Old 08-11-2015, 08:37 PM   #127
TurboBRZ
TurboBRZ's Avatar
Drives: 2013 BRZ Limited
Dyno Testing
The numbers are in! I went to STP Motorsports on their Dynojet to run the test and made 252.38whp @ 7psi, 273.95 @ 9psi and 295.85 @ 12psi. These are SAE numbers (the actual pull showed about 299.2 on the screen for the third map).
Not bad for a cheap ass turbo kit eh?
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast.
TurboBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to TurboBRZ For This Useful Post:
GhostOp86 (08-12-2015), Sportsguy83 (08-11-2015)
Old 08-11-2015, 09:01 PM   #128
raven1231
No sir sure aren't. Right up there with speed by design.
Old 08-11-2015, 10:39 PM   #129
TurboBRZ
TurboBRZ's Avatar
anyone know how to post youtube videos in posts?
Old 08-11-2015, 11:52 PM   #130
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
[ame="https://www.youtube.com/watch?v=bVRR_vEU9S8"]2013 BRZ makes 295whp @ 12psi on 93 octane - YouTube[/ame]
The Following User Says Thank You to Sportsguy83 For This Useful Post:
TurboBRZ (08-12-2015)
Old 08-12-2015, 09:29 AM   #131
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I take it their tach hookup was broken?
Old 08-12-2015, 10:32 AM   #132
TurboBRZ
TurboBRZ's Avatar
Dunno - maybe it was. I wasn't paying a whole lot of attention to their equipment, I was reading my own AFR gauge and Boost gauge during the runs and only looking at their screen afterwards to see what my HP and TQ curves were. Here is the graph based on RPM which also shows my AFR and TQ curves:
Although I have no idea why the #'s changed a little as I didn't mess with the scaling or smoothing or any other factors in this area?
The Following User Says Thank You to TurboBRZ For This Useful Post:
Sportsguy83 (08-12-2015)
Old 08-12-2015, 03:18 PM   #133
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The tach hookup was working if you got RPM which you did. I am always skeptical of Dynojet plots that don't show RPM at the bottom as you can see it somehow calculates it differently if the RPM signal is present so it can display torque. Torque numbers are pretty low while peak horsepower numbers are good.
Old 08-14-2015, 01:00 PM   #134
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Nice information here. I don't mean to thread hi-jack, just figured I'd post since I also did not find many CX kit owners so figured I'd leave some feedback.
I also went with the CX Racing kit on my BRZ. The issues you had were the same as me. The bolt quality was very poor (replaced with stronger bolts from Lowes). Welds on the manifold all were good quality, but the manifold to block flanges were not flush. I also had to use some high-temp RTV to get it to seal. When everything comes off to get coated, I'll also have it milled so it sits flush with the gasket.
Intercooler piping in my case was a perfect fit, though it could be due to my changed intercooler location due to my aftermarket crash bar. I made custom brackets to mount the intercooler so the position was slightly changed versus installing on the factory crash bar. I'll add a pic below showing my setup.
The last problem was the turbo itself. It is nothing more than cheap eBay knockoff (as well as the BOV and WG..). The oil seals in my turbo went out after a week. Luckily it only leaks in to the turbine side straight out the exhaust, so the car is still drive-able if I need to move it. The whole plan from the start was to replace it with a Precision turbo so its not a big deal. CX offered a 50% discount on a replacement turbo for me if I decided to try a replacement.
In the end you can only expect so much when going with a cheaper kit. I have to say that overall I am impressed with the quality. The modifications I've needed to make to the kit itself are worth the hassle from how much money I saved going with a cheap kit that I can directly fit a bigger turbo on to, which also has intercooler piping routing easily adaptable to a bigger intercooler in the future. I bought this kit to futureproof and it did the job perfectly.
No numbers on my end. I was only halfway through tuning the car when the oil seals went out. Hopefully you'll have better luck with your turbo than I did. I didn't expect it to last long but I did hope for more than a week.
BRZoomTX is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZoomTX For This Useful Post:
aagun (09-09-2015), raven1231 (08-14-2015)
Old 08-14-2015, 01:07 PM   #135
raven1231
You had the same idea I did originally. Only mine was to just get the hot parts kit and source my owns waste gate, turbo, and bov
Old 08-14-2015, 01:11 PM   #136
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
That was the original goal, but CX did a nice discount for the 4th of July sale so I went ahead and got the full kit. If the turbo quality was better the full kit is more than enough to exceed limitations of the stock fuel system. There would be no reason to upgrade the turbo unless you are looking for more than 300whp. This setup should do 350whp easy on e85 with fuel mods.
.. but I'll never know. The pte5558 will be here soon enough.
Old 08-14-2015, 01:19 PM   #137
raven1231
I was more so doing it to avoid a stuck waste gate or turbo from exploding lol. More reliability oriented then power output.
Old 08-19-2015, 01:07 AM   #138
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
Awesome. Following this.
KevinK121 is offline   Reply With Quote
Old 08-19-2015, 03:36 PM   #139
Cerevo
Drives: 2003 Evo GSR TB
I'd love to do this when I get a BRZ some day, the only thing I would change is the turbo and wastegate with a GReddy Type-S BOV.
great info and awesome build!
Cerevo is offline   Reply With Quote
Old 09-04-2015, 10:21 AM   #140
kilohercas
Drives: Subaru BRZ (soon?)
how about fuel consumption ? Does this turbo at light load makes it better or worse ?
Or you are to much right foot happy to even bother about economy ?
kilohercas is offline   Reply With Quote
brz cx racing turbo, brz rebuild, brz turbo
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 12:25 PM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 11:34 PM
91 MR2 Turbo with KO Racing GT35R Turbo Kit Unleashed Cars for Sale/Trade 2 02-21-2013 06:18 PM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 07:26 PM
