Old 08-12-2015, 10:54 PM   #12517
LWAA
Drives: Subaru BRZ
Realized after reading reviews.
Sent from my iPhone
LWAA is offline   Reply With Quote
Old 08-13-2015, 11:42 AM   #12518
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
just bought a whole bunch of silicone hoses for my turbo set up
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 08-13-2015, 11:52 AM   #12519
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Installed a gas pedal relocation kit.
GSpeed is offline   Reply With Quote
Old 08-13-2015, 12:19 PM   #12520
raven1231
Sent from my iPhone
OFT and E85 is your best bet. If you don't have E85, OFT and a header are the second best "bang for your buck" combo.
Old 08-13-2015, 12:24 PM   #12521
LWAA
Drives: Subaru BRZ
Ok. No I don't know if you're being serious or pissing about.
Sent from my iPhone
Old 08-13-2015, 12:38 PM   #12522
kch
Senior Misanthrope
kch's Avatar
Sent from my iPhone
For once raven is being serious. Using an OFT allows you to flash a tune to run E85, which is a noticeable increase in power. Installing a catless header, combined with an appropriate tune (can also use OFT for this), is generally the best mechanical mod you can do.
Old 08-13-2015, 04:39 PM   #12523
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Arrow DEMO
Lighting Demo
Sorry for the bugs, I had a focusing issue when doing the headlights at the beginning of vid and should have had my camera up higher when recording the tails
[ame="https://www.youtube.com/watch?v=ERr7n3bh-Wg"]BRZ Lighting Demo - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=ASkmtgRfZ6M"]Intec CF Tail Lights Demo FRS/BRZ/GT86 - YouTube[/ame]
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 08-13-2015, 05:47 PM   #12524
Synkronicity
Drives: Ford Escape to BRZ
found this stupid dent in my car, not sure how it happened but how can i fix it? LOL
Synkronicity is offline   Reply With Quote
Old 08-13-2015, 06:27 PM   #12525
waltco
waltco's Avatar
Drives: 2013 Subaru BRZ
Are these on the market? And how much?
waltco is offline   Reply With Quote
The Following User Says Thank You to waltco For This Useful Post:
GSpeed (08-13-2015)
Old 08-13-2015, 07:46 PM   #12526
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
They will be shortly. We'll do a group buy for the first run with tiered pricing, but aiming for under $100. Production units will be CNC machined with prettier rounded corners and pockets to reduce unnecessary weight.
More info here: http://www.ft86club.com/forums/showthread.php?t=93277
The Following 2 Users Say Thank You to GSpeed For This Useful Post:
DocWalt (08-13-2015), srizzors25 (08-17-2015)
Old 08-13-2015, 08:47 PM   #12527
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
I'm glad I'm not the only one who thinks the gas pedal is just a bit to far. Found it a little more difficult to heel toe.
rookie is offline   Reply With Quote
Old 08-14-2015, 12:12 AM   #12528
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
Most dealers and body shops have a guy or know a guy that removes those with vacuum.
The ones I've had done were pretty hard to even tell where they were...some were impossible.
MGPAX is offline   Reply With Quote
Old 08-14-2015, 12:16 AM   #12529
MGPAX
Still 17!
MGPAX's Avatar
Installed Whiteline's Caster/Camber top hats.....
By myself
In a parking lot
With the car's jack, a few pieces of wood and some hand tools
Only removed top hat nuts, top strut nut, sway bar nut and wheel
Really liking the way the car corners. Added 1.5 degrees static camber and .75 degrees caster. Next week is perrin 16mm rear adjustable sway bar!
Old 08-15-2015, 06:21 PM   #12530
Fastbrew
Drives: 2014 Pearl White BRZ
Filled up with E85 at Jay's Garage in Portland. Nice E content and just over 3 bucks a gallon.
Fastbrew is offline   Reply With Quote
