Old 08-19-2015, 06:57 PM   #15
dtrop
Drives: Wrb 2014 limited brZ
You made the mature decision not to buy something you currently can't afford, but I would look to purchasing something that fits your lifestyle more so than your desires in a car.
You should be looking for an economy car with great gas mileage. 25,000 is quite a bit of miles for one year and saving on fuel will help you build savings to maybe one day buying a more desirable car.
with your budget, you could get a barely used civic achieving 40 mpg while having decent storage space. It won't be a desirable car for you, but you'll save good money at the pump.
I can't think of any RWD car in your price range that will give you the same feel as BRZ/FRS AND with GOOD reliability while having good storage space. Now if you wanted to take out reliability......rx8, mini cooper
maybe consider a Veloster?
Maybe consider where you will be or where you hope to be financially in 3-4 years and then maybe consider getting a twin.
*I personally also would hate to see 25,000 be racked up every year on a little sports car (even though some members here already do).
dtrop is offline   Reply With Quote
Old 08-19-2015, 06:58 PM   #16
dtrop
Originally Posted by DAEMANO View Post
That's the hard point to stomach about the 86. There simply are no lightweight RWD 2+2s for anywhere near the price. Everything RWD and cheap is either a piggish GT or a 2 seat roadster.
So I'd say give a Fiat 500 Abarth a good look.
Not RWD, but FUN and tunable with OpenFlashTablet for $500 to have very nice power (180 WHP/ 207WTQ) for a 2500 lb car. Lots of room for its' size. Good fuel mileage. Gorgeous exhaust sound from the factory. Chuckable. Huge aftermarket. $15k will get you a decent used 2012 - 2013 one all day. Great owner's community and IMO it's more interesting than a Fiesta ST.
I've put merchandise in a customers Fiat before.....sorry, but there is simply not enough storage space, especially for someone specifically looking for a decent amount.
Old 08-19-2015, 07:05 PM   #17
DAEMANO
Time Traveller
Wrong.
I own an Abarth and have moved all kinds of large items in mine. Including music instruments, furniture, and audio gear that wouldn't fit in my FR-S. The car is taller than it looks inside and that's where you find the space. If an FR-S was big enough for the OP, than an Abarth would be easily.
One bike, two cars... which one fits better? Which car has more space left over?
The Following User Says Thank You to DAEMANO For This Useful Post:
NWFRS (08-19-2015)
Old 08-19-2015, 07:05 PM   #18
Brndn704
Brndn704's Avatar
Originally Posted by juliog View Post
Miata. If buying new, the NC (3rd gen) is being replaced by the ND, and dealerships are giving them away.
Or just buy a used NA/NB/NC.
I wouldn't recommend a S2000 with a 15K budget. Mileage is pretty bad (20MPG) and any example under $20K will need work.
lol wut?
http://www.autotrader.com/cars-for-s...99808119&Log=0
http://www.autotrader.com/cars-for-s...05980396&Log=0
Thats just a quick search on Autotrader. There are plenty of them out there. Low mileage, no accidents, clean. Just got to look. It won't just pop up and slap you in the face.
The FRS doesn't get that much better gas mileage...
Brndn704 is offline   Reply With Quote
Old 08-19-2015, 07:07 PM   #19
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
http://www.ft86club.com/forums/showthread.php?t=54356
My money would have been towards an RX-8 in all likelihood.
Another vote for checking out Hot Hatches, FWD cars can handle really well if you've got the skills to back it up. I saw a Mini Cooper run an AutoX about 0.5 seconds slower than a full up 911 GT2 last weekend.
Edit: I'd be wary of a $15k S2k, whenever I look they need several hundred dollars (if not thousands if replacing the top) of parts and inspection before I'd trust them to run at 10/10ths, RX-8 isn't any better but there's a lot more headroom in your budget.
ineedyourdiddly
Old 08-19-2015, 07:09 PM   #20
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
FWD=civic si-Most reliable
RWD=Rx8, g35, gti
AWD=WRX, impreza, 3series
BlackJesus is offline   Reply With Quote
Old 08-19-2015, 07:10 PM   #21
Pickleahoy
Drives: 10 Series #1617
The man is saying he drives 25k a year, needs something highly reliable and you all are suggesting an RX-8? Is this opposite land?
For 15k just get an S2000
Pickleahoy is offline   Reply With Quote
The Following 3 Users Say Thank You to Pickleahoy For This Useful Post:
FIRST! (08-25-2015), LSxJunkie (08-28-2015), NWFRS (08-19-2015)
Old 08-19-2015, 07:13 PM   #22
Brndn704
Brndn704's Avatar
Sure, if you want to replace the engine, have to rev to high RPM's everyday, not being able to just crank the car up and back it out and shut it off without flooding the engine; get an RX8.
Old 08-19-2015, 07:13 PM   #23
mikool
mikool's Avatar
Drives: 14' Firestorm FR-S
Are you not able to finance a car? or 15k is your finance budget?
I don't see why you wouldn't be able to put 15k down on a brand new 86.
mikool is offline   Reply With Quote
Old 08-19-2015, 07:16 PM   #24
juliog
juliog's Avatar
Drives: 86
Originally Posted by Brndn704 View Post
lol wut?
I own both, and I stand by my opinion. Common stuff:
Soft top tears
Worn clutch
Broken engine mounts
Worn tires
Fluids
Worn brake pads
Spark plugs
Valves clearances out of adjustment (need valve adjustment)
Suspension out of alignment, accelerating tire wear and impacting handling
Car untuned (or worse, running a bad tune) for aftermarket boltons
What I'm saying is, if you buy a $15K S2K, budget for a few thousands more to fix stuff soon after purchase. If your *total* budget is $15K, don't buy one. But that really should go for any used car, specially sports cars.
And while commuting I get 30MPG on my FR-S, and 20MPG on my 07 AP2.
juliog is offline   Reply With Quote
The Following 2 Users Say Thank You to juliog For This Useful Post:
DAEMANO (08-19-2015), strat61caster (08-19-2015)
Old 08-19-2015, 07:22 PM   #25
DannyQ86
Drives: 2013 frs
Why the fuck would you replace the engine? Revving to 9k is part of the fun. Have you ever driven an s2k..?
Wait, after re reading I think you are talking about the pos rx8 lol my bad
DannyQ86 is offline   Reply With Quote
Old 08-19-2015, 07:23 PM   #26
e1_griego
e1_griego's Avatar
Drives: Many
Focus ST? not rwd, small, whatever. But tons of room and they're fun to drive.
e1_griego is online now   Reply With Quote
Old 08-19-2015, 07:24 PM   #27
DAEMANO
Time Traveller
lol wut?
Old 08-19-2015, 07:24 PM   #28
DarkSunrise
DarkSunrise's Avatar
1 yo used Fiesta ST. It's not RWD, but supposedly a very fun car with decent cargo space for your gear. Also gets good gas mileage.
New they're going for ~$17k, so you should be able to get a lightly used one in the $15k range.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
juliog (08-19-2015)
I never realized just how loud my fuel pump was... Basket Case Scion FR-S / Toyota 86 GT86 General Forum 20 01-17-2014 02:22 PM
Just realized something else that makes me smile... CircuitJerk Scion FR-S / Toyota 86 GT86 General Forum 14 08-04-2012 11:35 PM
I just realized something... Draco-REX Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 10:48 PM
