Old 08-16-2015, 10:33 PM   #141
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
So you're measuring from to top of the boot?
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 08-16-2015, 10:55 PM   #142
93Targa
Brown rice
93Targa's Avatar
Drives: 93' Supra TT, 13' FRS
The bumpstop is under the boot. If you feel for it, you can tell where the bumpstop ends and top of the absorber begins. That's where I measured from.
Again, my first time installing as well but I did get the measurements from the booklet to match up.
93Targa is offline   Reply With Quote
Old 08-16-2015, 10:59 PM   #143
Bramick
Bramick's Avatar
Ok gotacha. You're measure from the bottom of the bump stop. I was measuring from the top
Old 08-17-2015, 12:24 PM   #144
jawnthen
Drives: 2013 BRZ Limited 6AT
Post installation impressions
A little bit of background, I've had the car for 8 months. The suspension stayed stock for 1 before I had Swift Spec-R springs installed on the stock shocks. I really can't remember all the details of how this car drove stock so my comparison will be based on using aftermarket springs on stock shocks vs these guys. This is my DD and I do a 15 min fwy drive on a really crappy road with tons of bumps and height elevation changes. I also carpool with my wife a couple times out of the week. The performance of the Swift SpecR/stock damper was good for spirited driving on fairly smooth roads and very responsive. I haven't made it out to the track yet, though. On rougher roads, the springs were too much for the shocks and sometimes I would get launched from my seat. The first few days coffee was spilled until I learned to slow down on those bumps. The wife hated it.
The FlexZ are set to the default recommend 7F/8R. Coming from the Swift Spec-R/stock damper combo, the difference is night and day in terms of comfort.
We drove this morning and instantly the wife approved. Minor bumps on the road was no longer jarring and more importantly no coffee spilled. Now that big bump that would launch me off my seat, today I ran through it without any drama whatsoever. There was an audible thud, but my butt stayed planted and the car just ate it up like morning breakfast. With all this comfort, the car doesn't feel sloppy at all. There's a hint of lag when I quickly change lanes but that's being picky. The last thing I tried before heading into work was a couple on/off ramps that are long and sweeping. I especially wanted to try the one I take when I leave work. It sweeps left about 160 degrees and then turns right about 30 degrees before merging with the fwy. It descending with a bump just after the apex of the first turn. I usually take it at 60mph and if I'm on the outside when I go over the bump, the traction control light comes on. That was with the Swifts. This morning I peeked and was doing 62mph, went over the bump, no TC light. The car felt planted the whole time.
So I couldn't be any happier with the switch to the FlexZ. If I had stayed with the Swifts, I was eventually going to find a proper damper to mate up with it but for the price of a good damper, I could get these. As far as comfort on a daily basis I'm happy with the default settings. I'll fiddle around with the settings and see what "lexus/boat mode" is like according to @CSGMike; I used to drive a lexus boat before this, so I can make an educated comparison. As far as performance, there seems to be enough clicks towards stiff I can play with to dial in performance for that track day that I will eventually get out to. Did it live up to the hype? Time will tell. I post more once I've tried other settings. As far as quality, I ran Tein coilovers on my Lexus for over 10 years without any issues.
jawnthen is offline   Reply With Quote
The Following 14 Users Say Thank You to jawnthen For This Useful Post:
93Targa (08-17-2015), akyp (08-19-2015), AlexL (08-18-2015), andrewFT86 (06-07-2016), Bramick (08-17-2015), Crazypinoy9 (08-19-2015), CSG David (08-19-2015), CSG Mike (08-19-2015), drewbot (08-17-2015), GT86_PRAGUE (08-20-2015), Kris86 (09-13-2016), mit_peid (08-18-2015), the new guy (08-17-2015), tracerit (08-17-2015)
Old 08-19-2015, 06:01 PM   #145
Crazypinoy9
Drives: FR-S TRD RS1#1488
100% agree with this review. I've only had my set on for 1.5 days but the drive comfort on these are awesome. I have them set right now to the stiffest setting and they fantastic. The only issue I had was of my own fault. Didn't think about getting new endlinks (shorter ones). So I had to get a pair or RSR end links from someone to lower the car as much as i wanted otherwise it wouldve hit the LCA.
But other than that I couldn't be any happier with the Flex Z's. time will tell if they hold up or not but for now I'm very happy.
Crazypinoy9 is offline   Reply With Quote
The Following User Says Thank You to Crazypinoy9 For This Useful Post:
Old 08-19-2015, 07:25 PM   #146
CSG David
CSG David's Avatar
Glad to see you guys put them to good use already.
The Following User Says Thank You to CSG David For This Useful Post:
Old 08-19-2015, 08:46 PM   #147
Crazypinoy9
Yup! Mike really came through for me on getting them shipped out fast. i was scheduled to get other stuff installed on the car so his quick help really saved me from having to go back to the shop more than once.
Old 08-19-2015, 09:16 PM   #148
djliquidsteele
Drives: Scion FR-S
So curious, are end links a necessity with 1-1.5" drop?
djliquidsteele is offline   Reply With Quote
Old 08-19-2015, 09:33 PM   #149
jawnthen
I'm pretty sure I went lower than my old setup (~1") and didn't need end links. I have SPL LCAs if that makes any difference...
The Following User Says Thank You to jawnthen For This Useful Post:
djliquidsteele (08-19-2015)
Old 08-19-2015, 09:43 PM   #150
djliquidsteele
Drives: Scion FR-S
Good to know. I am currently on RaceComp yellows so ~20mm drop and only want to go about 30-35mm drop. I also ordered the SPL arms so great comparison. Everything goes on Saturday. Thanks!
Old 08-19-2015, 10:15 PM   #151
Crazypinoy9
My arms are stock which is probably the difference. If i wouldve stayed with the stock end links there's no way I could gone lower than 1.5" or they wouldve hit the arm.
*it was the front i was having clearance issues with. not the rear. rear was fine.
CSG Mike (08-20-2015)
Old 08-21-2015, 08:09 PM   #152
JGalp
Drives: 2015 CWP BRZ Limited
Has anyone installed the flex Z with the OEM audio + sub in the back? if the sub has the cusco strut bar customization would that be enough for the struts that stick out in the back?
JGalp is offline   Reply With Quote
Old 08-22-2015, 07:25 PM   #153
Bramick
Bramick's Avatar
An easier way to setup the measurements.
The Following 2 Users Say Thank You to Bramick For This Useful Post:
Coastermikey (08-22-2015), zc06_kisstherain (08-23-2015)
Old 08-22-2015, 08:22 PM   #154
Coastermikey
Drives: BRZ DGM
So I received my coils, anyone else notice there are more than 16 adjustment settings or am I counting clicks.
Coastermikey is offline   Reply With Quote
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
