Old 08-05-2015, 03:31 PM   #2073
NepeanFR-S
NepeanFR-S's Avatar
Drives: 10 Series FR-S
Originally Posted by torqdork View Post
Makes sense but does seem a little soon. The manual says to keep the fob at least 15' (IIRC) away from the car when not in use or batteries will fail sooner.
Will change the batteries in one FOB myself and see what happens. I hope it does the trick as I hate dropping off the car for service with an intermittent problem...
NepeanFR-S is offline   Reply With Quote
Old 08-05-2015, 09:41 PM   #2074
dnieves
Drives: FR-S 10 Series
So you can use that weird miniature key in the fob to open the trunk and driver's side door but if the fob's battery is dead how do you start the car?
dnieves is offline   Reply With Quote
Old 08-06-2015, 01:20 AM   #2075
torqdork
torqdork's Avatar
Drives: RV-7
Push the Start button? It runs off the car battery so is independent of the fob battery unless there's some sort of fob transponder code needed to begin the start sequence. Easy enough to test.
torqdork is offline   Reply With Quote
Old 08-06-2015, 06:59 AM   #2076
dnieves
If you take out the battery from the fob there should be a RFID (in the fob) that the car detects to get it started? So as long as your car has power and a working RFID scanner you're set to go.
I'll try it out the weekend.
Old 08-26-2015, 02:21 AM   #2077
alexjandro
alexjandro's Avatar
Drives: 2013 FRS
Picked up #2346 last week. 4,500miles. Phoenix AZ
alexjandro is offline   Reply With Quote
Old 08-26-2015, 02:43 AM   #2078
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Grats, welcome to the club!
aegisdrgn is offline   Reply With Quote
Old 08-26-2015, 02:43 AM   #2079
alexjandro
alexjandro's Avatar
Drives: 2013 FRS
Thanks!
Old 08-26-2015, 01:47 PM   #2080
torqdork
torqdork's Avatar
Drives: RV-7
Nice clean example, congrats! Really interesting pic, too.
Old 08-26-2015, 04:16 PM   #2081
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
So it's been two years since majority of us has owned a 10Series. How have they been treating you (ex. any issues, faults, problems) ? Post mods of your 10Series as well
Old 08-26-2015, 05:59 PM   #2082
dnieves
My experience with the 10 Series has been great. The only problem I had was the slightly leaky cam plate (such an easy fix -I'd recommend it as a preventative measure for any manual twin leaking or not!).
Ownership has been so incident free I can see why so many people here let their OCD get the better of them and nit pick the dumbest things.
It still turns heads and I'd buy it again (except not from Atlantic Toyota!!!!).
Old 08-26-2015, 06:29 PM   #2083
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
I might be the only one with this but my front and rear LED emblems have stopped lighting up. Not sure if it has to do with the -40 to -50 degC that I had the car in last winter.
I'm just glad the LEDs in the headlamps and tail lights are able to withstand such cold.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 08-26-2015, 06:38 PM   #2084
aegisdrgn
aegisdrgn's Avatar
Might just be a fuse issue?
Old 08-26-2015, 10:15 PM   #2085
dnieves
Check the fuse to see if it's intact then take a voltmeter and check the wiring harness leading to the module, check to see if there's power coming out of the control module (could be bad), if that checks out then the wiring to the badge (or the badge itself) is the culprit.
I just re-read your post. I'd check: the fuse, wiring harness to control module, and control module itself.
Old 08-27-2015, 02:34 AM   #2086
bitz928
Drives: 2013 FR-S 10 Series
Can someone tell me how the electroluminescent should be working?
I bought the 10-series new from a dealer but came with broken el dash. I took the car to a dealer and its been more than 3week but they still have not figure out to fix it. They ordered second computer or something (can't remember exactly which it was) but it will take a while for it to arrive so they told me to take the car until parts arrive.
Anyways, I noticed the el dash lighting up but only when I turn on the engine. I thought it should light up when door is open/closed and also when on/off switch is toggled?
bitz928 is offline   Reply With Quote
86 Owners of New England - Registry MannyO New England 247 10-27-2025 03:45 PM
**Tennessee Registry** Xryn Southeast 139 11-02-2022 12:31 PM
Mid-Atlantic Owners Registry. IloveBaldEagles Mid-Atlantic 366 10-24-2022 08:55 PM
Issue updating Registry. IloveBaldEagles Site Announcements / Questions / Issues 1 03-18-2013 07:19 PM
First 86 Registry: 2013 Scion FR-S Flipside909 Scion FR-S / Toyota 86 GT86 General Forum 44 05-18-2012 05:54 PM
