| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1499 |
Drives: 2018 Golf R
If you can't find an answer here, put tire shine on your tires, slap a piece of blue painters tape all the way around the fender lip, and go for a drive. When you get back, wherever you're rubbing should be clearly marked on the tape.
Parting out HERE
| The Following User Says Thank You to civicdrivr For This Useful Post: | Lust (08-20-2015) |
#1500 |
Drives: 2017 Subaru BRZ
Thanks for that tip I'll definitely do that. Though it seems that people who already have this setup with no issues have a secret formula or I just have bad luck
#1501 |
Drives: Toyobaruion
I really don't understand how you're rubbing with like 2 finger gap with that camber and spring rate. Even if I put mine on full soft dampening, i don't even really rub more frequently.
#1502 | |
Drives: Honda Civic Type-R FK2
Skickat från min LT26w via Tapatalk |
#1503 | |
Drives: 4 wheels
I tried to put r888 265/35/18 and it stuck out 1 in. running -1.8 in the rear. Rays 57xtreme 18x9.5 40+... Very disappointed it ended up on Craigslist the tires ![]() .
Pekingduck's Build thread http://www.ft86club.com/forums/showthread.php?t=5717
| The Following User Says Thank You to Pekingduck For This Useful Post: | Hicklinc (02-25-2018) |
#1504 |
In all honesty i have no clue what my current camber is but it's far from aggressive. Maybe the R888 run wider then the Cup 2s?
#1505 |
Drives: '14 SWP BRZ Limited
Looks like you're at stock height? You're goint to have to be lowered to not have something like that poke out...
#1506 |
Drives: 4 wheels
My car is lowered, it makes it worse at you correct camber after lowering the car.
#1507 |
Drives: 4 wheels
I am just trying to show the different sizes between manufacture and even within it own company.
#1508 | |
Drives: '23 BRZ Limited
It's widely known R-comps run very wide compared to street tires. Look at the section width vs the "numbered" size of the tire. For instance, I used to run 205 R888s on 8" wide wheel on the Miata, and lots of Miata guys run 205 Hoosiers on 9" wide wheels. |
#1509 | |
Drives: 4 wheels
I tried to do a search and couldn't find anything on 265 R888 so I thought I would try. At least it add to this search engine in regards to this setup.
#1510 |
Drives: 2015 Frs
Cant wait to get my pics up, only a couple more parts on, running a set of ssr 18x9.5 all the way around with a 255 tire, gonna see how well it fits
#1511 |
Drives: 13' Scion FRS
Posted in the 'Will it Fit' thread, but figured you guys might be able to help too...
I've done some research on a wheel setup and it looks like it'll "fit". I would just like to confirm and possibly get any pics of the setup, if available. 17x9 +30 245/40 Stock suspension for now, but will be lowering it soon. I know it'll poke at stock, so I might just wait till I lower it to put them on. Thanks in advance! |
#1512 | |
Drives: LR BRZ Limited
i have same specs as above but in +25. you'll need to run neg camber to avoid poke. im running coilovers but you might hit the front shocks with those offsets on full lock maybe. |
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
