CANADA Canada
Old 08-05-2015, 11:13 PM   #2801
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
. Custom Hand turned on a conventional lathe with 15 degree facets to replicate a sphere
. Diameter is 1.975" (cut from 2" brass rod stock) and 2.75" tall
. Weight 500+ Grams
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 08-06-2015, 12:47 PM   #2802
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
That is super cool! Unique for sure
I feel like I should drive to Moose Jaw this weekend
The Following User Says Thank You to SkAsphalt For This Useful Post:
JPxM0Dz (08-06-2015)
Old 08-06-2015, 01:42 PM   #2803
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
A few shots of the lights. Pics don't due them justice.
2URGSE
The Following User Says Thank You to JPxM0Dz For This Useful Post:
SkAsphalt (08-06-2015)
Old 08-06-2015, 05:29 PM   #2804
Jcl
Drives: 2014 BRZ
Anyone interested in rexspeed heated mirrors? Will be driving through swift current and saskatoon. 😃
Jcl is offline   Reply With Quote
Old 08-07-2015, 08:57 PM   #2805
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
2URGSE
SkAsphalt (08-07-2015)
Old 08-08-2015, 03:48 PM   #2806
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Yay toms!
JPxM0Dz (08-09-2015)
Old 08-10-2015, 11:42 PM   #2807
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Grimmspeed intake sold. Mishimoto on route
2URGSE
Old 08-11-2015, 05:01 PM   #2808
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
HKS intake duct installed with no front bumper removal
2URGSE
SkAsphalt (08-14-2015)
Old 08-13-2015, 10:43 AM   #2809
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Lighting Demo
[ame="https://www.youtube.com/watch?v=ERr7n3bh-Wg"]BRZ Lighting Demo - YouTube[/ame]
2URGSE
Old 08-14-2015, 06:03 PM   #2810
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Atta boy JP, way to fit that in there!
JPxM0Dz (08-17-2015)
Old 08-17-2015, 12:43 PM   #2811
Avi0304
Drives: Brz
brz vs snow
hey guys
am planning to get the 2016 brz but it will be my dd. how is this thing on ice and snow with good snow tires and additional weight in the trunk? has anyone driven this car in our winter? pls advice. much appreciated
thanks
Avi0304 is offline   Reply With Quote
Old 08-18-2015, 02:38 PM   #2812
MrJesse
MrJesse's Avatar
Drives: SWP BRZ
Originally Posted by Avi0304 View Post
hey guys
thanks
This will be my 3rd winter with my BRZ. The car gets around fine in the winter. You'll be fine with studded or studless winter tires regardless of whichever you choose. The biggest problem is starting from a stop. You will have to go very easy on the gas or else your rear end will slide out. Some weight in the back will help with this tremendously. Just don't put too much weight or the rear will swing out whenever you make a turn.
MrJesse is offline   Reply With Quote
Old 08-18-2015, 03:02 PM   #2813
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
^^ exactly this.
I would be light on the wait, maybe one or two bags of salt. ensure you have winter tires (Studs certainly help) and...can this car start in second? That was my trick for getting moving in my mustang GT..no idea if the FRS has the torque for it though (I do not drive mine in winter)
Old 08-18-2015, 06:18 PM   #2814
R2
Originally Posted by SkAsphalt View Post
^^ exactly this.
I always found myself using 2nd gear because the 1-2 shift is usually impossible when the transmission is cold. Also, yes, there enough torque to get going in 2nd, more than enough for frosty pavement let alone ice and snow. Plus, you're already in the right gear for hooning around with then.
Regarding the weight in the trunk question, I found a bit of weight helps (~80lbs is what I used) but only in the scenario when you are on sheer ice at an intersection and pointing uphill (RWD's Achilles heel), and then only slightly. I didn't bother last winter and it didn't hold me back. I found that once you get a bit of acceleration the weight transfer allows more acceleration, etc. With this you'll find that after the first ten feet from an icy intersection you will be able to out accelerate almost all FWD vehicles - the same weight transfer hurts them.
In my experience the key to winter driving in this car is 2nd gear, keep the wheel slip to a minimum, and traction/stability control OFF. Also key is top tier winter tires, don't cheap out on these. This will be my fourth winter in the car and I'm looking forward to it.
R2 is offline   Reply With Quote
EDM Thread!! Synack Off-Topic Lounge [WARNING: NO POLITICS] 194 12-13-2013 12:18 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Not another BRZ vs WRX thread... stayclam BRZ First-Gen (2012+) — General Topics 5 02-28-2012 02:58 PM
