Old 08-22-2015, 03:11 PM   #15
Pedal may have been just a tad too low in the first place. Also the length of throw with the stock hydraulics is abysmal. Until I fixed that, I was always misjudging the engagement and slipping the shit out of the clutch in second.
@civicdrivr is on point. I've also had chatter from a blown rear main seal. Got lucky that time. Cleaned up nicely and drove on the same clutch until I bought the FR-S.
civicdrivr (08-22-2015), yomny (08-22-2015)
Old 08-22-2015, 04:02 PM   #16
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Lets see how things play out. I've been driving today almost the whole day and it has behaved fine. Still does the shaking while taking off, at times, but this could be due to not enough gas given. I guess if things persist then i'd have to remove or have someone remove the tranny and double check anything.
Are these lightened flywheels something you could resurface? Thanks
Originally Posted by civicdrivr View Post
I've got the same clutch with the same problem. The flywheel is hot spotted, causing the clutch to skip as it engages.
Only way to fix it is to resurface or replace the flywheel.
Sent from my XT1095
How exactly do i about the heat spotting.. i honestly didn't slip the clutch, didn't drive over 3k and didn't boost until it was broken in.. not sure what else to do.. Thanks
Wheres this rear main seal? towards the end of the tranny or in by the input shaft? I got the clutch as a kit and came with new throw out bearing and another bearing, i think its the pilot.. goes in the flywheel. I've been reading around and it seems the shaking at take off could be hotspots as @civicdrivr mentioned.. sucks!! lol
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 08-22-2015, 04:28 PM   #17
It's around the crankshaft in front of the flywheel but it's not relevant. I only mentioned it to say it can all be fixed.
The flywheel can be resurfaced depending on the depth of the heat affected zone. Make sure you pick the shop carefully and ask them to pull as little as they can with each pass. Ask them to rebalance.
yomny (08-22-2015)
Old 08-22-2015, 05:12 PM   #18
yomny
yomny's Avatar
Thanks i really appreciate your suggestions. I will start doing some research as shops down here in miami are not so dedicated to the trade. I've had a really hard time finding anything that hasn't disappointed me. I look for shops with 86 experience but i guess id have to settle for anything that just has a good drivetrain reputation. If you guys find anything around the web id really appreciate it. Ive read suggestions on Tr3 performance. I'll see what i come across, thanks.
Old 08-22-2015, 05:15 PM   #19
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
You may be able to resurface the flywheel.
I'm not entirely sure how it happened in my case, but its created by too much heat. I drove to NY yesterday and sat in traffic for about two hours. Every start resulted in that annoying shudder, frustrating to say the least.
Sent from my XT1095
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-22-2015, 05:16 PM   #20
Nothing special about this flywheel. It's a straightforward job for any competent shop.
Old 08-22-2015, 06:07 PM   #21
yomny
yomny's Avatar
Sent from my XT1095
Yep that's what happens to me in this so great miami traffic. My fear is that the shudder eventually may damage either mounts or anything else. Just have to find a decent place.
Old 08-22-2015, 06:08 PM   #22
yomny
yomny's Avatar
Yeah I guess I'm just paranoid, the one time I took my car to a shop and well now I got this situation. Let's see if anyone locally could refer to a good place. Really appreciate your support man.
Old 08-22-2015, 06:27 PM   #23
Best wishes. Don't worry. It just takes some TLC and, with an accurate grind and balance, could come out better than new. Depends on the original manufacturing tolerance and/or installation surface prep.
civicdrivr (08-23-2015), yomny (08-22-2015)
Old 08-24-2015, 12:51 PM   #24
yomny
yomny's Avatar
One thing that strikes me as really odd which may turn out to not be as odd as I think is that all my problems seems to happen on really hot days after driving in the city for about 45 mins or more. My morning drives to work, normally about 30 mins or so still with some traffic, in about 86F weather, the car is perfectly normal, no shaking, no hard gears(which haven't been present since adjusting the pedal). Im sure there's an explanation and nothing to do with timed drives lol. What is it the heat affects that is causing this, oil, grease?
Old 08-24-2015, 12:57 PM   #25
fika84
fika84's Avatar
When I used to have a Clutchmasters stage 3, 4 puck sprung on a turbo civic it would get jittery when I was in stop and go traffic just because the friction disk would start to get more and more sticky as it got hotter and hotter. If I slipped it too much it would just grab and hold on (only happened once or twice).
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
yomny (08-24-2015)
Old 08-24-2015, 01:28 PM   #26
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
^ This.
The heat builds up in the clutch causing the judder.
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post:
yomny (08-24-2015)
Old 08-24-2015, 02:13 PM   #27
yomny
yomny's Avatar
Ahh ok well at least it seems to be common.
Old 08-24-2015, 07:39 PM   #28
Hmmm... That just doesn't seem right in any case. Sticky for real, or warping?
yomny (08-25-2015)
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Windows, Tranny, Clutch, Rattles Chalk Issues | Warranty | Recalls / TSB 7 06-30-2015 02:48 AM
Windows, Tranny/clutch, dealer issues. Help! Chalk Issues | Warranty | Recalls / TSB 9 02-15-2015 03:11 PM
Need your expertise(clutch and tranny) WatchmaN Issues | Warranty | Recalls / TSB 18 12-31-2014 08:32 AM
clutch issue yurgirlishot Issues | Warranty | Recalls / TSB 14 11-15-2013 04:20 PM
