Old 08-27-2015, 05:44 PM   #239
Originally Posted by Sideways View Post
But he told me that there is yet another newer version of fuel pump on its way but won't be available for another few weeks, so if the problem returns after new fuel pump, I will have to take it in again after few weeks to get fuel pump replaced again.
HunterGreene (09-15-2015)
Old 08-27-2015, 06:10 PM   #240
zonda
Drives: 2014 WRB BRZ
have a 2014 and after it rains or gets washed. the driver window makes an annoying loud screech noise for a few days after. its probably been mentioned, but can scion tsb for weatherstrip be applied for the brz?
zonda is offline   Reply With Quote
Old 08-27-2015, 08:24 PM   #241
73TORANA!
Drives: Orange GTS
I had the same issue. Get some Sellies EZY glide Teflon spray and spray it only in the window runner channels carefully. Mine has been good for a year now since I sprayed it. Any dry lube Teflon spray should do from you local hardware store. Its used on zippers for cafe'e PVC blinds. It might take a couple of sprays to lube the runners but it fixed mine MY July 13.
73TORANA! is offline   Reply With Quote
Old 08-27-2015, 08:39 PM   #242
73TORANA!
Drives: Orange GTS
Originally Posted by aegisdrgn View Post
Insider access at dealerships.
Sent from my HTC One using Tapatalk
Any chance you could ask your insider if they have had any brake clunking noise issues originating from the booster / master cylinder area. Mine occasionally has this weird metallic sound coming from the booster area when the pedal is released and it not the pedal linkages, other times its perfect.( brakes performance is fine, no problem there just this clunk) more noticeable when released fast. Toyota AUS changed the booster but it still pops up now and then, most annoying. Toyota AUS not fast in reacting.
Thanks.
Old 09-29-2015, 01:27 AM   #243
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Are all the TSB on post 1, up to date? Anyone know?
Old 09-29-2015, 04:27 AM   #244
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It's about 8 months since it's last update. Those however are the latest TSB up to that time no doubt:http://www-odi.nhtsa.dot.gov/owners/...od_ids=1471823
About 10 TSBs total on the NHTSA site for the 2013 FR-S absolutely nothing for the 2014 or 2015 (my year) is registered there because those issues are fixed during production for the most part. @Sigh-on-Rice is pretty active he would be able to answer the question better I believe.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Packofcrows (09-29-2015)
Old 09-29-2015, 05:52 AM   #245
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Post 1 has everything I found on this forum. If there is any TSB that was released but not posted on this forum, then I wouldn't have those. But I think this forum has more information about TSB (or any issues with twins) than everything you can find from elsewhere on the Internet.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
notout86 (09-29-2015)
Old 09-29-2015, 06:05 AM   #246
There is this but I can't find anymore beyond what is written here:
Technical Bulletin S-SB-0021-15, issued September 17, 2015, Idle Fluctuation in Park or Neutral.
Applicability: 2015-2016 FR-S
Introduction: Some 2015-2016 model year FR-S vehicles may exhibit a condition where the engine idle speed fluctuates (typically 500 - 1000 RPM) only when the transmission is in the Park or Neutral shift position. This condition occurs after the vehicle has been driven about 25 miles or more at highway speeds. The Transmission Control Module (TCM) logic has been revised to address this condition.
http://www.ft86club.com/forums/showp...&postcount=134
Sigh-on-Rice (09-29-2015), Ultramaroon (09-29-2015)
Old 09-29-2015, 03:16 PM   #247
Sigh-on-Rice
I totally missed it. I thought that thread was for "S-SB-0040-13 : Intermittent RPM Drop" and didn't even keep up reading it. Thanks for the info. I updated the 1st post linking to your post for now since there is no soft copy of the TSB document available now.
The Following 2 Users Say Thank You to Sigh-on-Rice For This Useful Post:
notout86 (09-29-2015), Ultramaroon (09-29-2015)
Old 09-29-2015, 03:58 PM   #248
FRSBRZGT86FAN
Thanks! I'd really like to get that TSB done, I've noticed an idle issue on my car which is also an idle issue if a printout is available
Old 09-29-2015, 05:15 PM   #249
You guys have @arvidj to thank. I am just the messenger.
Sigh-on-Rice (09-30-2015), Ultramaroon (09-29-2015)
Old 09-30-2015, 11:53 AM   #250
FRSBRZGT86FAN
Hey sigh I attached the full TSB document for you to add to the main post!
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Sigh-on-Rice (09-30-2015), Tcoat (09-30-2015)
Old 09-30-2015, 03:08 PM   #251
Sigh-on-Rice
Thank you! I just added it to the main post.
FRSBRZGT86FAN (09-30-2015), steve99 (09-30-2015)
Old 10-01-2015, 02:48 PM   #252
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
Finally a fix for the idle hunt issue in park! I always think back to the 13's that nearly stalled everytime it happens. I have that and rough shifting in manual (manual MODE), so hopefully a trans reflash will fix that.
V_86 is offline   Reply With Quote
chirping, high pressure fuel pump
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 10:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 12:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 07:00 PM
Owners Manual Recall Opie BRZ First-Gen (2012+) — General Topics 8 06-05-2012 10:09 PM
Did anyone get a call from toyota about a recall yet? AustinTCLN Scion FR-S / Toyota 86 GT86 General Forum 2 06-04-2012 11:45 PM
