| Member's Car Journals Car journals by our members. |
#15 |
too much is never enough.
Drives: 2015 FR-S RS1.0, 2005 Corolla XRS
I've done that on all my cars, my 05 Corolla has 365,000 on it and the conderser looks practically new.
Too much is never enough.......
2016 Colorado Z71 Trailboss, 2005 Corolla XRS, 1987 Cavalier RS Wagon ![]() Nanako's Mod Thread |
#16 |
Drives: 2013 frs
Nice man! Is that the mustang 3rd brake light you are going to use to replace the oem one?
#17 |
Drives: Moped
The black wheels are going to look killer...can't wait
#18 |
The rest of the story
Didn't have a chance to post the progress over the last few days, so here is stuff that was done.
Echomaster Backup Camera - Done Gentex Auto-Dimming Mirror with Homelink Compass & Temp - Done Rear Fog Light - 1/2 Done INTEC 3rd Brake Light Relocate - Done TRD Aero Stabilizing Trunk Cover - Done Custom 8 Ball Shift Knob - Done Toyota Front Arm Rest - Done Apply Clear Paint Protection film to the lower door panels, sil plates and a few other places - Done Custom Decepticon Emblems - Done TRD Rims 18x7.5 Square - Done Michelin Pilot Super Sports Tires 245/35 ZR18 - Done Destroy Seat Belt Chime - Done Items to install at a later date: Rear Window Spoiler Rear Arm Rest Courtesy lights in doors Custom Ghost Lights in doors Echomaster Backup Camera ![]() Follow indentation on the left side for where to drill the hole for the camera ![]() Drill and moun the camera (sorry no pic) Mount the trunk garnish and run your wires to the back of the radio (I included the wire for the rear fog light in my run to the front) ![]() ![]() ![]() ![]() Head Unit Wiring ![]() You must add a pin into slot 2 of the 28 Pin connector on the back of the radio and wire it to the reverse light circuit, IP J/B Connector 3D Pin 4, to kick on the monitor. The wires for the back-up camera get hooked up to Acc and Ground. I used the Blk/Lt Blue wire in pin 7 for Ground and Red pin 3 for Acc (connector is below the one on the left) ![]() IP J/B Wiring ![]() Plug in the connector they give you that has the Video plug ![]() Assemble, turn Acc on and put in reverse to test Success! ![]() Gentex Auto-Dimming Mirror with Homelink Compass & Temp Adaper install Best to use blue lock-tite on all 3 screws so they done vibrate loose ![]() Mount the mirror and wire. Connector for ACC power and Ground is near the light in the headliner, reach up and to the right and you should get it. Its a three pin connecctor, wrapped in grey foam, 2 pins are ground ,1 pin ACC. Wire up the ground to the middle ground wire and the red and yellow to the ACC wire ![]() ![]() Rear Fog Light Have this half done, still have to do the LED in the cluster and wating for my pulse latching relay ![]() ![]() Test ![]() INTEC 3rd Brake Light Relocate Pretty simple and straight forward ![]() Remove rear deck, and grind off plactic welds to remove the factory 3rd brake light, then put on the supplied felt covers ![]() ![]() Clean the top inside of the window thoroughly, (if you have some adhesive promoter, you can put in on where the 2 sided tape will attach to the window) Pull out the plastic plug in the roof, line it up and peel off the 2 sided tape and stick. Run your wire down the pass side c pilar and under the rear deck to the 3rd brake light connector. ![]() ![]() ![]() Done ![]() TRD Aero Stabilizing Trunk Cover Glad I can read pretty pictures! lol instructions in Japanese! Not that hard to install, really like how it looks on the car!! ![]() ![]() ![]() Custom 8 Ball Shift Knob A tradition that has been done to every manual trans car I have owned Drill and Tap the ball ![]() Give the shifter a half inch hair cut, and re-cut the threads ![]() Rollin ![]() Front Arm Rest Got so involved in it that I didn't take any pics ![]() finished pics in next post!!! Laterz! ![]()
| The Following User Says Thank You to Crashdummy For This Useful Post: | new2subaru (02-28-2016) |
#19 |
No, its the INTEC one through FT-86 Speedfactory
#20 |
Yes they are
#21 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Love it!
| The Following User Says Thank You to Packofcrows For This Useful Post: | Crashdummy (08-19-2015) |
#22 |
Finished pics
Here are the finished pics as she sits right now.
