Old 08-25-2015, 08:28 PM   #2423
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Wow, I completely jinxed myself. I wen't to the gym and on my way home my vacuum line on my intake to crankcase popped off at the crankcase side. I recognized the sound instantly when I taking off from a light and around 2000 rpm's. The barb on the case was super hot and the hose refuses to stay on without a clamp now.
It's that 1 vacuum line I didn't clamp too. talk about a scare.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-26-2015, 12:18 PM   #2424
grant
Drives: too many to list
Originally Posted by Kiske View Post
^ No check valves/restrictor pills on your catch cans are there? There doesn't have to be much crankcase pressure to cause a restriction in the drain, just enough pressure where it doesn't drain as fast.
You will know if your burning oil via the turbo. White shitstorm everywhere behind you. And if you are smoking you will smoke for weeks, and like a sob when the cat is warm. The tinyest ammount takes forever to burn even after cleaning all the pipes.
I followed her into work today, nothing like that at all, just some condensation but it was cooler this morning @ 15C
grant is offline   Reply With Quote
Old 09-03-2015, 01:47 AM   #2425
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
What oil cooler is compatible with the fbm kit besides the fbm one?
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 09-03-2015, 08:55 AM   #2426
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Any of them really. You just need a sandwich plate to feed oil to it.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
The Following User Says Thank You to blackfireball5 For This Useful Post:
FRS Johnny (09-03-2015)
Old 09-03-2015, 09:52 AM   #2427
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It's really just a matter of getting fittings that connect to the oil sandwich plate that will clear the piping.
Old 09-03-2015, 03:36 PM   #2428
FRS Johnny
FRS Johnny's Avatar
If placing the oil cooler infront of the intercooler it would block some air, but is it enough to lessen the ability of the ic? I would assume not. I just wanted some input!
And what gauges are you guys running? afr, oil pressure/temp, boost? 2 gauges 4 outputs
Old 09-04-2015, 09:44 AM   #2429
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It will block and heat up some of the air that would be better used going through the intercooler and radiator. Those are the most popular 4 outputs. I am using an AEM Failsafe and an Innovate MTX-D to accomplish that, although I have to say that I have had two of the Innovate oil pressure senders fail so far.
Old 09-04-2015, 01:15 PM   #2430
FRS Johnny
FRS Johnny's Avatar
Looks like I'll be getting the fbm oil cooler. My friend has the mtx oil temp/pressure gauge already so I might as well use it. Thanks for the info! I might pm you. I might have some more questions!
Old 09-04-2015, 04:58 PM   #2431
blackfireball5
Well guys, I think I'm still having my water issue. It rained all night very hard, and when I went to drive to work in the morning, the car did some sputtering just like when I had water in my intake. So I immediately drove it home to switch cars. I opened the hood, and all along that metal bracket there was puddles of water. I don't understand how I'm the only one having this issue.... Soab. Lol. I'm going to have to try something else...
Wheelwell Profile
Old 09-07-2015, 03:35 AM   #2432
Eighty
Drives: Toyota 86
I'm in! full blown premium kit
Eighty is offline   Reply With Quote
Old 09-07-2015, 08:31 AM   #2433
GsxrMe
GsxrMe's Avatar
Is there a way to get the boost controller to talk to the ECU directly? Say we're using ECUTEK with multi maps and we want to change maps and boost at the same time?
2014 Subaru BRZ
Old 09-08-2015, 09:37 AM   #2434
King Tut
NASA SpecE30 Racer
King Tut's Avatar
There is a way to have the ECU control a boost solenoid yes.
Old 09-09-2015, 08:35 PM   #2435
Xxdragn89xX
Drives: 2015 Subaru BRZ
Boosted question
Alrighty so apparently my map sensor is having issues with the new kit. Map, it's reading that the barometric pressure is too high. And at about 5k it basically shuts down. Its bogging down/hesitating hard core. Sorry didn't see a better place to post this. (running full blown stage one base kit) thank you.
Xxdragn89xX is offline   Reply With Quote
Old 09-10-2015, 09:38 AM   #2436
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Have you datalogged this event happening?
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
