Old 08-24-2015, 10:39 PM   #15
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
I wonder how reliable this would be on a stock engine assuming the only thing done to it was bigger injectors and a bigger fuel pump.
Alltezza is offline   Reply With Quote
Old 08-25-2015, 01:51 AM   #16
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
CSG has some packages that will be put together to support the extra boost!
Well well what do you have in mind?? Do tell
Jmonty is offline   Reply With Quote
Old 08-25-2015, 03:41 AM   #17
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Originally Posted by Alltezza View Post
Damnit Mike over at CSG got me excited as fck about that Edelbrock E-force SC and then THIS is announced I don't even know what I want anymore........
I feel exactly the same brother!
clayrush is offline   Reply With Quote
Old 08-25-2015, 05:15 AM   #18
Alltezza
Alltezza's Avatar
Lol I used to be all about turbos but these superchargers are up there now with exactly my power goals that I want. I'm very impressed and excited.
The Following 3 Users Say Thank You to Alltezza For This Useful Post:
clayrush (08-25-2015), hmong337 (11-26-2015), ScionOfHorus (08-25-2015)
Old 08-25-2015, 08:37 AM   #19
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
I have three primary goals that I am looking for from a FI solution and I was thinking that a low mount turbo was the only choice.
1. Minimize heat in the engine bay for sustainable track performance in the southeast.
2. Enough low end torque (3-5K) to make the car entertaining when not wringing it out.
3. Enough highend horsepower to reduce typical shift points to 7K and more opportunity to remain in higher gears and still power out of corners.
I am currently waiting to buy another car so my wife won't have to rotate the FRS anymore, then it's fulltime E85 and transformation time.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
CSG Mike (08-25-2015)
Old 08-25-2015, 10:50 AM   #20
puma
crew chief
puma's Avatar
Drives: Race car FR-S
this may be a dumb question but how hard is it to swap the pulley for someone who would want to switch from a low to a high boost on a couple of occasion during the year? I have not even seen a kit in person so i don't know what kind of work is involved.
puma is offline   Reply With Quote
Old 08-25-2015, 10:55 AM   #21
DaiTT500
DaiTT500's Avatar
Drives:
+1 how bad is the pulley swap? Is it as simple as putting a wrench on the tensioner to move the belt off the pulley and keep the pulley mounted, use allen wrenches to loosen the bolts from the pulley to the rotrex and then swap out, putting the bolts back in and placing the belt back into place?
Would their be an easier way or do you have to unmount the rotrex and swap pulleys out of the car? @Jackson Racing
DaiTT500 is online now   Reply With Quote
Old 08-25-2015, 11:35 AM   #22
sprintamx
Thinking about a track-side swap in/out and then go home? I like that idea!
sprintamx is offline   Reply With Quote
Old 08-25-2015, 12:44 PM   #23
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
Stock motor can take the extra boost?
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline   Reply With Quote
Old 08-25-2015, 12:45 PM   #24
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Yep
Sent from my XT1095 using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 08-25-2015, 12:50 PM   #25
duke_FRS
duke_FRS's Avatar
Drives: 2015 FRS Hot Lava 2014 CT200H
very very interesting.. The supporting mods make sense for a high boost setup.
Open Flash Tablet Stage 1 93 | Borla Cat-Back | VOSSEN VFS1 | Eibach Sportline
duke_FRS is offline   Reply With Quote
Old 08-25-2015, 01:21 PM   #26
CSG Mike
CSG Mike's Avatar
I can outline the steps for you.
- Let the car cool down
- Break loose the 6 hex bolts that secure the pulley onto the supercharger
- Release the tension on the serpentine belt. I usually push down the factory tensioner, and then pull the belt out from around the alternator. You can then release the factory tensioner and the belt will be slack
- Take out all 6 hex bolts from the pulley
- Swap pulleys
- Apply a dab of red locktite to the hex bolts and re-insert them to secure the pulley to the supercharger. Hand tighten loosely.
- Press down on the factory tensioner, and re-install belt. Release tensioner. Verify that the belt is properly routed. *double check belt to make sure it is properly routed
- Torque down the 6 hex bolts to spec.
Note: the belt provides all the support/traction you need to break loose and tighten the bolts attaching the pulley to the supercharger.
On a cold car, I can do this in under 5 minutes total.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
ATL BRZ (08-25-2015), clayrush (08-25-2015), DaiTT500 (08-25-2015), kch (08-25-2015), ScionOfHorus (08-25-2015), Sleepless (09-19-2015)
Old 08-25-2015, 01:24 PM   #27
DaiTT500
DaiTT500's Avatar
Drives:
Bad ass Mike! Looking forward to getting mines.
Old 08-25-2015, 01:29 PM   #28
juliog
juliog's Avatar
Drives: 86
No need to swap tune maps, as long as car is running 93+ or custom E85 then?
juliog is offline   Reply With Quote
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 10:26 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 08:51 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
