Old 08-18-2015, 03:32 PM   #295
CSG Mike
CSG Mike's Avatar
Please let me know if I'm not making sense; this isn't the normal type of discussion I usually post online. It's usually more geared toward engineers.
Old 08-18-2015, 04:41 PM   #296
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
It's perfectly clear and easily understandable. It's nice to have you sharing important informations like this. That's the kind of posts I hope (and fail) to find most of the time.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 08-18-2015, 06:11 PM   #297
Calum
That Guy
Drives: 2013 asphalt FRS MT
That "close to MBT" balance gets pusedh back toward the direction of retarded timing advance when you add boost into the mix. Being able to go beyond MBT gives you a significant amount of overhead as in-cylinder IAT climbs with boost.
If you're doing a cost benefit analysis, how's this:
Tomei header + FF kit + FF tune
vs
Ace header + 91 tune
The Ace still makes more power, if the front pipe is in place....
The dyno's Ace posted showed some loss in the mid range when use their front pipe with the 4-2-1 compared to just the 4-2-1 and the OEM front pipe. Have your tests shown a similar loss?
Old 08-18-2015, 06:16 PM   #298
CSG David
CSG David's Avatar
The disclaimer is they're using an off the shelf Stage 2 tune from Delicious Tuning meant for a different header. In other words, their dynos showed what would happen with the ACE header when using a tune meant for a different header.
Old 08-18-2015, 07:56 PM   #299
Calum
That Guy
Thanks David. I was aware of them using a tune for a different header. Just for clarity, can you confirm that the loss doesn't exist with a proper tune?
Edit, I just reread the first post. Nevermind.
Old 08-18-2015, 08:10 PM   #300
CSG David
CSG David's Avatar
We actually thought we were going to get some dip in power. To our surprise, the power is absolutely linear with no dips. The front pipe added a substantial amount of power in the NA configuration which was actually more of a surprise to us since generally front pipes yield a mild gain. Response is substantial and power is very different from the other systems we've played with.
Old 08-18-2015, 08:30 PM   #301
Calum
That Guy
That's awesome. Thanks. Any chance you have a dyno showing this, please?
Also, are you guys moving toward offering e tunes for this setup? Or do you have any specific tuners you would recommend?
Old 08-18-2015, 08:34 PM   #302
steve99
Drives: FT86
Copy pasta from another thread.
E85's big advantage is that it allows for the majority of the inefficiencies of many headers to be masked. E85 is proven to add a solid 35whp to an otherwise stock car with tune, but on the Ace, it's worth 12-15whp at best, NA.
totally agree
with E85 we see virtually same gains from cheap headers like these (that look like they were designed on Friday afternoon over a few beers and welded by people who have never seen a welder before) or high end headers
http://www.ebay.com.au/itm/TOYOTA-86...-/151383079811
the one thing we have here is good E85 (our petrol is crap worse than your 91)
Guaranteed E85 at 85% ethanol and 107 octane available at the pump.
Old 08-18-2015, 08:49 PM   #303
djliquidsteele
Drives: Scion FR-S
So what I'm hearing is I can STILL make more power with E85.
djliquidsteele is offline   Reply With Quote
Old 08-18-2015, 11:41 PM   #304
CSG Mike
CSG Mike's Avatar
See the second post in this thread
Note that the "dip" is a phantom dip, from additional tuning done to maximize the potential of the chambered front pipe. We can place the dip precisely within the 2500-4500 RPM window, by altering ramp time; in other words, it is an artifact, and not actually there.
Old 08-19-2015, 01:18 AM   #305
churchx
churchx's Avatar
Drives: 2014 GT86
Or in other words normal customers with normal front pipes with normal tunes for this header wishing linear delivery won't have dip in low rpm-s more common @ daily driving / cruising.
I still wonder how Ace managed to got all three checkboxes checked, top power, middle rpm power, dip elimination, when most of other had to choose between. Especially Nameless, whose EL also has long runner lengths, just shaped different way.
Old 08-19-2015, 01:50 AM   #306
CSG Mike
CSG Mike's Avatar
Well, considering their primary market is Porsche and oldschool VWs....
Old 08-19-2015, 05:08 AM   #307
Calum
That Guy
Damn, how the hell did I miss that?
Thanks!
Old 08-19-2015, 07:13 PM   #308
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We've just gotten an Ace 4-2-1 on our shop BRZ, and will be doing some dyno testing tomorrow to see what we can pull out of it. Initial impressions are quite good!
Sincerely,
Zach
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
