#127 |
Drives: GT86
Mine occasionally dips to around 400, car gets wobbly for a second until the ECU cottons on and boosts rpm to compensate, sometimes in time with the AC compressor, sometimes the radiator fans, sometimes for no real reason at all, I've learned not to panic about it, if it isn't stalling it isn't a big deal to me.
I find it happens less if I let off the clutch in neutral and haven't just come to a complete stop after gunning it, my guess would be the fluctuations are down to the heavy gas usage suddenly swapping to idle and the fuel miz being off a little. Has anyone that has this issue WITHOUT CEL kicking in actually had the car stall on a 2014 or newer car? I doubt it. Last but not least stick to the same fuel, don't be putting in regular then randomly premium because you're making it hard for the ECU to nail down a good setting! |
| The Following 2 Users Say Thank You to Futaba For This Useful Post: | Tcoat (08-31-2015), Ultramaroon (09-02-2015) |
#128 |
Drives: Series 10 #177 M/T
This used to happen to me. I took it to the dealership and they did some TSB on the ecu and told me it was better. Kept happening so I bought an openflash tablet and changed my idle to 1000. It hasn't shuddered since.
#129 | |
#130 | |||
Drives: FT86
If you have access to ecu tables zero out the Port/direct injection ratio tables up to 0.2 engine load for manual and 0.3 if you auto like below. Their are three tables cold/warm/hot do all three. This will make ecu run full Direct injection at idle and its not trying to inject very small amounts of fuel via both injection systems, works well bump the idle to 700 or 750 from the stock 650 |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Tcoat (08-31-2015), Ultramaroon (09-02-2015) |
#131 |
Drives: 2016 FRS
I usually always fill up at the esso by my house I use 91 Oct as I don't think there is any higher in Ontario Canada , at least not that I've seen. I do live on the border with the states I know the pumps there go to 97 I think, haven't tried filling it there yet.
#132 |
Avid searcher of things
Drives: Scion Fr-s 10 series
So it is the forward o2 sensor for now (that's what they think anyway) which is what I told them from the begging that I thought it was the o2 sensor but its all good should be getting a new one in soon and we will see if the issue goes away
#133 | |
#134 | ||||||
Drives: '93 MR2 Turbo
Finally, a solution ...
I would like to thank the experts on this forum who provided well reasoned comments on the the issue ...
Technical Bulletin S-SB-0021-15, issued September 17, 2015, Idle Fluctuation in Park or Neutral. Applicability: 2015-2016 FR-S Introduction: Some 2015-2016 model year FR-S vehicles may exhibit a condition where the engine idle speed fluctuates (typically 500 - 1000 RPM) only when the transmission is in the Park or Neutral shift position. This condition occurs after the vehicle has been driven about 25 miles or more at highway speeds. The Transmission Control Module (TCM) logic has been revised to address this condition. I had the TCM software upgraded yesterday ... about an hour at the dealer total time ... and the idle is now rock solid.
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads |
| The Following 5 Users Say Thank You to arvidj For This Useful Post: | cdo221 (09-24-2015), hasanaltan (09-24-2015), Sigh-on-Rice (09-29-2015), Tcoat (09-24-2015), Ultramaroon (09-24-2015) |
#135 | |
In fairness to those that said that it was "normal" etc that was the information available from the dealers at the point in time that the comments were made. Since there is a new TSB issued those comments will no longer be accurate. We need to get our hands on a copy of the TSB to place in the stickyed thread.
#136 | |
Drives: 2015 FR-S (Halo)
sorry for being a ****! haha it looks like I was having a rough day
#137 | |
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
#139 | |
#140 |
Drives: Whiteout FR-S MT
So, this new TSB only affects 2015-2016 models? What did they change from the 2013-2014 that the old fixes don't work for them?
Seems odd to have a new fix on an old issue for a newer subset of cars, when they haven't changed anything to the engine. |
