Old 09-03-2015, 11:55 PM   #71
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by sam69 View Post
Pic he sent me of an oil gallery half blocked with silicone and it doesn't take much imagination to think what would happen when this stuff starts floating around oil galleries/motor
Will see if he has pics of the oil pick up cause as said before he reckons the motor was just full of it
Did this motor go out aswell?
Astroboy is offline   Reply With Quote
Old 09-04-2015, 07:56 PM   #72
sam69
Drives: GT 86
No apparently it had only done a bit over 4000 Km when pulled apart for a rebuild so it hadn't but he said it would have sooner or later.
sam69 is offline   Reply With Quote
Old 09-06-2015, 03:23 PM   #73
pantdino
Drives: Firestorm 2013 FR-S
[QUOTE=Luckrider;2376630]Time to revive the thread.
What failed (if you know): The motor hasn't been torn into yet. It sounds like a spun bearing.
Mileage: 38,000
How it failed Driving down the highway doing about 50mph. It started to make a funny clunking noise. It was driven maybe a mile. The motor stalled on the exit ramp. Cranking twice, the motor died on startup and killed the battery. I picked the car back up from Subaru 3 weeks after the incident and when fired up, it made a loud rattling noise that smoothed out to a clatter when the idle came down. It was then shut right off. When on the highway, there was no oil light, no extra heat showing on the coolant guage on the dash
Circumstances when it went out- slow and gradual or just boom See above
Results of warranty claim? Denied. The car was blacklisted at a previous dealer for having a header which forced the dealership the car was brought to to call Subaru. The dealership looking at the car confirmed that if it wasn't for this note, the car would have been repaired already. SoA specified that modifications are not the cause of denial on the warranty. They state the one drop of oil on the outside of the drain pain (on the drain plug) was proof of failure of service. There was no oil spray anywhere under the car.
And of course... modifications to the car, your use of the car Daily Driver/Mountain Road carver/Toy. Modifications include an Openflash Header and Tune.
Last oil change 5,000 miles.The oil level was checked less than 3 days prior to failure when I added washer fluid. Oil showed on the dipstick after the failure. The service department says they added 4 quarts to fill.
List of services performed, IE, recent reflash etc. Nothing Recent. There was probably 3,000 since the last reflash running 93oct.
QUOTE]
"They state the one drop of oil on the outside of the drain pain (on the drain plug) was proof of failure of service. "
So their contention is that a new crush washer was not used and 4 qts of oil dripped out past the old washer? That's ridiculous.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 09-06-2015, 03:29 PM   #74
pantdino
How many motor failure warranty claims in NON-forced induction cars have been denied under these circumstances?:
1) oil changes done by dealer at <= 7500 miles
2) oil changes done by independent at <=7500 miles
3) oil changes done by owner at <=7500 miles w proof of oil and filter purchase receipts
Seems like the dealers / manufacturers tend to blame the owner under the flimsiest of pretenses and let the owner sue them to get justice.
The Following User Says Thank You to pantdino For This Useful Post:
civicdrivr (09-06-2015)
Old 09-06-2015, 03:34 PM   #75
pantdino
Purely anecdotal since I am not going through all the threads to compile data but many (most?) of the stories about these failures start with something long the lines of "I had just been on the highway a couple of minutes when...".
Now, I certainly don't know if everybody takes ramps like I do but I do know that I use them as very short tracks. I can easily be at or above the speed limit by the time I hit the highway on some of the bigger ones. There can be some pretty heavy lateral force involved and although I am not familiar with the oil pump orientation I would have to think that if it was floating or rubbing on the housing this could jamb it temporarily and reduce the volume considerably.
HMMMMM you may be onto something there.
Anyone know where the oil pickup is in the sump? Under lateral load the oil will tend to move to the outside surface of the sump, which could lead to oil starvation if the level is low and the pickup is on the inside.
There were M3s on which it was advised to run the car with an extra quart of oil in the sump if you were doing a track day.
Old 09-06-2015, 04:18 PM   #76
pantdino
Originally Posted by RobertPaulson View Post
when was the last time you checked your oil? i check weekly.
Page 283 of the 2013 BRZ Owners Manual says:
Listed below are the general maintenance items that should be performed
at the intervals specified in the “Warranty and Maintenance
Booklet”. It is recommended that any problem you notice should be
brought to the attention of your SUBARU dealer or qualified service
shop for advice.
Battery Check the connections.
(P. 300)
Brake fluid At the correct level? (P. 298)
Engine coolant At the correct level? (P. 296)
Engine oil At the correct level? (P. 293)
Exhaust system No fumes or strange sounds?
Radiator/condenser/hoses Not blocked with foreign matter?
