Old 08-31-2015, 11:10 PM   #603
jph11
Drives: Still deciding
looks fine
little tiny bit of knock occasionally just dropped your iam to 0.97 from 1,
looks like a hot day 100 plus intake air temps
nothing to get worried about, maybe try different brand of fuel
or if rearly kean maybe alter the intake air temp ingnition retard tables but no real need its very minor.
see links below on logging ect
Yeah good ole texas heat. I think it was around 98 when I went out to pull this. Gave it about 20 mins of driving before I started logging to try and get past the learning curve.
I dont anticipate touching anything. @Shiv@Openflash is making a trip down here in two weeks to do a few custom tunes for a few guys here in Dallas. Ill leave it to him to iron it all out for me
ps: thank you @steve99 . Been reading through all your posts the last few days tryng to grasp the concept. You have benfited the community greatly with all the info youve assembled. Hats of to you good sir.
jph11 is offline   Reply With Quote
The Following User Says Thank You to jph11 For This Useful Post:
steve99 (09-01-2015)
Old 08-31-2015, 11:51 PM   #604
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
So just got an ecutek cable and started doing some data logging... I dont really know what "knock" is but from the tables it seems like I have a lot of it...
8.0 in some instances of "Knock Correction Learn Value (°CA)"
I know i get a lot of jerking when i go WOT for the first couple seconds...
Edit: I guess I'll throw my table up here if anyone is interested... I've never wandered over to this section of the forums... I guess this is where the cool kids be hanging at.. lol
http://datazap.me/u/olsonpg/phils-berz?log=0&data=6
Thanks in advance for the good info!
olsonpg is offline   Reply With Quote
Old 09-01-2015, 12:23 AM   #605
steve99
Drives: FT86
@olsonpg
Ok looking at your log for knock look at these parameters
http://datazap.me/u/olsonpg/phils-be...ata=6-15-35-39
see how you got a series of knock events that dropped your IAM from 1 to 0.75, this is worse knock that the previous guy, not super bad but probably needs some work to sort it out its not ideal.
you getting knock correction events between -2 and -3 degrees quite regularly. This is causing the IAM to drop to 0.75 from one.
assume your using the fuel appropiate to the tune ?
http://datazap.me/u/olsonpg/phils-be...zoom=1412-3690
This looks like a tuned rom to me the AFR is way leaner than stock tune which runs really rich often down in the high 10's. and it appears the LTFT is disabled or you have incredibly good maf scaling as its always zero % normally it would vary a bit.
http://datazap.me/u/olsonpg/phils-be...2403&mark=2325
looks like you need to run better fuel or even just try differnt brands some are way better than others, or get the tuner to back the timing off a bit and/or richen it up a bit higher rpm arround 7000 and also in the 2000-3000 areas where your getting those -2 degree knock corrections or increase the intake air temperature retard.
its not rearly bad but could be better.
olsonpg (09-01-2015)
Old 09-01-2015, 09:27 AM   #606
mcquarrieg
Drives: Whiteout FR-S "Irene"
hi @steve99
here is the quick 3rd gear pull recorded yesterday morning. let me know what you think or if i need to include more/different parameters.
there ~50-60 learned miles btw. airaid intake, op/fp, cat back, oft stg2 el e85 (stock header)
http://www.datazap.me/u/mcquarrieg/l...4?log=0&data=1
thanks!
mcquarrieg is offline   Reply With Quote
Old 09-01-2015, 07:36 PM   #607
olsonpg
olsonpg's Avatar
@olsonpg
I wish i could hit the thanks button a 100 times! THank you so much. When i have more time this evening i'll study the maps and what you have said. I am tuned and it was with 91 octane... 93 is hard to come by here in Iowa (where i'm at anyways)...
Granted im being remotely tuned and this is the 2nd ROM update I have received... Soo we're still working on it... but thank you so much again!.
Old 09-01-2015, 08:08 PM   #608
steve99
Drives: FT86
Originally Posted by mcquarrieg View Post
hi @steve99
thanks!
i cannot open the log ,i think you need to select the "public" checkbox so other can see :-)
Old 09-02-2015, 09:11 AM   #609
mcquarrieg
darn it lol. ok try now
Old 09-02-2015, 10:58 AM   #610
phrosty
Did you just recently switch over to E85 (i.e. residual 93 still in tank)? It's safe, but you're running pretty rich up top.
phrosty is offline   Reply With Quote
Old 09-02-2015, 02:31 PM   #611
DarkSunrise
DarkSunrise's Avatar
Switched back to OFT stage 1. Looks like I'm now running slightly lean.
AFR goes from 13.9 @ 2800 RPM --> 13.2 @ 4000 RPM --> 12.3 @ 6700 RPM/redline.
Commanded AFR is ~0.5 richer on average. Is this a reason to be concerned?
Here are two 2nd gear pulls.
http://www.datazap.me/u/darksunrise/...1?log=2&data=1
The car feels strong (stronger through the midrange than stage 2?), but I am seeing some FLKC on the logs.
2022 BRZ Build
2013 FR-S Build
Old 09-02-2015, 03:28 PM   #612
mcquarrieg
@phrosty - yes i'm about 150 miles in on my first E85 fill-up. ~60-70 miles have been closed loop/learned miles.
stupid question - what value are you looking at and what should a more normal looking value be?
Old 09-02-2015, 06:13 PM   #613
phrosty
When WOT, AFR with an E85 tune should be 12.06 @ 6000rpm and 12.14 @ 6800rpm.
The Following User Says Thank You to phrosty For This Useful Post:
mcquarrieg (09-03-2015)
Old 09-02-2015, 07:34 PM   #614
steve99
Drives: FT86
looks like a rearly hot day iat 100 and above
if you did a little maf scaling it would bring you afr and commanded afr togeather, you probably only need to do the open loop scaling ie above 3.2 volts that will make you run to the commanded afr ie slightly richer which will probabaly clean up that bit of knock.
the iam is solid at one so the ecu software not bothered about that knock.
if correcting the afr does not fix it then make the iat retard tables a bit more agressive at the high iat temps your seeing.
the stock tune knocks way worse than that
DarkSunrise (09-02-2015)
Old 09-02-2015, 07:47 PM   #615
steve99
Drives: FT86
log commanded AFR as well as AFR during wot they should follow eachother .
see the logging link below
it looks ok for first tank of e85 ie negitive fuel trims due residual petrol, see how it goes on next fill, you car looks like it got the maf sensor that runs on the rich side, it safe but will result in slightly worse economy and power.
if your handy with romraider you can port accross waynos tune changes to your map.
Old 09-04-2015, 11:19 AM   #616
mcquarrieg
i filled up the 2nd tank of e85 this morning and will do some more closed loop learning and take another log in a few days and resend. glad to know i'm on the safe side. so are guys seeing good afr's (12s) during high rpm wot with stock headers?
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
