Old 05-03-2015, 06:32 PM   #29
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
I have some headlights I can sell you if you haven't bought them yet but from the sounds of it you got them already. Glad everything is up and running again !
Old 05-13-2015, 11:35 PM   #30
eddieflyinv
eddieflyinv's Avatar
Originally Posted by Chaetagnath View Post
Wow, that was a tough one. Thanks for sharing your saga, may help someone in the future. Did they tell you exactly which ground point was broken?
no unfortunately not, but they said it was somewhere near the flasher relay i put in when changing to LEDs
odds are I accidentally nicked it or broke it somehow when i put that in there or when messing around adjusting my clutch pedal :/
eddieflyinv is offline   Reply With Quote
Old 08-04-2015, 11:03 AM   #31
Andew727
Drives: Scion FR-S
this same issue just happened to me. high beam light on dash and no head light or turn signals. everytime i disconnect the battery to reset and actuate the stalk for headlights, i trip something. any new news on this?
Andew727 is offline   Reply With Quote
Old 08-05-2015, 06:59 PM   #32
eddieflyinv
Sorry I failed to get as many details as i woild have liked when i picked my car up. More blown away by the near $800 bill just to fix 1 ground wire, and replace 2 headlights that blew up... I kinda forgot to ask what happened exactly
Sent from my HTC One using Tapatalk
Old 06-03-2019, 01:33 AM   #33
mb_
Ex-MR2 owner
Drives: Scion FRS
Sorry to bump this thread from the dead but I ran across the same issue earlier today.
What's weird is I haven't changed anything electronically in my car for a while now so it I'm suspecting mine is also a wiring/ground issue. Will have it checked out by a technician later this week and report back on what's happening.
Electrical mods I have:
- HID (I have a 2015 FRS which comes with halogen standard)
- Switchback Turn Signals/Front Parking Lights
- LED front and rear Sidemarker bulb
- LED Turn signal bulb
- LED Map light
- LED Trunk Light
- Aftermarket relay for LED bulbs
- Dashcam hardwired in
I tried disconnecting them to no avail. I also tried disconnecting the headlight switch and issue persists when I put the key in accessory/on position
mb_ is offline   Reply With Quote
Old 06-05-2019, 06:20 PM   #34
mb_
Ex-MR2 owner
Drives: Scion FRS
Update... it was the HAZ fuse in the engine bay lol
See this thread:
http://www.ft86club.com/forums/showthread.php?p=2941325
Old 01-03-2020, 02:31 AM   #35
alecbarrondrift
Drives: 15 FR-S
See this thread:
Exact same symptoms here, dash lights and high beam light on, beeping, headlights and tail lights wont come on.
This comment in particular got me home from work safely tonight, i spent two hours in the parking lot scratching my head until i found this. Unplugging everything, checked all the fuses under the dash, and wouldnt have checked under the hood fuse box had i not found this. Seriously, thank you.
alecbarrondrift is offline   Reply With Quote
The Following User Says Thank You to alecbarrondrift For This Useful Post:
mb_ (01-16-2020)
Old 11-06-2020, 01:43 PM   #36
Jrabb100
Drives: 2015 Scion Fr-s
Same problem :/
Sorry to constantly keep reviving this thread, but it seems this problem is pretty constant lol. Did you by chance find an alternative? I have the same exact symptoms, however my HAZ fuse continues to blow every time I replace it and I can not detect a short. Very frustrating 😅
Jrabb100 is offline   Reply With Quote
Hot fuse tap - Which fuse? cgrey Electronics | Audio | NAV | Infotainment 9 09-17-2016 08:24 PM
Fuse box. Chen Northwest 4 01-19-2015 04:51 PM
Best fuse to tap that is hot with car off? Frs32907 Electronics | Audio | NAV | Infotainment 0 08-30-2014 11:11 AM
Fuse Box beagoodruslan Electronics | Audio | NAV | Infotainment 0 04-20-2014 12:31 AM
Does anyone know the secret to Japanese fried rice? jLoBRZ Off-Topic Lounge [WARNING: NO POLITICS] 12 03-27-2014 02:26 AM
