#127 | ||
Drives: Toyota 86 - Charcoal Grey
I try my best to threshold brake but yeah, especially on downhills, it's easy to get onto the ABS. What makes it harder on the brakes in particular? Is it temperature fluctuations or something to do with how the pads respond to different pressures? So on that note about ABS - now that I got myself some Bridgestones instead of the slippery OEM tyres, I'll obviously be able to brake harder without locking up and triggering the ABS. So being able to brake harder = harder on brakes, but not triggering ABS = lighter on brakes. Any idea if this will improve or degrade my situation? |
#128 | |
Platinum Member
Drives: Toyota 86 Vortech SC
I normally go off track before the end of the session, and trying to do a cool-down lap in heavy Supertrax traffic is kamikaze foolishness.
I don't think so. It's the same amount of momentum being converted into heat energy, whether one brakes harder or not. I certainly haven't found that sticky tyres put more strain on my brakes...
#129 |
Drives: Lawn moweR
Just called Toyota to quote me on changing brake pads (front and rear) and bedding them in, they quoted me R1400 and some change..
![]() Guess I better find myself that tool to change my own brake pads and disc
#130 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
Ouch. You pretty much need one or 2 spanners only. Undo the top bolt on the caliper and swing them over.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#131 | |
Platinum Member
To change pads you need a 14mm ringspanner. I slacken the top bolt and remove the bottom bolt, then the caliper doesn't hang on the pipe. The toughest is pushing the pots back when fitting new pads - needs some force. Once you've done it a few times, you can do it in your sleep.
#132 | |
If you're only doing the pads, you just need a 14mm socket and possibly a C-Clamp to depress the calliper pistons. It's not too bad. As long as you can safely lift the car it's hard to screw up. If you're doing disks, it's a bit more work. Sure, @Fish Eagle mentioned that he does his quickly now, but for a first time job if you don't work on cars, just be ready for it to taker longer than you anticipated. Also, the 17mm bolts mounting the calliper are a lot tighter than the 14mm bolts holding it closed. These can be a pain to crack loose because there isn't a lot of space to fit a breaker bar. You also need to decide how seriously you take the recommended torque specs. I wanted peace of mind, so I bought 2 torque wrenches to cover all my bases. Same for measuring the disk runout - you will need a dial indicator. You can decide to skip these steps of course. Chances are the disks are perfectly manufactured and will "just work", and that a bolt that is "nice and tight" won't cause issues. I'm willing to loan tools with a collateral, so if they come back it's , but if they don't, we can avoid the
#133 |
C-clamp works great. Or use your thumbs...
95RON SAV Tuned |
#134 |
Platinum Member
With your thumbs!!
Remind me not to pick a fight with you ![]() I normally use a big screwdriver as a lever - works OK. A clamp is much better, but I can never find one. The probability of finding the right tool in your workshop is directly but inversely proportional to the number of adult male children that you have.
#135 |
ROTFLOL!! Sometimes it's the only way.
![]() I agree though, having the right tool and actually being able to find it are two completely different things.
95RON SAV Tuned |
#136 | |
95RON SAV Tuned |
#137 | |
Platinum Member
Cost?
#138 |
Will keep you posted. Was R1800 from International Race Supplies. Contact person is Mike Bond. Pads were recommended by Pyro Performance.
95RON SAV Tuned |
#139 |
Platinum Member
Fitted new PB discs today, R2700 delivered Nelspruit.
My previous PB discs lasted 16 track days ![]() I've recently done 4 track days on stock discs as a stopgap and to see how they shape up after using PB. For day 1 & 2 they were fine, day 3 they were OK'ish, but by day 4 they were shuddering badly...
#140 |
Drives: Lawn moweR
I finally got down to ordering Endless PB05 pads (Front) and Bendix(Rear) from Powerbrake last night,
I emailed Francois to find out the 'correct' or 'proper' bed-in process, and got this response, hope this is useful, will try it out, what do you guys think about this process? "Bed-in Cycle: 1. Drive slowly for 1 week (at least 200km’s) after fitting the new pads. Use moderate brake applications during this time and try to avoid long brake applications from speeds in excess of 100 kph. Normal urban commuting, using your brakes from moderate speeds about once per kilometre is ideal. Long stretches of open road driving do not count, as the brakes are not being used. Increase following distances during this time making provision for “green fade” in an emergency stop. Never left foot brake or drag the brakes! After this ... 2. Drive a few kilometres, using the brakes gently to bring them up to a moderate operating temperature. 3. Perform 6 consecutive brake applications of increasing intensity from 100 km/h down to 30 km/h. If wheel lock-up (or ABS activation) is referred to as a 100% brake effort then you should be aiming to build up to a 60 - 70% brake effort for the last two applications. The applications should be performed consecutively, accelerating normally back up to 100 km/h after each application, before braking again. 4. If possible, do NOT come to a complete stop throughout the 6 brake applications described above. Doing so can result in ‘pad etching’ during which friction material is unevenly deposited onto the brake disc causing DTV and brake judder. The etching will be visible as the outline of a brake pad on the disc surface. (To learn more about pad etching and DTV click here) 5. It is possible to experience “green fade” from the 4th or 5th application onwards - this is not an issue. 6. Drive on, using the brake as little as possible, for a number of kilometres allowing the brakes to cool substantially in the air-stream before parking the vehicle and allowing the brakes to cool completely. This cooling cycle is important. Regards Francois " |
| gc8 4 pot brakes | wholeeoh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 05-15-2022 04:38 PM |
| Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 05:53 PM |
| GT to GTS brakes? | Turdinator | AUSTRALIA | 30 | 01-12-2014 12:33 AM |
| OEM Brakes? | marinjim | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-20-2012 10:26 PM |
| GT brakes | jello | AUSTRALIA | 2 | 06-10-2012 09:10 AM |
