Old 08-18-2015, 12:24 PM   #85
CSG Mike
CSG Mike's Avatar
How much preload are you running?
I'm guess you have JDM spec Flex Z, as the USDM spec has only been on the market for about 2 weeks now? Japanese roads are exceptionally well maintain from what I understand (I have no firsthand experience, so can only relay what I've heard)
Old 08-18-2015, 01:06 PM   #86
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Thank's mike for your answer.
Like I said I use the USA spec as mention in the manual
Front
A= 92mm/3.6"
B=28mm/1.1"
C=170mm/6.7"
D=106mm/4.2"
Rear
A=115mm/4.5"
B=35mm/1.4"
C=244mm/9.6"
D=164mm/6.5"
What are the serial number of USA flexZ?
Am I right to increase pre load to get car higher with more travel like I would do on my KW V3 and H&R from my other car ( those don't have independent high adjustment).
Because if I only adjust the ride height I will not get more travel just more high car so still hit the bump stop isn't it?
Mars2 is offline   Reply With Quote
Old 08-18-2015, 01:09 PM   #87
CSG Mike
CSG Mike's Avatar
Front
A= 92mm/3.6"
B=28mm/1.1"
C=170mm/6.7"
D=106mm/4.2"
Rear
A=115mm/4.5"
B=35mm/1.4"
C=244mm/9.6"
D=164mm/6.5"
More preload = less compression/bump travel before hitting the bump stop.
I recommend running with minimum preload.
I did not run into issues with bottoming out and believe me, Los Angeles roads are BAD.
Old 08-18-2015, 01:17 PM   #88
Mars2
How do you manage not touching the under tray and exhaust of the car when drop more than 1"? I touch every wear. only on smooth flat road is ok.
When I said flat I mean from right to left side of road. B road are often convex here.
Old 08-18-2015, 01:23 PM   #89
CSG Mike
CSG Mike's Avatar
Minimum preload, proper damper setting.
Have you tried adjusting your dampers?
Old 08-18-2015, 01:24 PM   #90
Mars2
Yes I try adjusting my damper and the best I found was 7 front and 5 back. 7 front to have more weight transfer and more dampening and 5 back because any thing more and I bottom all the time.
so I will try the GT86 setting from FlexZ manual. As BRZ setting are very close to USA setting:
Front
A=100mm/3.9"
B= 32mm/1.2"
C= 178mm/7"
D= 110mm/4.3"
Rear
A=130mm/5.1
B=52mm/2"
C=259mm/10.2"
D=181mm/7.1"
SO 4mm less preload in front and 3mm less preload at back than USA setting
then adjust ride hight 5mm higher on the back. as this set up is supposed to be 10mm higher front and back than USA setting.
Old 08-18-2015, 01:36 PM   #91
CSG Mike
CSG Mike's Avatar
Front
A=100mm/3.9"
B= 32mm/1.2"
C= 178mm/7"
D= 110mm/4.3"
Rear
A=130mm/5.1
B=52mm/2"
C=259mm/10.2"
D=181mm/7.1"
I don't understand why you're so stuck on the USA default settings, when you're using JDM dampers. Try the recommended drop, but with minimum preload (only enough to hold the spring in place, but loose enough that you can rotate the spring.).
Is that 7/5 from maximum or minimum damping?
Old 08-18-2015, 01:40 PM   #92
Mars2
It's 7 and 5 from maximum. stiffest. or to the left, unscerw.
Because I do not believe they would produce totally different shock unless I see that serial number are different. then I will see that I did a mistake. But no body can give me USA serial number.
Thank's for all your time I really appreciate.
Old 08-18-2015, 01:48 PM   #93
churchx
churchx's Avatar
Drives: 2014 GT86
Try scrolling back page or two in thread where pics were posted. IIRC there were some numbers in them on plates over coilovers.
Old 08-18-2015, 03:14 PM   #94
tracerit
Drives: '13 SSM BRZ Limited 6MT
I called West End Alignment for install and alignment and they want to do everything in one day. I hope I didn't insult the guy but I was taken aback since I thought alignments should be done after the car has been driven a bit to let things settle. But that's my experience with springs, are coilovers different? :/
tracerit is offline   Reply With Quote
Old 08-18-2015, 03:20 PM   #95
93Targa
Brown rice
93Targa's Avatar
Drives: 93' Supra TT, 13' FRS
I do the same. Install, let the suspension settle for a week or two than perform an alignment.
93Targa is offline   Reply With Quote
Old 08-18-2015, 04:00 PM   #96
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I highly trust Darin and Chris over at West End for what it's worth. If you haven't been there before I do not think you will regret it after the appointment.
2much is offline   Reply With Quote
Old 08-18-2015, 04:52 PM   #97
CSG Mike
CSG Mike's Avatar
I'd recommend you try adding more damping for spirited drives; that's a very soft setting.
Old 08-18-2015, 04:53 PM   #98
CSG Mike
CSG Mike's Avatar
The Flex Z do not settle much, if at all.
If you really want, you can always set two appointments, one for install, and one more after to align. But, knowing Darin and Chris, they're not gonna allow you to walk out with "just an install" because your alignment will absolutely be off with just an install, and they don't let sub-par/unfinished work out of their shop.
Tein Flex A DeaconRoc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 138 04-12-2018 05:23 AM
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Street flex JM'sFR-S562 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-09-2015 11:04 AM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
