Old 08-24-2015, 11:53 AM   #141
Swede
Drives: White
When its time my wife will get our Audi A6 Allroad and ill get a GT86 /BRZ and probably get the Cosworth stage 3 to it.
Maybe a stupid question but….do i need the stage 1 and 2 before getting the stage 3 or can i just get the stage 3 and fit it in?
Swede is offline   Reply With Quote
Old 08-24-2015, 11:58 AM   #142
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by ajc209 View Post
The clutch will need an upgrade for anything more than 280HP i'd say.
What do you mean sit around 320hp but top out at 380hp? do you mean different 3.x stages?
http://www.topgear.com/car-news/modi...hp-toyota-gt86
That article mentions it. Though, I haven't heard anything else since. But since the other kits have a 1.x or 2.x I'd assume the 3.x would be a possibility.
MS, CSCS, TSAC-F, CPT
Old 08-24-2015, 11:59 AM   #143
weederr33
weederr33's Avatar
We don't quite know what Stage 3 is but if it's more power, I'd assume you'd need Stage 2.
Old 08-24-2015, 01:18 PM   #144
350matt
Drives: toyota mr2/ Toyota GT86
Perhaps Cosworth should explain why and how they have concluded the rods cant handle more than 280hp. It would show the quality of their R&D abilites and inspire confidence.
Cosworth could do a 310hp (+30hp) pulley kit but not recommended for heavy track use....
I wouldnt be surprised if the stage 2, 280hp was limited a bit to allow for a bit more step up in power for the stage 3.....
I think its time we saw the full 350+ HP stage 3 kit.
as I understand it they did an full FEA stress analysis on the rod and tested the rod material to provide a strength figure
the analysis tool then runs through a stress test and shows whats hot and whats not and you can predict ( reasonably accurately) when and where the part will fail
perhaps as you say a smaller pulley and shorter belt kit for trackdays only? I'd say any warranty would then go out the window though
350matt is offline   Reply With Quote
Old 08-24-2015, 03:58 PM   #145
weederr33
weederr33's Avatar
So you think it would be Rods and Pistons? Or just Rods and something else?
Old 08-24-2015, 04:49 PM   #146
Swede
Drives: White
I was thinking maybe stage 3 is all pre stages included, cause stage 2 is 1+ more if I'm right…
Old 08-24-2015, 05:34 PM   #147
350matt
depends on the ratio I suppose
typically with boost you need to drop the compression ratio down a bit as 12.5: 1 is a bit steep for a boosted engine
but I suppose you could just fit decent rods and keep the stock pistons as I'd say they're not too bad
Old 08-24-2015, 05:45 PM   #148
ajc209
Drives: GT86 Cosworth
Yes that the sort of thing I think cosworth should be talking about.
Regarding the smaller pulley on the stock block, I'd have thought not recomending it for track days would be best to avoid failures?
What guarantee are we talking about? I'm not aware of any in the uk at least or am I missing something?
ajc209 is offline   Reply With Quote
Old 08-24-2015, 08:36 PM   #149
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
What sort of difference in power would be seen between a UEL and EL header used for this setup?
I have a TOmei UEL, but I've heard that for Forced induction an EL Header is preferable. Although don't the EJ WRX's run UELs stock?
If someone could clarify this for me it would be great.
Also too lazy to search for an answer, but what's the max rear wheel HP that someone has achieved with this kit + full exhaust.
Wise is offline   Reply With Quote
Old 08-24-2015, 08:51 PM   #150
weederr33
weederr33's Avatar
SEARCH NOOB!
Just kidding. UEL is mostly for the torque, but you already get plenty with a PD supercharger. EL will help with mid or top end power. I feel that's more relevant for this application. Of course, if you think about it, Cosworth chose EL for a particular reason. If you already have Tomei headers, then you'll just get more gurgle and lower torque I suppose.
The Following User Says Thank You to weederr33 For This Useful Post:
Wise (08-24-2015)
Old 08-25-2015, 02:49 AM   #151
350matt
I don't think I've seen any different installations between UEL and EL on this charger - I only imagine its not much, 5 or 6 bhp at the top end - the shape of the torque curve will differ by more than this though
as for the max RWHP I think its 256 on 93 octane and the full exhaust
Old 08-26-2015, 08:43 AM   #152
philooo
Drives: 13' Scion FRS Track car
how come the cosworth supercharger is not offering more power ? I mean jackson racing is making 370hp with fuel pump and injectors ...
it is time for cosworth to wake up and offer a more aggressive setup.
philooo is offline   Reply With Quote
Old 08-26-2015, 08:51 AM   #153
ajc209
Thats true, but if they dont think the stock internals can reliably handle that power long term, they risk tarnishing their reputation if failures happen.
I suppose they could offer the stage 3 kit and a bottom end separately (recomending the bottom end for more power that stage 2) and let people decide if they want to risk more power on stock internals?
Old 08-26-2015, 12:34 PM   #154
350matt
agreed
get the pulley kit out there with a 'best of luck' and let people tune away, stock rods or not
I'd predict a bent stock rod or 2 are part of the learning process
MCA Blue coilovers - Now with first impressions and install pics!!!!!!!! Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 05-23-2016 08:18 PM
Cosworth Stage 2 Supercharger Install (Dyno,Tech,Photos,Videos) RallySport Direct Forced Induction 49 08-20-2015 07:32 AM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 10:10 AM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
Cosworth Stage 2 v86 Software Tuning 2 11-05-2014 07:47 PM
