#1681 | |
APEXHNTR
Drives: 10 Series FR-S #1867
I just wanted to touch on this one... ST's are basically KW v1's meaning there's height and "damper" adjustments. On the KW v3's the height is adjustible as well but the compression and rebound are independently adjustible.
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#1682 | |
Drives: 4 wheels
| The Following User Says Thank You to justint5387 For This Useful Post: | Jawnathin (08-17-2015) |
#1683 |
Drives: 2017 BRZ
I spent last winter researching and prepping, first year back out in a long while so coming along. So unsure how relevant this may be at this time, but probably enough to share. With wheels and such I'm just over $10k already, and there are some updates I may need to make (we'll see if I ever justify a clutch type LSD with driving to match...) I could have spent a little less on wheels, and I certainly didn't need the Sprint AP this year for the weight savings (but they're SUCH nice brakes)
Slowly getting better as a driver, we'll see how next weekend goes in Milwaukee, and how that leaves me feeling about how Chicago is going for me just now... For perspective, my car (different driver, his first ever in a BRZ rather than his Corvette...) last event in Milwaukee was 0.3 behind @Scooby South and not quite 1.5 behind Hockerman and Leeder... and a very tough field up at the top of PAX where they were 4 and 7 (Cashmore in 1. Intake, I'd go Grimmspeed or not bother. I have one, not sure it matters. I'd do it again just because it cleans up the engine bay so much, but there's probably a little power gain too. Exhaust, only Nameless is 3" as far as I know and, while they demonstrated an improvement with 3" over 2.5" I'm not sure it's worth the weight or increased noise - and that's after going for a full 3" as quiet as I could find (JDL.) I think the torque band on Nameless or Ace are where you want to be. That's not to say others won't work out perfectly well - my obsession over maximizing options without the skill to back it up is speaking here I do like the sound, just a touch loud and WOT always gets a touch brash due to timing changes... I may need to add engine mounts though, since I'm dealing with rear subframe+exhaust contact under acceleration.Coilovers, I wanted ride height and preload separate, and I wanted good support this side of the ocean. I might go a different route if I started all over, but I have a little room to go as a driver before I'm comfortable making an outright switch. And I'd be trying different springs first. I do think you'll want at least double-adjustable if you're serious, and probably pretty high rates. Last event I ran into some conditions that actually made me wonder if 3-ways would have been able to tune out some odd behavior with softer high-speed compression but... I doubt I have a clue. This seems to be where folks keep the most quiet, making it difficult to know what's truly fast.You can dig up some goodies used if you're patient, and help keep the budget down (I did...) The sales are also obviously useful for that... C |
#1684 |
Drives: Many
I've never heard that from anyone I know with MCS. This just for brz/frs? Or generally speaking?
#1685 |
Drives: 4 wheels
#1686 |
Drives: Many
Alright, well I guess I'll report back on mine when I get them and install them.
#1687 | |
Drives: Subaru BRZ
#1688 | |
Drives: 2013 WRB BRZ
| The Following User Says Thank You to autoXracer For This Useful Post: | ksconekiller (08-29-2015) |
#1689 |
Corvette convert
#1690 |
btr.life
Drives: 2022 GR86
Thinking about defecting from my e36 STX BMW to a twin. Drove my friends STX prepped FRS at a TnT last weekend and instantly went a full second quicker (on a ~46s course), having never even driven the car before, than my fastest of ~12 runs in my BMW
![]() Anyways, are there specific trims or models that are better than another for autox? Or, all they all the same?
#1691 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
For a prepped STX car, they are all the same
CS is another story Sent from my A0001 using Tapatalk |
#1692 | |
Drives: Moped
The 2016's have gained a little weight (from other model years) from what I've been told. In the U.S. all Scion offers is a base version (no specialty trims unless you count the Release Series, Monogram, etc....which is a little heavier than the base FRS because of add-ons, different interior trims). |
#1693 | |
Drives: 2017 BRZ
It was a BRZ limited for me because my wife wanted heated seats. Not sure the STI bodykit matters, but with everything (maybe even just the underbody stuff) it's a tiny bit better aero... |
#1694 | |||
btr.life
Drives: 2022 GR86
Don't want to make any moves until after I get back from Nationals though.
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
