Old 08-27-2015, 12:05 AM   #57
CSG Mike
CSG Mike's Avatar
Originally Posted by SomedayIsuppose View Post
Mike,
Couple questions, gonna be in Socal near the holidays and would be interested in having CSG do the install based on your thorough posts about it.
1. I know you said there isn't a break in, but is it advisable to install the kit and a few days later drive back to Oregon?
2. Do you have a ballpark for labor on install? I assume under a day for pros like you guys.
Thanks!
1. There is litterally no break-in for the supercharger. EVERY supercharger that is assembled at Edelbrock is run in-house to verify that it works properly.
2. We do, PM us.
SomedayIsuppose (08-27-2015)
Old 08-27-2015, 12:10 AM   #58
CSG Mike
CSG Mike's Avatar
Originally Posted by FyeaFRS View Post
Jesus the install instructions are nightware-ish. I put a deposit down for this kit and am seriously reconsidering it now. There's so many modifications you have to do just to install. They claim this to be a simple bolt-on kit, but it looks to be far from it. Really bummed about it
http://www.edelbrock.com/fa20/downlo...structions.pdf
This is pretty typical for any supercharger kit of this type. When you break it down to the most basic steps, virtually every step is a "tighten bolt", "loosen bolt", "push in", or "pull out".
The Innovate/Sprintex kit is similarly involved, as is the Cosworth, and, I speculate, the Harrop.
If you are uncomfortable performing the installation, I'd recommend you find a local shop that can install the kit for you.
Old 08-27-2015, 11:11 PM   #59
zigzagz94
BRZerhood Lurker #13
zigzagz94's Avatar
Drives: 15 DGM BRZ Premium
CSG, I'm assuming the R&D on this kit was designed around not having an oil cooler. Would an oil cooler be needed for a pure DD that's not going to see any track usage? Edelbrock is marketing this as an all inclusive kit but for a DD are there other things that are considered must have complimentary upgrades? Thanks.
Yesterday is history. Tomorrow is a mystery. Today is a gift and that's why it's called the present.
zigzagz94 is offline   Reply With Quote
The Following User Says Thank You to zigzagz94 For This Useful Post:
Afghan Vet (10-21-2016)
Old 08-28-2015, 04:23 AM   #60
Calum
That Guy
Drives: 2013 asphalt FRS MT
The only way to know will be to log your oil temps and see. I know my car running in light traffic, in Nova Scotia "summer" ~ 25 - 30 C, at stock power, will run oil temps of about 98 - 99 C. I'd have to guess that running a super charger would increase that, but a better tune might lower it for steady highway cruising.
The Following User Says Thank You to Calum For This Useful Post:
zigzagz94 (08-28-2015)
Old 08-28-2015, 05:49 AM   #61
Kodename47
Kodename47's Avatar
Drives: UK GT86
For a DD an oil cooler is completely unnecessary. You want oil to be 100-110C. With my Sprintex and cruising on a Spanish motorway in summer for hours I never saw oil temps over 105C and they drop off as soon as you come off the throttle.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-28-2015, 06:10 AM   #62
CSG Mike
CSG Mike's Avatar
For street driving? No, you don't need a cooler.
If you're going for spirited drives that have sustained high RPM, or are tracking the vehicles, you should have an oil cooler.
Edelbrock probably has something in the works, but there are several options that fit, if you decide you need an oil cooler.
The OEM FA20DIT cooler is a perfect match for street driving, and casual spirited drives; it is not suited for track driving.
Old 08-28-2015, 06:25 AM   #63
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
But Mike, what about the mishimoto sandwich plate that fits the 15 wrx, supposed to work with an air to oil cooler along with the water to oil cooler
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline   Reply With Quote
Old 08-28-2015, 08:03 AM   #64
OkieSnuffBox
Drives: '23 BRZ Limited
At first I wasn't too intersted in this particular setup. Because of the lower peak numbers, but I'm thinking this + oil cooler + E85 could be pretty awesome because of the big midrange bump......
Seems as though with E85 it would be pretty easy to add even more midrange and peak power, without maxing out the fuel system. That's an intriguing idea. Essentially use E85 to bring it up to JRSC peak levels.
Old 08-28-2015, 11:11 AM   #65
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by DarkSunrise View Post
Wow the Edelbrock-provided dynosheet looks impressive. (Assuming this is apples-to-apples 91 octane CARB comparison...) More midrange torque than the C30-94 JR/KW rotrex superchargers (3500-6000 RPM), but matches them top-end (6000+ RPM).
@CSG Mike
What are your thoughts on Edelbrock vs. JRSC? Primarily focused on power delivery and track durability. We all know JRSC is track-proven, how about Edelbrock? Thanks!
If the unit proves decently reliable, I think I've found my FI solution. Cheaper than the innovate (which is over $5k with the IC) with way more topend... hell yeah!
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
CSG Mike (08-28-2015)
Old 08-28-2015, 11:17 AM   #66
OkieSnuffBox
@CSG Mike any idea how much more cranking power you need from the battery with this?
I was planning on going with one of the lightweight batteries, but was curious if they would still have the juice to crank this over.
Old 08-28-2015, 11:52 AM   #67
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
The high low and mid-range torque isn't surprising. TVS blowers are extremely efficient and always make tons of low-end power.
@Alltezza depends on design. TVS blowers like these usually do not whine unless you're spinning them to make 15+ PSI. Traditional roots and twin screw blowers have a lot more whine.
An aftermarket open element intake will help increase whine, but you likely will not notice much.
BRZoomTX is offline   Reply With Quote
Old 08-28-2015, 12:17 PM   #68
CSG Mike
CSG Mike's Avatar
I think you'd be okay with any of the proven lightweight batteries. I'm 99% sure the KC Machine battery would be just fine. (We sell that too!)
Old 08-28-2015, 12:55 PM   #69
CSG Mike
CSG Mike's Avatar
Ohai
The Following 7 Users Say Thank You to CSG Mike For This Useful Post:
BigFatFlip (08-29-2015), chaoskaze (08-28-2015), MaximeT (08-28-2015), ravisraval (08-28-2015), SirBrass (08-28-2015), SomedayIsuppose (08-28-2015), stoked_on_spool (08-28-2015)
Old 08-28-2015, 01:05 PM   #70
OkieSnuffBox
I have an unhealthy amount of want for this.
The Following 3 Users Say Thank You to OkieSnuffBox For This Useful Post:
JoeC (08-28-2015), SomedayIsuppose (08-28-2015), SuperDave (09-08-2015)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
