Old 08-11-2015, 04:08 PM   #323
dmyers
dmyers's Avatar
Drives: Subaru BRZ 2013 Dark Gray
Judging from the image you quoted, the intake housing appears to be rapid prototyped (you can see the "grain" showing the printing direction if you look closely). I would guess this was more for fitting purposes, or as bertio mentioned, an individual test unit.
Rapid prototype for sure. if you look a few of the pictures it actually looks like it goes straight in.
http://www.edelblog.com/wp-content/u...07/fender1.jpg
dmyers is offline   Reply With Quote
Old 08-11-2015, 05:35 PM   #324
Budo
The IC core
Originally Posted by 350matt View Post
interesting, looks like the edelbrock IC core is a lot smaller than the cosworht units
we'll see I spose wher it all sits in terms of IAT and bhp
Agreed. At first glance of the pictures I'm disappointed, but everything else looks "On Point" and modern colloquialism puts it. It seems comparing Cosworth, Harrop and Edelbrock, one has quad cooling, the next 2 W2A units and Edelbrock the one unit. I hoped that the single unit was about the same total size as the Harrop's two units, but it doesn't appear so. Ah well, as above, we will see what comes out in the wash. But, I do so want something with enough headroom to be able to justify built engine in several years.
Cheers,
Budo
Budo is offline   Reply With Quote
Old 08-11-2015, 06:01 PM   #325
wparsons
wparsons's Avatar
Originally Posted by dmyers View Post
I noticed on their "test" BRZ they ended up putting a Borla cat-back on it after the testing was finished. I wonder if they would share that tune with SC purchasers? I think the Borla sounds pretty good and if I could get the tune it would make this SC even a better deal!
Generally a cat-back won't require re-tuning at all
flickr
RobertPaulson (08-14-2015)
Old 08-11-2015, 06:06 PM   #326
CSG Mike
CSG Mike's Avatar
The Edelbrock core is designed for minimum airflow restriction. You have to balance airflow with temperature drop. On the other hand, the Edelbrock heat exchanger is far, FAR larger than the Cosworth unit. It is nearly the size of the OEM radiator!
I have no doubt the Edelbrock will have a far more sustainable output.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
BatStig (08-11-2015), Budo (08-11-2015), funwheeldrive (08-11-2015), wparsons (08-15-2015)
Old 08-11-2015, 06:08 PM   #327
CSG Mike
CSG Mike's Avatar
Oh, and....
The Following 9 Users Say Thank You to CSG Mike For This Useful Post:
bedabi (08-14-2015), civicdrivr (08-11-2015), CxG (08-11-2015), FLIPs_FR-S (08-11-2015), funwheeldrive (08-11-2015), G-Man (08-12-2015), Porcupint (08-12-2015), SuperDave (08-25-2015), tahdizzle (08-11-2015)
Old 08-11-2015, 06:29 PM   #328
tracerit
Drives: '13 SSM BRZ Limited 6MT
Oh, and....
any idea on what pricing will look like for a CARB version?
tracerit is offline   Reply With Quote
Old 08-11-2015, 07:18 PM   #329
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Oh, and....
Mike, you're such a tease
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
CSG Mike (08-11-2015), sato (08-12-2015)
Old 08-11-2015, 07:22 PM   #330
Calum
That Guy
Drives: 2013 asphalt FRS MT
It only doesn't go straight in on the stick intake manifold.
Old 08-11-2015, 07:22 PM   #331
CSG Mike
CSG Mike's Avatar
Sorry, only so much I can do until its officially released....
Old 08-11-2015, 07:47 PM   #332
BigFatFlip
BigFatFlip's Avatar
Do you guys plan on testing and carrying this product too, similar to the JRSC?
Old 08-11-2015, 08:07 PM   #333
dmyers
dmyers's Avatar
Right, that's a whole new intake.
You can see the intake and tube in this picture a lot better
http://www.edelbrock.com/automotive/...ers/fa20.shtml
Looks like the same air "input" location (without the stock snorkel) to a larger filter? Which is then straight into the intake
Old 08-11-2015, 08:35 PM   #334
CSG Mike
CSG Mike's Avatar
To a lesser degree yes.
Old 08-12-2015, 03:53 AM   #335
j123ic
Drives: Evo 9
You're absolutely right Mike. I just wanted to add that the E-Force kit utilizes .75" id intercooler hoses, whereas others are using .625" or smaller. Additionally, the waterpump flows double the amount at 8gpm v.s the older Bosch unit at 4gpm.
Based on images I have seen online, both Harrop and Cosworth are using Bosch pumps.
Lastly, fin density on both the charge-air-cooler and front heat-exchanger is key. It may be too early to find this info, but Edelbrock usually posts the performance specs of each in BTU's/hr. Basically, you can't tell how something will perform based on size alone.
j123ic is offline   Reply With Quote
The Following 4 Users Say Thank You to j123ic For This Useful Post:
BatStig (08-12-2015), Budo (08-12-2015), CSG Mike (08-12-2015), Phantobe (08-12-2015)
Old 08-12-2015, 07:17 AM   #336
350matt
Drives: toyota mr2/ Toyota GT86
agree about the BTU statement, I'd be surprised if they release that information thou
I remember the cosworth statement was the coolers were good for about 35Kw of heat rejection which they equated to about 400Bhp
also the cosworth hoses are 0.75" not 0.625"
and have you got any details about this 8 GPM pump? I'm always on the lookout for better pumps..
350matt is offline   Reply With Quote
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
