| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1513 | |
Drives: the white one
Sent from my SM-G920V using Tapatalk
If you can't win a race, beat the person in front of you
#1514 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
#1515 |
Drives: Toyobaruion
| The Following 3 Users Say Thank You to c4lvinnn For This Useful Post: |
#1516 | |
Are you 20/20?
Drives: Hopes and dreams
Also, I don't think 3.2 is excessive camber by any means. If you're running 0 camber all around, it just means you aren't gripping as well in the corners. I'm at -2.5 all around (265/295) and my contact patch is fine, thank you
#1517 |
Drives: 13' Scion FRS
#1518 |
Drives: Toyobaruion
#1519 | |
What is your opinion on a good alignment spec? CC Sent from my SM-G920V using Tapatalk
#1520 |
While there are worse things people do, I do agree with him that is on the excessive side for mostly straight line day to day traffic.
#1521 |
Drives: Toyobaruion
#1522 |
#1523 |
Drives: Toyobaruion
Why would I answer that when you or Jive have a technical response to the original comment?
This is the meaty tire thread not the bitch about and say how "excessive" or "terrible" a whole 2.5 or 3.2 rear camber is. |
#1524 | |
the tuna, no crust.
And yes, tire wear does have something to do with it. My RE11 at the end of their life had pretty noticeable camber wear and I rotated them often and i'm always checking pressures. If majority of what you do is street driving then you will for sure see it wear unevenly with that much camber. Mind you I was only running -1.8 in the rear. Running camber in the front is one thing, the rear is another. May I ask what your toe specs are? What suspension do you run? Right now i'm running -1.6 in the rear..08 toe in per side. -1.9 in the front with slight to out. my favorite setup was when the front was at -2.2 slightly toe out, rear at -1.8 toe in a bit. car turned in so nicely. |
| The Following User Says Thank You to Jive Turkey For This Useful Post: | Hicklinc (02-25-2018) |
#1525 | |
Drives: Toyobaruion
BC Coilovers. 0.08 toe in as well, -3.5* front camber with toe at 0. This isn't my first rodeo with camber. I used to run -6.4* (natural from just the drop) on a double wishbone front suspension and drove that like a madman. Rears were around -4.5. Tires lasted me 10-12k miles. Completely negligible to me so don't use tire wear as an explanation as this is less than half of that specific set up. Oh and that was with 360 treadwear which isn't much... My car is very reactive to input which I want and has no negative effects, no squirelly, no unstable high speeds from toe or camber, etc. Does everyone forget that toe kills tires, not camber? Last edited by c4lvinnn; 09-04-2015 at 02:21 PM. |
#1526 |
There is more to it than what you think you know, and yes it is because of the attitude that I cbf to participate in further discussions with you.
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
