Old 08-20-2015, 04:59 PM   #2647
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Go with the B6 shocks.
- Andrew
Piggybacking off this question -- currently running B6 with TRD springs, would the 2" Raceseng rear top mounts be too much added travel?
Asking purely for economical reasons (can pick up second hand set vs buying new 1" raceseng tops).
edit: b6 w/ trd springs, OEM rear LCA
asdf is offline   Reply With Quote
Old 08-21-2015, 09:19 AM   #2648
Well you wouldn't gain any travel, you'd just lower the car 2 inches.
Those top mounts are intended for coilovers primarily and I'm not sure I would run them on fixed perch struts (even the 1 inch drop tops).
- Andrew
Old 08-21-2015, 10:14 AM   #2649
8686
8686's Avatar
Drives: 86
- Andrew
Why do you prefer B6 over B8?
I got the B8 because I assume it suite the shorter spring better than B6! is this true?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 08-21-2015, 10:23 AM   #2650
All lowering springs are designed for OEM shocks and still stay captive in the OEM shocks, so there is no need for the B8 with shorter droop travel. There is no advantage.
The B8 probably has shorter internal bumpstops, but I have never opened them up to find out.
The valving is likely the same.
- Andrew
Old 08-21-2015, 11:38 AM   #2651
asdf
asdf's Avatar
Drives: #0517
- Andrew
I'm fairly certain that wouldn't be the case-- the spring seat and contact point at the top wouldn't move, only the "piston" part of the shock would be extended up 1 or 2 inches. @Raceseng has a kit that includes a spring perch for oem size springs
just wondering with the spring/shock loaded with the weight of the car, would there be enough travel to use the 2 inch tops? Could also keep them if I decide to switch to coil overs in the future as well...
http://www.raceseng.com/shock-top-re...u-brz-2013-719
Old 08-21-2015, 11:57 AM   #2652
OkieSnuffBox
Drives: '23 BRZ Limited
The point of the mounts is to get the car lower, so you leave more travel available in the coilover (which typically have less stroke than OEM-type dampers). IE, not adjusting the collar so low to get the desired ride height resulting in reduced travel/droop and typically smashing off the bump stops all the time ruining the ride/handling.
Old 08-21-2015, 12:05 PM   #2653
asdf
asdf's Avatar
Drives: #0517
Right-- I know that's the case, but when using lowering springs the stroke is reduced even when using bilsteins or konis since the shock body is the same (ie, you can use oem springs w the b6 shocks, so when using springs that lower the car 1 inch, you lose 1 inch of shock travel vs oem springs)... If I were buying new, I would definitely get the 1 inch tops to make up for the 1 inch drop, just wondering if there's enough stroke to use the 2 inch tops since there is a set for sale
Old 08-21-2015, 03:24 PM   #2654
Gotcha, I was thinking about fronts where the spring perch is separate from the upper mount.
Anyway, 2 inches of extra bump travel would almost certainly result in spring bind (meaning more shock bump travel than spring travel) and that would be my first concern. One inch might do it too but I'm not sure.
- Andrew
Old 08-24-2015, 07:12 PM   #2655
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Originally Posted by Norkoastal View Post
Thinking of swapping a few parts out when the rear SPL LCA's go in. Currently on Tein Street Flexes dropped to Tein spec.
SPL Titanium Rear Traction Arms FR-S/BRZ
SPL TITANIUM Rear Toe Arms FR-S/BRZ/WRX
SPL PRO Rear Endlinks FR-S/BRZ/WRX
Thanks!
Bump it up!
CO>CA Cartel
Norkoastal is offline   Reply With Quote
Old 08-24-2015, 10:25 PM   #2656
Bump it up!
Not really. Make sure the bearings are protected from grime and dirt otherwise they'll wear out and start making noise.
Old 08-24-2015, 11:08 PM   #2657
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
I'm going to be investing in the full TOM's brace set(minus the rear bumper replacement), how much will this influence daily driving experiences and feeling? I know it'll become much stiffer, but I'm wondering if it would become too much for a comfortable drive here and there. As for track days and hard corners, would it provide more balance with sharper cornering precision? Reviews haven't really helped explain this.
megamarines is offline   Reply With Quote
Old 08-26-2015, 10:57 AM   #2658
Just bracing? It won't make too much difference.
- Andrew
Old 08-27-2015, 09:52 PM   #2659
djliquidsteele
Drives: Scion FR-S
SO I installed the Tein Flex Z's last weekend and think I have settled on 5 clicks out in the front and 6 clicks out on the rear. It seems to feel like the car settles in about the same time from to rear.
In my previous setup I was on stock dampers with RCE Yellows. I also have RCE sways bars front and rear. I feel like could oversteer a little easier before which isn't necessarily the best, but now I feel like I'm getting a bit of understeer.
So, my question is, would setting the rear sway bar stiffer or increasing the damping take out understeer better?
djliquidsteele is offline   Reply With Quote
Old 08-28-2015, 02:32 AM   #2660
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
More rear sway bare or less front. It's the most important setting for understeer vs oversteer.
Damping setting is second order vs sway bare.
If you just want to change corner entry oversteer, you may want more rear damping and less front.
Damping setting will change oversteer/understeer balance when mass transfer is occurring.
When in cornering stady state, it won't change much.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
