Old 09-01-2015, 03:54 PM   #603
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
One question - is this kit track worthy, assuming you have an oil cooler installed?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
The Following 2 Users Say Thank You to ultra For This Useful Post:
ajc209 (09-01-2015), ravisraval (09-01-2015)
Old 09-01-2015, 04:22 PM   #604
Porcupint
Drives: 13 GBS BRZ
Something we're all waiting on CSG to give the thumbs up or down on.
Porcupint is offline   Reply With Quote
The Following 3 Users Say Thank You to Porcupint For This Useful Post:
CSG Mike (09-01-2015), ravisraval (09-01-2015), ultra (09-01-2015)
Old 09-01-2015, 04:23 PM   #605
raven1231
looks awesome!
Old 09-02-2015, 12:05 AM   #606
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
There will actually be quite a few well known companies testing this kit on the track. I would expect early solid results from CSG and the likes in the next 2-3 months.
The Racers Line is offline   Reply With Quote
The Following 3 Users Say Thank You to The Racers Line For This Useful Post:
CSG Mike (09-02-2015), ravisraval (09-02-2015), ultra (09-06-2015)
Old 09-02-2015, 08:58 AM   #607
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
To those of you testing this kit- Can you log pre and post charge cooler temps and throttle position for the rest of us?
GSpeed is offline   Reply With Quote
The Following 3 Users Say Thank You to GSpeed For This Useful Post:
ajc209 (09-02-2015), CSG Mike (09-02-2015), The Racers Line (09-02-2015)
Old 09-02-2015, 09:12 AM   #608
ajc209
Drives: GT86 Cosworth
Yes please.
ajc209 is offline   Reply With Quote
Old 09-02-2015, 10:14 AM   #609
j123ic
Drives: Evo 9
pre intercooler temp wont be as accurate because the temp signal wire from the MAF is relocated to the TMAP sensor to read post charge temps. Unlike other superchargers on the market, it uses a Bosch 2bar combination temp/pressure sensor. Looks like there's an ambient temp sensor in front of the AC condenser that can be used for reference.
Are other supercharger pre-post temps available on threads here? I couldn't find anything.
j123ic is offline   Reply With Quote
Old 09-02-2015, 02:49 PM   #610
CSG Mike
CSG Mike's Avatar
I was going to send you just an AIM log. While it wont be pre/post cooler temps, you'll get AAT vs IAT, which is still a great relative reading, and we can also watch the trend over time.
Old 09-02-2015, 09:46 PM   #611
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Right, it would be interesting to add a sensor or two and measure them directly. Resolution is pretty poor on the OBD channels.
That'd be great!
Old 09-03-2015, 05:53 PM   #612
ajc209
The only one I have seen is for the Cosworth SC Kit. Less than 10C temp rise.
The Following 2 Users Say Thank You to ajc209 For This Useful Post:
j123ic (09-04-2015), sato (09-08-2015)
Old 09-03-2015, 06:05 PM   #613
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Less than 10C rise at 25C. I want to see some temperatures taken at 40C. Around here, 25C is a cool fall morning. Keeping a car cool at those temperatures is nothing to brag about, in my opinion. The delta T at 40C is going to be substantially reduced. That graph also doesn't show engine coolant temps, or any other indicator that the car had been running hard for an extended period of time.
If the Edelbrock can keep a 10° rise at summer temps at the end of a session, we'll be sold. Until then, we'll wait to pass judgement.
The Following 2 Users Say Thank You to GSpeed For This Useful Post:
Decay107 (09-03-2015), stockysnail (09-03-2015)
Old 09-03-2015, 06:15 PM   #614
CSG Mike
CSG Mike's Avatar
We have no idea how long that pull was. For all we know it could have been a 2 second ramp, which doesn't even give the air time to get hot.
Old 09-03-2015, 07:04 PM   #615
ajc209
It wasn't taken on a dyno pull. These guys do it properly
They did tons of track testing. Worse track for them in terms of IATs here in the uk was bruntingthorpe on a 25C day (that's hot here in the UK) where the main straight was 3/4 typically hitting 150MPH (lots of extended WOT). They were seeing 33-35C all day long.
I didn't ask specifically about high ambient temps (was more interesting in seeing evidence the kit doesn't heat soak) but they seemed confident they had tested it in all possible environments.
Old 09-03-2015, 07:10 PM   #616
CSG Mike
CSG Mike's Avatar
All that testing means nothing, without evidence of it working well.
You could still say they did a ton of track testing, even if the results were terrible.
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
