 09-04-2015, 11:00 AM   #631
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
The thermostat governs the lowest coolant temp your engine (should) will see. No need for it, IMO.
Petrolheads are too much concerned with low engine temp. You don't want to ruin your street driving with low engine temp.
I work for a manufacturer that build shit cars, but we can still build an engine with a 106C regulation for the street. It makes for better efficiency.
Under hard driving conditions we instantly switch back to 90C regulation.
Running a street car under 80C is totally stupid.
As the manufacturer knows people are stupid, we will always set the display temp on the dashboard to 90C. If the temp is between 70 and 109C, we tell the driver it's 90C.
It's fun when you read a review of the car, and the journalist says the thermo management is great because the gauge stay always in the middle
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 09-04-2015, 12:02 PM   #632
Porcupint
Drives: 13 GBS BRZ
Originally Posted by Freeman View Post
This is now edlebrock vs cosworth. Come one Harrop get in the game already
It's out. https://www.harrop.com.au/tvs86
Porcupint is offline   Reply With Quote
Old 09-04-2015, 12:06 PM   #633
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by Porcupint View Post
I know. I'm hoping to see it in the U.S. soon.
Freeman is offline   Reply With Quote
Old 09-04-2015, 12:08 PM   #634
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Any word on Edelbrock coming out with a FMIC for this for people with increased boost levels?
Instagram: trevor.parque
Old 09-04-2015, 12:13 PM   #635
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'm not trying to sound like a d!ck, but how would they go about doing that, and how would it benefit increased boost levels?
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-04-2015, 12:16 PM   #636
MisterSheep
Killed Scion
I've seen FMIC setups before on a twin screw. Normal twin screw superchargers can only handle so much boost before they need an outside intercooler to cool the extra air.
Old 09-04-2015, 12:36 PM   #637
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I get that, but the current design of the manifold doesn't really allow for that. You'd have to tap into the intake tract post blower but pre cylinder heads, which would require new manifold castings.
As it is, the existing cooler lives in the manifold between the blower and intake runners.
Parting out HERE
Old 09-04-2015, 01:27 PM   #638
sickmint79
Drives: bmw
hmm why did i think you might work in france even before reading your info on the side??
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 09-04-2015, 01:43 PM   #639
350matt
Drives: toyota mr2/ Toyota GT86
sounds like your cars have a new fangled electric thermostat if you can switch coolant temps with duty cycle, the FRS has an old fashioned mechanical stat - you have to pick a temp
and I think the cosworth stat lowers things by 10°C so the coolant sits at 82° instead of 92°C
probably allows a bit more spark, and to hell with the small loss in brake specific fuel consumption
350matt is offline   Reply With Quote
Old 09-04-2015, 01:47 PM   #640
MaximeT
MaximeT's Avatar
Congratulations
You made my day.
Old 09-04-2015, 01:49 PM   #641
MaximeT
MaximeT's Avatar
As long as you're over 80C that's reasonable.
Old 09-04-2015, 01:57 PM   #642
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Are you talking about non-intercooled twin screw set-ups? Technically, the Edelbrock does have a FMIC, granted its a water-to-air vs an air-to-air FMIC, which is what I think you are saying.
Exactly, if you look at Edelbrock's intake design, its very obvious that they meant to make the air path as short and straight as possible, which is probably why they went with a W2A intercooler.
Old 09-04-2015, 04:03 PM   #643
350matt
It'll be interesting to see how much boost this thing runs to get its target power as if you're too short on runner length you need more boost to get the power up as th engine tune speed is out of sync with the maximum engine speed
if you look at the stock manifold the runners on that are pretty long
Old 09-04-2015, 04:51 PM   #644
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
ummm...
Longer runners are typically so that you get more lower end torque, not so you get more top end power...
Jaden
Jaden is offline   Reply With Quote
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