I have a few more things that need to be done, I just dont have the parts yet or the time right now. Nanako........ ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now to put some miles on her! ![]()
| The Following 2 Users Say Thank You to Crashdummy For This Useful Post: | MemphisR (08-24-2015), new2subaru (04-07-2018) |
#23 |
Finally had some time to get a few more things done!
Rear Arm Rest Courtesy light in doors Custom Ghost Lights in doors Red Floor Lights All the stuff laid out ![]() Rear Arm Rest Pretty simple! remove seat and unbolt the 2 10mm bolts for the console and pull out the arm rest ![]() The factory glue was not holding so I re-glued it ![]() Installed ![]() Courtesy Lights and Ghost lights B+ and Ground ran through door boot ![]() ![]() Courtesy Lights and Ghost Lights mounted and wired in the door panels ![]() ![]() Red LED floor lights for front and rear foot wells Put a few coats of VHT Nightshades to knock down the brightness ![]() ![]() Since there was nowhere to mount them, I made custom brackets for them Front Drivers From the Fuse box to the OBDII support bracket ![]() Pass Front JB Welded this one to the 2 flat spots on the blower assembly ![]() Drivers and Pass Rear Mounted both to the flap that runs down from the backrest to under the seat, zip ties do the trick. Then ran the wire along with the factory harness. ![]() Finished! The set up: Each side is wired to the factory door switch at the BCM and diode isolated Drivers door opens - Ghost lights, Courtesy light come on there side only, all floor lights on Passenger door opens - Ghost lights, Courtesy light come on there side only, all floor lights on Park lights - All Floor lights come on ![]() ![]() ![]() More things in the works....................soon! laterz
2016 Colorado Z71 Trailboss, 2005 Corolla XRS, 1987 Cavalier RS Wagon ![]() Nanako's Mod Thread Last edited by Crashdummy; 09-29-2015 at 08:28 PM. |
#24 |
Drives: 2013 Raven FRS
some interesting things you're doing! keep it up!
| The Following User Says Thank You to fatpwr For This Useful Post: | Crashdummy (10-22-2015) |
#25 |
Space for Rent
Drives: 2014 6MT ToyoBaru86ScionMonogram?
| The Following User Says Thank You to 1GiantTurtle For This Useful Post: | Crashdummy (10-22-2015) |
#26 |
Your posts were what started me on the road to getting it done. Just havent had the time to finish hooking up the relay board yet, everything else is set to go.
| The Following User Says Thank You to Crashdummy For This Useful Post: | 1GiantTurtle (10-23-2015) |
#27 |
Space for Rent
where did you get the Courtesy light from?
#28 |
A Demon
Drives: Raven GT86
| Fr-s release series 1.0 Q&A | Ankit | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 12-30-2015 06:15 PM |
| FS: DRL Mod for Monogram/10-Series/Release Series 1.0 | leoh007 | Exterior Parts (Aero, Lighting, Etc.) | 0 | 05-12-2015 12:15 PM |
| FS: DRL Mod for Monogram/10-Series/Release Series 1.0 | leoh007 | Audio/Visual, Electronics, Infotainment, NAV | 0 | 05-12-2015 12:14 PM |
| Release series | MemphisR | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 07-11-2013 07:58 PM |
| Release Series | rL-gT | Scion FR-S / Toyota 86 GT86 General Forum | 55 | 01-18-2012 02:02 PM |
