Old 08-31-2015, 05:58 PM   #183
churchx
churchx's Avatar
Drives: 2014 GT86
Higher spring rates .. wasn't that already in EUDM/JDM Z-s?
(I sometimes wish for CSG to test JDM Flex Z-s too, as for customers on other side of pond ordering USDM version will worsen main advantage of low price for good dampeners due import/shipping charges, and also it may be harder to warranty/service/order replacements for USDM variant, adding time and cost to ship overseas for that as well)
Old 08-31-2015, 06:30 PM   #184
CSG Mike
CSG Mike's Avatar
Well, if you can fly me to Japan and provide me with a 86 equipped with the JDM spec Flex-Z, as well as arrange some track time, I'll gladly get the testing done
Old 08-31-2015, 06:32 PM   #185
kbye
kbye's Avatar
Drives: 2014 FR-S
Spring rates identical.
If there is a conceivable difference in dampening, you could probably not tell for street use. I had JDM spec, rode over potholes just fine.
You will always get better warranty and service by ordering your coilovers through your local or regional authorized dealer.
kbye is offline   Reply With Quote
The Following User Says Thank You to kbye For This Useful Post:
CSG Mike (08-31-2015)
Old 08-31-2015, 10:08 PM   #186
tracerit
Drives: '13 SSM BRZ Limited 6MT
I'm adjusting the height now for the rears but one side the springs (just the springs, not the whole strut(?)) are rotating freely while the other side it's taking a lot of effort to rotate. The measurement for the seat lock (for Springs) and the lower bottom lock for height are the same now after my adjustment. Is this normal? Should the springs be taut or loose? Car is currently jacked up by the differential btw. It's the drivers side that's loose, could it be because the passenger side has the gas tank and it's pitting pressure on the springs? I do have a full tank. Yeah, I'm not sure haha
tracerit is offline   Reply With Quote
Old 09-01-2015, 08:20 PM   #187
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Prior to install, it is recommended to adjust the coilovers according to the recommended measurements provided in the manual. These values allow you to set the preload to the recommended setting without too much effort and allows you to set the ride height accordingly. Tighten the collars and perches properly, not semi-loose (which causes the assembly to seemingly sag or lose your measured spec). Always check that the top nut is tighten properly to ensure that top hat sits securely on the coilover and holds the springs in place. These are general tips to take into consideration and to let your mechanic/technician know before install.
CounterSpace Garage is offline   Reply With Quote
The Following 3 Users Say Thank You to CounterSpace Garage For This Useful Post:
chaoskaze (09-02-2015), GT86_PRAGUE (09-11-2015), tracerit (09-01-2015)
Old 09-01-2015, 11:02 PM   #188
tracerit
I just measured and adjusted the rear and going for the fronts now. The rears were off by over an inch both sides. With everything matched to the recommended measurements, the spring is no longer loose. Although the right rear is 2/16th inch higher after reinstalling everything still. , would that be a problem down the road?
Old 09-01-2015, 11:14 PM   #189
CSG David
CSG David's Avatar
Just start doing everything first and make sure everything is tight. Then drive around and recheck. It should be good to go.
Old 09-06-2015, 10:06 AM   #190
mid_life_crisis
Drives: FR-S 10 #103 AT
If I keep the car long enough to wear out the factory dampers, this looks like the way to go, assuming they're still available. I just have one strange thought.
Does anyone else find it odd that they designed dampers with 28 levels of adjustment that are pretty much never set beyond 8 or so?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 09-06-2015, 11:02 AM   #191
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Marketing ploy
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 09-06-2015, 12:59 PM   #192
churchx
churchx's Avatar
Drives: 2014 GT86
Did they ever stated in marketing materials or product description that there are 28 lev of adjustment? Otherwise it looks to me that there is groundless product bashing simply because some users guess/expect that each and every click from those 28lv should be available just because they think so, and tein should spend time/efforts to remove 'redundant clicks'. To me it looks rather sharing some parts or designs or thread depths with other coilovers to quicken and to save on development costs, hence nothing wrong if even with just lesser real adjustment levels count they still does what they should, unless they actually marketed it other way.
Old 09-06-2015, 01:09 PM   #193
SilverFRS
Drives: Silver FRS
Instructions included with the product state 16 clicks, marketing also I believe.
SilverFRS is offline   Reply With Quote
Old 09-06-2015, 02:07 PM   #194
Jonde875
Drives: GT86
How much is the camper on rear with this kit if I put 18" wheels and lower it to be flush? Is there need for adjustable camber control arms?
Jonde875 is offline   Reply With Quote
Old 09-06-2015, 02:16 PM   #195
SilverFRS
Drives: Silver FRS
At 1.2" lower than stock, ended up at -1.8 left, -2.5 right, so I bought cheap SPC lca, not sold on their adjustment method, haven't installed yet, any body weigh in on SPC?
The Following User Says Thank You to SilverFRS For This Useful Post:
Jonde875 (09-06-2015)
Old 09-06-2015, 08:47 PM   #196
tracerit
Any recommendations for what I numbers I should have the shop doing the alignment go for? I'm dropped to the factory specs from Tein and this would be for highway and street driving.
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 04:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 04:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 04:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 05:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