(P. 298)
Washer fluid At the correct level? (P. 304)
The Warranty and Maintenance booklet then shows oil maintenance being Replace at 7,500 mi / 7.5 mo. (No entries for Inspect)
So there is nothing in the owners manual about having to check your oil weekly or any other frequency.
A new engine should not burn or otherwise lose oil.
Old 09-06-2015, 04:42 PM   #77
Astroboy
Astroboy's Avatar
Drives: None
[quote=pantdino;2382094]
Mileage: 38,000
QUOTE]
Wow did it really drip out 4 full quarts!?
Sent from my LG-D850 using Tapatalk
Old 09-06-2015, 09:49 PM   #78
Astroboy
Astroboy's Avatar
Drives: None
Why are most of these failures are in the 30k millage area. I'm starting to worry for I am at 31k and boosted
Old 09-07-2015, 11:19 PM   #79
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
It certainly did not drop 4 quarts of oil. There was not a single drop anywhere but the drain plug. I would say the new crush ring is accurate, but I did the change myself and know a crush ring was on there.
This pretty much seems to be it. I did all of my oil changes and it is frustrating that they won't even touch the car beyond now agreeing to tear the whole block down just to what I will guess is eventually deny the warranty and give it to me in parts.
There was a mention earlier about cars losing it under light power after getting on the highway and someone suspected that tight onramps were causing oiling issues. I was driving a couple of days after that theory was posted and realized it started making noise right after getting on the highway with a 270° onramp.
shop for advice.
(P. 300)
(P. 298)
On top of that, it says they recommend taking it to the dealer. They legally cannot require you to unless they pay for the parts and labor.
[quote=Astroboy;2382136]
No, it didn't drip out 4 quarts. The car registers 4 quarts as empty on the dipstick and the stick had oil when we pulled it (between the motor letting go and it being dragged to the dealer). The tech claims he put 4 quarts in to full, but that makes me think it was overfilled at the dealership if that is the truth. It is possible since a normal oil change would take 6 quarts for me and put the level on the middle of the stick.
Luckrider is offline   Reply With Quote
Old 09-09-2015, 03:43 PM   #80
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
A new engine should not burn or otherwise lose oil.[/B]
Not exactly true. I've owned new german vehicles in the past that seemed to use oil during the initial break in period. I always thought it was odd, but the dealership assured me that it was normal. Something about the rings needing time to seat or bed. Sure enough ... after the 1st couple of months .... it stopped using oil. Not sure about japanese motors though.
Braces is offline   Reply With Quote
Old 11-30-2016, 12:30 PM   #81
brzbrad
[||•]=(86)=[•||]
brzbrad's Avatar
Drives: 2014 BRZ Limited WRB
Spun rod bearing
26k
Highway driving, low RPM. Heard a slight knocking noise when at ~3k rpm, babied it to try get to a shop, motor stalled a short while later.
Not covered under warranty because of mods.
Mods: Full exhaust, intake, lightened pulleys, tune.
DD, some spirited driving, one track day.
Last oil change at 25k, kept up with all necessary maintenance.
Been waiting for the shop to finish the rebuild for almost 3 months now...
<a href=http://www.ft86club.com/forums/showthread.php?t=91507 target=_blank>Build Thread</a>
brzbrad is offline   Reply With Quote
Old 11-30-2016, 10:28 PM   #82
Lantana frs
Drives: 13 frs red
From my experience I would avoid aftermarket pulleys and raising the rev limit. Also, not driving like an asshole will probably help. Race and replace.
Lantana frs is offline   Reply With Quote
Old 11-30-2016, 11:27 PM   #83
brzbrad
[||•]=(86)=[•||]
brzbrad's Avatar
I've had a couple people say that about pulleys to me now (of course after this happened...) and driving like an asshole?
Old 12-01-2016, 12:35 AM   #84
[QUOTE=brzbrad;2806629]I've had a couple people say that about pulleys to me now (of course after this happened...) and driving like an asshole? [QUOTE]
Of course, don't all of us up here in the PNW drive like that ..... ??
bearing, blown, failure, motor, rod
Major engine Failures - one year overview regal Issues | Warranty | Recalls / TSB 51 08-31-2016 08:16 AM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 03:01 PM
Traction control failures ? Any one Jacques Blom AFRICA 20 05-16-2014 04:57 AM
Are 2014 models experiencing DI seal failures as well? cys19 Issues | Warranty | Recalls / TSB 4 04-07-2014 07:44 PM
Top 10 Automotive Failures (according to Edmunds via Yahoo news) wrxgoose Other Vehicles & General Automotive Discussions 1 07-12-2013 12:24 AM
