Software Tuning Discuss all software tuning topics. |
09-01-2015, 01:31 PM | #1 |
Drives: FR-S black. Buell XB12s 25th anniv.
93 oct on 91 oft ots tune
My city got its first 93 oct pump in like decades and so i filled up woth it forgetting my tune is 91 from open flash tablet their off the shelf 91 stage 2 for headers. I remembered they have a 93 tune as well so I was planning on running a few tanks of 93 oct in it before i switch the tune to their 93 oct stage 2 tune. Is this okay? Do i need to wait a few tanks before switching it?
Also not sure if this is just the tune hut i also have noticed the AFR tends to run more rich (which i know os safer than lean) i see its almost always below 14.7:1 and especially now that its on the 93 oct which i thought would have the opposite affect.
He who shall be last shall be sideways and smiling
09-01-2015, 01:39 PM | #2 |
Seņor Member
Just drive normally until you burn through your first tank of 93 and you will be fine. Even if you go WOT the car might run a little rich, but you should be fine.
The Following User Says Thank You to STV3 For This Useful Post: | AppleSauce (09-01-2015) |
09-01-2015, 02:37 PM | #3 |
Drives: 2014 Scion FR-S
correct me if I'm wrong, but I believe you can run a higher octane gas with a lower octane tune. You'll only have problems if you run a higher octane tune with a lower octane gas.
The Following User Says Thank You to mike7792 For This Useful Post: | AppleSauce (09-01-2015) |
09-01-2015, 02:40 PM | #4 |
the OFT 91 and 93 are identical except the timing for high RPM so you are fine to run 93 gas with 91 tune.
The Following User Says Thank You to sstfnv For This Useful Post: | AppleSauce (09-01-2015) |
09-01-2015, 03:11 PM | #5 |
Drives: JAWS
If I were you I'd just keep running the 93 octane, it gives you a little insurance when driving hard or on hot days, you'll have less knock and probably better mpg too.
The Following User Says Thank You to JB86'd For This Useful Post: | AppleSauce (09-01-2015) |
09-01-2015, 03:19 PM | #6 |
You might get some knock at WOT if you use the 93 tune right away. Maybe run through a tank of 93 first. The power difference isn't even noticeable -- you need a dyno -- so you're not sacrificing anything if it's just your DD.
The Following User Says Thank You to phrosty For This Useful Post: | AppleSauce (09-01-2015) |
09-01-2015, 05:37 PM | #7 |
Drives: FRS
I run my car on 93 oct, on a 91 tune all the time.
The Following User Says Thank You to Chimera For This Useful Post: | AppleSauce (09-01-2015) |
09-01-2015, 06:08 PM | #8 |
The insides of my exhaust tips are atrociously black now
09-01-2015, 08:31 PM | #9 |
Drives: FT86
The 91 you were using may have been an ethanol blend resulting is cleaner combustion, the 93 you switched to may be non ethanol hence the backer exhaust.
as @Wayno said the tunes are identical except for top end ignition timing over 5000 rpm. oft tunes tend to be on the rich side which is safe if you want a clean exhaust switch to e85 fuel and tune. :-) |
09-02-2015, 12:21 AM | #10 |
actually they were starting to get pretty dark before i put headers on and now they are just awful. next spring im getting SC and a real tune along with it so i will hopefully not have this problem afterwards
Similar Threads | ||||
How can you trust a tune? (tune noob) | Benschneider06 | Software Tuning | 20 | 05-21-2015 11:03 AM |
Drift Office Tune vs Visconti Tune | mechaghost | Engine, Exhaust, Transmission | 109 | 07-03-2014 12:57 AM |
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
difference between vortech tune and perrin tune? | Frs32907 | Forced Induction | 7 | 12-05-2013 02:49 PM |
Dynotronics and their E-Tune/ OTA tune. | Ricepuddin | User/Vendor/Sponsor Reviews, Feedback, Comments | 5 | 12-24-2012 09:53 AM |
