Old 08-22-2015, 07:20 PM   #15
ajc209
Drives: GT86 Cosworth
The TMG CS-V3 cup cars have optional 10mm spacers front and back to increase track width with et48 ultraleggeras. In case you didn't know, TMG are Toyota's offical motorsport team in Europe that build the le mans cars and won all those rally championships in the Celicas.... if they say its okay to run those spacers. ...
ajc209 is offline   Reply With Quote
Old 08-22-2015, 10:05 PM   #16
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I've run stock (+48), +45, +40 and +35 offset wheels from 0 camber to -3.2* degrees and there was very little difference in steering effort required between the different offsets. Not sure how much effect it has on tire wear characteristics, but steering effort, not so much.
Intent > Content
Old 08-22-2015, 10:59 PM   #17
Originally Posted by 7thgear View Post
curious about this as well
Negative effects of excessive scrub radius are rarely written about.
A personal very negative effect for me is the greatly increased possibility of turning what would be minor curb rash into a catastrophic accident.
I don't remember how much positive scrub I had on my 240Z but whenever I barely touched a curb it would rip the steering wheel right out of my hands. I was always afraid of tapping a curb at any speed over a creep.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
johan (08-23-2015), MaximeT (08-23-2015), Plumbus (10-23-2019), Wayno (08-31-2015)
Old 08-23-2015, 02:53 AM   #18
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
That's how I understand the possible troubles with scrub radius. The curb could suck your steering wheel and makes you turn more than what you want.
The question is: when does trouble start ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 08-23-2015, 03:00 AM   #19
Originally Posted by MaximeT View Post
The question is: when does trouble start?
Good question. No idea but I have first-hand experience of when it's over the top.
Old 08-23-2015, 03:04 AM   #20
MaximeT
MaximeT's Avatar
My only experience is with LFS simulator. The only one I know where you can test different scrub radius.
The effect is scary.
The Following User Says Thank You to MaximeT For This Useful Post:
Ultramaroon (08-23-2015)
Old 08-25-2015, 07:18 AM   #21
JDM4E
Drives: Honda Accord Euro
good call, I couldn't find the 10mm info tho. How do you know? Anyway I agree that if it is good for them...
JDM4E is offline   Reply With Quote
Old 08-25-2015, 07:57 AM   #22
ajc209
10mm spacers.
First mentioned here:
http://www.toyota-motorsport.com/mot...tmg-gt86-cs-v3
and can be seen here on page 55 of the user manual:
https://www.google.co.uk/url?sa=t&rc...nTTLlxtcbYPbyQ
The Following User Says Thank You to ajc209 For This Useful Post:
JDM4E (08-25-2015)
Old 08-25-2015, 11:49 AM   #23
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
depending on how the camber is achieved, you might actually be angling the strut to compensate for the increased offset so the actual effect on scrub is much smaller than the raw offset value.
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
Ultramaroon (09-07-2015), wheelhaus (08-25-2015)
Old 08-25-2015, 12:26 PM   #24
solidONE
solidONE's Avatar
The camber was added from camber bolts, so the increased negative camber probably had the opposite effect of increasing scrub radius a little, if anything.
Intent > Content
Old 08-25-2015, 05:00 PM   #25
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
This.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 08-27-2015, 02:52 PM   #26
ajc209
Exactly. IIRC 2 degrees of negative camber (strut camber not bolts) at the front moves the scrub radius out by about 5mm. I cant find my friggin spreadsheet now actually I need it
So you might actually want spacers if you add significant camber depending on the wheel offset.
Old 08-28-2015, 07:33 PM   #27
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
I believe I've found it easier to lift a rear wheel just by adding 10mm spacers. Of course, we're talking about hauling ass up steep driveways. The other thing I noticed is bigger scrub radius exacerbates body roll. Even at standstill, turning the wheel lock to lock causes noticeable roll. Maybe 1-1.5" as measured at the roof?
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Old 08-28-2015, 09:17 PM   #28
I'm not picturing this unless you're talking about changing, what is it with camber plates fore-aft, rake?
...well, plates in the strut tower that can do both.
Scrub radius help ChrisD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-08-2015 10:14 PM
FS: Whiteline bushings KDT926 (Positive shift kit) & KDT922 (Positive traction kit) Tim_Asphalt_FRS Transmission and Driveline 3 09-26-2014 11:41 AM
Decreasing radius corners ZionsWrath Other Vehicles & General Automotive Discussions 48 11-11-2013 07:34 PM
what could cause my avg mpg to drop .3 in 2 miles?? dealer screwing me over? fluffy-reindeer-slayer Scion FR-S / Toyota 86 GT86 General Forum 45 09-02-2012 06:18 AM
which one is positive and negative frs Scion FR-S / Toyota 86 GT86 General Forum 1 08-04-2012 10:42 PM
