| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: blue brz
When does second radiator fan come on?
Hi all,
I've had an overheating problem and am diagnosing why the second fan (drivers side) doesn't come on. Some posts say if AC is turned on, both fans should come on. Only my primary fan comes on with AC. Some posts say one is triggered with the AC and the other is triggered based on coolant temp. Hooked fan to battery and proved wires and motor are good. Swapped fan relays - no change. Primary fan comes on with AC but no second fan. Ran car up to temp (engine temp of 215), pulled over and checked under hood. No second fan running. Is there any way to validate proper operation of the second fan while car is sitting in the driveway? Thanks for any help. Keith |
#2 |
Drives: 2005 Toyota Camry
There are two fans, one for engine and one for AC.
The engine fan will come on once you have reached an "overheating" condition. The specific temperature triggers are listed in the FSM, however it does not come on with only AC usage. The only way to validate is to either replicate the engine heating conditions to trigger fan, or have some type of ECU tuning software that allows you to manually turn the fan on. -alex |
#3 |
Drive From Home
Drives: BRZ STI Performance
This problem was pretty common with the Mk5 Golfs. It was fixed by replacing the secondary fan (my old Golf GTI) or both fans (my friend's old Golf S). We weren't able to monitor the fans with RossTech VCDS (if there is a parameter to read, I wasn't sure where it was), so I'm not sure if Toyota Techstream can monitor the operation of the fans.
Pretty easy to test on a very very hot summer day with the car parked and engine started. The primary fan should come on after the engine starts, and then as soon as A/C is turned on, the secondary fan should come on. |
#4 | |
Drives: blue brz
#5 | |
Drives: blue brz
#6 | |
It's triggered by coolant temp, and usually some combination of ambient temp + vehicle speed. I don't have access to the ECU code, otherwise there would be a more definitive answer. -alex |
#7 |
Drives: Asphalt Scion FR-S
@krl, have you checked the RDI fuse? I'm bringing this thread back as I solved this same issue I had on my car. Both fans should turn on with AC on.
I experienced Fan2 (driver side fan) never getting enabled. Fan1 (passenger side fan) would go on with AC and when overheating. I swapped in spal fans w/ shroud since I thought Fan2 motor died. Fan1 worked for a while, and then stopped working with AC. Realized 2x 25A fuses were blown, RDI and CDS. RDI is Fan2 and CDS is Fan1. Now both fans turn on with AC. It's odd the BRZ wiring schematic doesn't include these fuses in the diagram for the radiator fans, but includes the relays.
| The Following User Says Thank You to JDKane527 For This Useful Post: | SuperTom (09-17-2018) |
#8 | |
Stole my avy from zGrinch
Drives: 2015 Audi S3
If you go out for a drive on a hot day, go for a nice brisk drive and get it up to temperature. After about 30 minutes, come home and park it in your driveway and leave it idling. Turn off the air conditioning. At this point, you shouldn't hear any fan running. As the car heats up since it isn't moving, the second fan should kick on (depending on ambient temperature, I would guess 10 minutes or so). Once it does, turn on the AC and then both fans should be going.
2015 Audi /S3 | Panther Black | DSG Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT |
| The Following User Says Thank You to pinski For This Useful Post: | jcw99 (07-12-2016) |
| FS: OEM Radiator | MicheleAbbate | Engine, Exhaust, Bolt-Ons | 10 | 09-12-2016 02:11 PM |
| Radiator for AT | Boba_kz | Engine, Exhaust, Transmission | 15 | 01-18-2016 04:22 PM |
| WTB: OEM Radiator | TemeCal | Want-To-Buy Requests | 2 | 01-23-2015 09:34 AM |
| FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 15 | 05-27-2014 01:18 PM |
| Mishimoto Radiator & Mishimoto Radiator Hose Kit | tlinspired830 | Engine, Exhaust, Bolt-Ons | 5 | 01-08-2014 09:44 AM |
