Old 03-27-2015, 05:32 PM   #1
stockysnail
Just the tip
stockysnail's Avatar
Question Whiteline Front Roll Center Kit - Anyone have and can review?
I was considering purchasing the Whiteline Front Roll Center kit but would like to hear opinions about them first. Has anyone out there installed them? If so what are the before and after impressions and what other things have you don't to you suspension?
Old 03-27-2015, 10:48 PM   #2
orangeblue
Drives: Whiteout
I've got one waiting to be installed.
MotoIQ installed the kit on their car: http://www.motoiq.com/MagazineArticl...Whiteline.aspx
orangeblue is offline   Reply With Quote
Old 03-28-2015, 12:24 AM   #3
wootwoot
Drives: FRS
I have them. I contacted Whiteline and they told me they are built to correct 20mm of drop. I lowered the car 20mm via coilovers before corner balancing. I think they are a good product if you use them correctly.
The Following 2 Users Say Thank You to wootwoot For This Useful Post:
ruturaj001 (09-03-2024), stockysnail (03-28-2015)
Old 03-28-2015, 01:13 AM   #4
stockysnail
Just the tip
My drop from RCE yellows just happens to be around 20mm so this may be good then.
Old 03-28-2015, 01:14 AM   #5
stockysnail
Just the tip
Notice any difference in handling or in general with them on? Did you need realignment after?
Old 03-28-2015, 02:20 AM   #6
wootwoot
Drives: FRS
Hard to say what they did in isolation as I changed several things at once. You should get an alignment after for sure.
Old 04-14-2015, 05:25 PM   #7
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Drives: Bone stock 2019 BRZ manual
Smile
You are supposed to get an alignment afterwards, they say it makes a big difference. I'm hopefully getting these soon along with some hotchkis springs
AreteAuto is offline   Reply With Quote
The Following User Says Thank You to AreteAuto For This Useful Post:
stockysnail (04-14-2015)
Old 04-18-2015, 05:48 PM   #8
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
Pressed in the ball joints today, should have it buttoned back up by tomorrow. I'm thinking changes will be minimal. Will report after testing.
funbeatsfast is offline   Reply With Quote
The Following User Says Thank You to funbeatsfast For This Useful Post:
FRS Johnny (04-18-2015)
Old 04-21-2015, 12:12 AM   #9
orangeblue
Drives: Whiteout
I installed the kit a week ago. But I also installed a bunch of other stuff, so hard to make any concrete statements about changes attributable to the roll-center kit as opposed to the caster kit (ALK), solid steering rack bushings, new alignment settings, etc.
Old 08-16-2015, 04:05 PM   #10
stockysnail
Just the tip
Anything to report back?
Old 08-17-2015, 03:36 PM   #11
funbeatsfast
Drives: '13 FR-S
Sorry for the delay. As predicted, changes are minimal.
stockysnail (08-18-2015)
DIY: Whiteline Roll Center Adjustment Kit Install RallySport Direct DIY (Do-It-Yourself) Guides 27 05-27-2020 07:21 AM
(PA) Whiteline roll center/ bump steer tapsumbongfrs Brakes, Suspension, Chassis 2 03-05-2015 04:12 PM
Whiteline Bump Steer & Roll Center Kit Review troek Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-22-2014 09:25 AM
For Sale: Whiteline roll center correction kit BNIB xDanger_208x Brakes, Suspension, Chassis 3 06-23-2014 09:56 AM
Whiteline Roll Center Kits now available at RallySport Direct! RallySport Direct Brakes, Suspension, Chassis 7 11-25-2013 05:01 PM
