Old 08-25-2015, 09:47 AM   #29
Originally Posted by Bristecom View Post
But... my Eclipse has the whine and it has syncros. I was just wondering if the whine is still there but just masked with modern insulation. Unless it is something with newer types of syncros or the tolerances (although I haven't heard anything that changed in newer transmissions other than more syncros in the lower gears).
Ya, I oversimplified. It isn't just the syncros it is the whole make up of trannys with syncros that usually make them quieter. Newer oils, gear cut, better bearing, etc all come into play. There are exceptions of course.
Bristecom (08-25-2015)
Old 08-25-2015, 03:03 PM   #30
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Talking
Since I removed my spare some times I can hear my Differential whine with rear seats down, I think I Fuped my sound deadening in the trunk lol.....but I love the noise as I accelerate in every gear.
Old 08-25-2015, 03:13 PM   #31
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I'm starting to feel it chatter at low speeds when I'm being dumb and trying to lay down the powah
ineedyourdiddly
chaoskaze (08-25-2015)
Old 08-25-2015, 09:47 PM   #32
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
How many miles? My Eclipse had the whine but that was after a quarter million miles. Bearings were cooked.
Yeah but my brand new transmission I put in there still makes the whine, maybe not as much though.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
The Following User Says Thank You to Bristecom For This Useful Post:
Ultramaroon (08-25-2015)
Old 08-25-2015, 10:08 PM   #33
It isn't diff whine is it? My Talon TSI howled like a banshee.
Old 08-25-2015, 10:11 PM   #34
The Tor
Drives: 13 FR-S Argento
My old 81 El Camino made an awful lot of racket.
But that car had a very leaky transmission and power steering reservoir, disintegrating exhaust system, a slipping belt, and was basically being held together by very thick coat of bright yellow paint my uncle threw all over it.
The Tor is offline   Reply With Quote
Old 08-25-2015, 10:17 PM   #35
AHHHHH the sound of a power steering pump that is low on fluid. There was zero doubt as to what was wrong.
The nostalgia brings a tear to my eye.
humfrz (08-27-2015), The Tor (08-26-2015), Ultramaroon (08-25-2015)
Old 08-25-2015, 10:52 PM   #36
If the pitch continues to climb with vehicle speed, it's either the diff or the trans output shaft. If it follows engine speed and drops with each shift, it's the input shaft. Mine was the input shaft.
Bristecom (08-26-2015), Tcoat (08-25-2015)
Old 08-25-2015, 10:58 PM   #37
Mine was with outa doubt the diff. I went with a bit heavier oil and it was good for about a month but then went right back to it's Bjork imitation.
Old 08-27-2015, 01:29 AM   #38
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Just put enough aftermarket parts on and change your gearbox fluid. My car makes all kind of lovely ticks, whines and pops that were covered up by the engineering of the oem parts.
Bonus points if you get some stout brake pads and slotted rotors- you get that race car brake squeal when coming to a dead stop on any day below 60 degrees.
Sent from my LGLS990 using Tapatalk
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
BEST of Start Up sounds!! More than 70 Exhaust Sounds! JPxM0Dz Other Vehicles & General Automotive Discussions 5 01-08-2014 03:24 PM
Help Fund This Abandoned Iowa Race Track's Glorious Comeback dem00n Off-Topic Lounge [WARNING: NO POLITICS] 1 10-21-2013 09:56 AM
Help Fund This Abandoned Iowa Race Track's Glorious Comeback dem00n Tracking / Autocross / HPDE / Drifting 0 10-20-2013 11:34 PM
Overall mechanical satisfaction? Tman08 Issues | Warranty | Recalls / TSB 15 08-26-2013 06:28 PM
