Old 08-12-2015, 09:29 PM   #29
jflogerzi
jflogerzi's Avatar
Originally Posted by glamcem View Post
"overkill".. I hear this word pretty often these days
http://www.ft86club.com/forums/showp...1&postcount=76
for a track day no cooling mod is "overkill" IMO, there is "adequate" or "inadequate " cooling..
if you don't have a thermostat or thermostatic sandwich plate (so called "high flow plates" which I've never been a fan of) or don't block the oil cooler during cold winters/days, it's expected to see those kind of temps .. if you still have the oil cooler I would keep it and add a thermostat (not a thermostatic plate that is prone to failure)
I would get some sort of oil cooler (OEM preferably ) even when stock,
It had a thermostat but temps still stayed low. I am sure it was not defective. If I do keep the car, I will invest in an OEM like setup which should help a bit.
The Following User Says Thank You to jflogerzi For This Useful Post:
glamcem (08-12-2015)
Old 08-12-2015, 10:03 PM   #30
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
What are your air fuels? You sure you weren't overheating the OEM header cats cuasing a good amount of heat pre cat.
WHITE is offline   Reply With Quote
Old 08-12-2015, 10:46 PM   #31
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by jflogerzi View Post
I agree with OEM is better. I just switch all my exhaust(Catless Borla UEL, Motiv OP, and Perrin 2.5inch Resonated CB) back to stock. WoW what a difference. I don't think I can't go back to aftermarket. I love the quiet smooth OEM sound.
I just went back to stock exhaust too. I felt like I was always shouting at everyone. I go to the track plenty (I've been averaging about twice per month this summer) but the car is driven on the street 99.9% of the time. I've built it for it's actual purpose, not it's "intended" purpose
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 08-13-2015, 12:34 AM   #32
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
yes, I am pretty sure
glamcem is offline   Reply With Quote
Old 08-13-2015, 12:39 AM   #33
glamcem
glamcem's Avatar
what exactly do you mean by "stock exhaust"? like the full exhaust system including the headers or header back or just catback ?
either way, that's something I would never do even for street use only, once you drastically change your power output, you also need to make other drastic changes to keep the car in a good working order and "free exhaust flow" comes first in that list.. each his own of course
Old 08-13-2015, 01:04 AM   #34
CSG Mike
CSG Mike's Avatar
Originally Posted by Sleepless View Post
These failures could be caused by your tune. There are others out there with stock header and FI and so far you are the only one that seems to be having this problem.
It's not a tune issue. I've observed this failure before.
glamcem (08-13-2015)
Old 08-13-2015, 01:36 AM   #35
glamcem
glamcem's Avatar
yes, I remember we had this conversation ..
Didn't you also say it was an NA car and melted cats or something?
The Following User Says Thank You to glamcem For This Useful Post:
CSG Mike (08-13-2015)
Old 08-13-2015, 03:20 AM   #36
CSG Mike
CSG Mike's Avatar
Stock tune too :p
Old 08-13-2015, 03:41 AM   #37
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Nice! That's why you were in the hood! Pete was around too during lunch time, we were working on his car with the PBBs for several hours.
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following 2 Users Say Thank You to Drift-Office For This Useful Post:
glamcem (08-13-2015), Sleepless (08-13-2015)
Old 08-13-2015, 03:56 AM   #38
glamcem
glamcem's Avatar
Stock tune too :p
case is closed now
Old 08-13-2015, 03:58 AM   #39
glamcem
glamcem's Avatar
I never knew he would be there haha what a timing
Old 08-13-2015, 09:26 AM   #40
Timmy_Jones
Spun
Drives: 23' Supra
Originally Posted by Lunatic View Post
Your going to love the coating. I had my headed coater with 2000 degree ceramic inside and out and it made a big difference.
Big difference? How so? Curious what you observed.
Timmy_Jones is offline   Reply With Quote
Old 08-13-2015, 09:27 AM   #41
Timmy_Jones
Spun
Drives: 23' Supra
Is this thread for real?
A guy uninstalled and then re-installed an OEM manifold 3 times, another guy is claiming he couldn't wait to go back to OEM so he could smooth out the car.
I am confused.
Old 08-13-2015, 12:30 PM   #42
glamcem
glamcem's Avatar
I am confused.
I cannot blame you for that
maybe I could've been more clear, first time when this happened I thought it might be because of just bad luck or the restrictive factory cats or combination of both so I wanted to try without the cats this year and the same thing happened at the same exact spot, at that point I was sure it's the build/material quality ..
I mentioned my reasons and why I preferred the OEM header instead of an aftermarket one and wanted to give another chance ...I also mentioned that the third manifold has been installed temporarily (until I receive my HKS ),
we also learned that same thing can happen to a completely stock car,so would you consider running OEM manifold on the track -especially when boosted- and having that information in mind? that would be the question to ask I think
Timmy_Jones (08-13-2015)
Looking for used aftermarket exhaust or header vitti821 Want-To-Buy Requests 1 04-07-2015 10:58 PM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
WTB: Aftermarket Header Akari Want-To-Buy Requests 1 08-08-2014 12:57 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Aftermarket Header help!!!! chiefshayan Engine, Exhaust, Transmission 20 11-20-2013 02:32 AM
