Old 08-12-2015, 01:30 PM   #43
S84kam
S84kam's Avatar
Drives: FBRZS
Originally Posted by pleong View Post
just curious... if i were to be able to make one and get it fully functional and PnP.. how many would be interested in getting one?
I'd be interested just to get the brz hvac to work and operate manually/normally on my frs!!!
S84kam is offline   Reply With Quote
The Following User Says Thank You to S84kam For This Useful Post:
Cessblood (09-15-2015)
Old 08-12-2015, 01:34 PM   #44
pleong
Drives: 2013 Whiteout FR-S
Originally Posted by ir1064 View Post
i'm interested in single zone, dual is too complicate and not necessary.
I agree I think single climate control would probably be best... BUT I think that would mean the harness would be different from what was posted on the first page correct?
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
The Following User Says Thank You to pleong For This Useful Post:
Old 08-12-2015, 03:49 PM   #45
Chaetagnath
Drives: Whiteout FRS
My harness is designed for dual temp. My install ended up being single temp. So, the same harness works for both, you just end up with one plug (for the passenger side temp) which isn't used.
Chaetagnath is offline   Reply With Quote
The Following User Says Thank You to Chaetagnath For This Useful Post:
Binary_fission (08-12-2015)
Old 08-12-2015, 04:39 PM   #46
Binary_fission
Binary_fission's Avatar
Drives: FRS
Where did u get the harness from?
Sent from my SM-N910T using Tapatalk
Binary_fission is offline   Reply With Quote
Old 08-12-2015, 07:01 PM   #47
Chaetagnath
There was a guy a couple years ago who made them. No one has been able to track him down. However, with the info I posted earlier it can be made. If you order all of the connectors and pins, and have a bunch of wire, it should be fairly straight forward to put one together.
Old 08-13-2015, 08:30 AM   #48
pleong
I'll be attempting towards the fall/winter.. it's too hot in texas right now lol
Old 08-13-2015, 11:51 AM   #49
S84kam
S84kam's Avatar
Drives: FBRZS
Driver side temp control servo: SU003-02045
Damper control servo: SU003-02044
Screws for the servos (need 5 total) SU003-02113
Blower transistor (73533AJ000)
the climate control panel: 72311CA061
temperature sensor: 73730CA020
the hose assembly for the temperature sensor: 72313CA010
Thanks for all your hard work. Is there a way I could just make the harness and plug and play without those extra parts? I just want the normal frs manual functions
Old 08-13-2015, 12:16 PM   #50
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Dual Climate Climate "Style" Conversion
You want this then. At which point you might as well wait for the harnesses to be available or make your own harness cause it looks very out of place(and worst than the manual controls IMO)
Old 08-13-2015, 02:34 PM   #51
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
I have most of the parts. I just need the harness.
Cessblood is offline   Reply With Quote
Old 08-13-2015, 02:46 PM   #52
S84kam
S84kam's Avatar
Drives: FBRZS
No offence to that guy. But that's a butchered looking system
The Following 2 Users Say Thank You to S84kam For This Useful Post:
DustinS (08-13-2015), pleong (08-14-2015)
Old 08-13-2015, 02:46 PM   #53
S84kam
S84kam's Avatar
Drives: FBRZS
How much we're all the parts?
Old 08-13-2015, 03:06 PM   #54
Binary_fission
Drives: FRS
Did u get them from dealership?
Old 08-13-2015, 03:11 PM   #55
Cessblood
I didn't get the parts from the Dealership. I got them from someone online. I'll take pictures of the parts when I get home. I had the parts for a few mouths. I almost sold them.
Old 08-13-2015, 04:51 PM   #56
Binary_fission
Drives: FRS
So i contacted Diode to make harness for this ac. They are known for making custom harness and wiring mods for cars, so I thought they might be interested in making one for ac. And here's their response.
Originally Posted by DiodeDynamics View Post
Hello,
While it is in the realm of what our engineers can do we stick only to aftermarket lighting solutions at this time. I will pass that information along though!
Thank you,
Phillip
contact@diodedynamics.com
(314) 205-3033 x223
I'm hoping they decide making it cuz i know they can do it.
Wtb:pnp harness for automatic climate control for frs Sangthing Want-To-Buy Requests 5 01-02-2015 04:11 PM
BRZ limited dual climate control Sangthing Interior Parts (Incl. Lighting) 6 09-12-2014 06:01 AM
Ac knobs for BRZ limited / FRS with dual climate dnizzle Cosmetic Modification (Interior/Exterior/Lighting) 3 08-15-2014 10:43 PM
FS - BRZ Dual Climate Control Unit dvsidboy Audio/Visual, Electronics, Infotainment, NAV 4 01-12-2014 08:52 PM
