#1555 |
Drives: Scion Frs Turbo
Hello group fellow avo owner.
Stage 2. 10psi on 93. No build thread but I might start 1. Also dynoed at 315hp. |
#1556 |
Drives: 2013 BRZ DGM
What is the size of the rubber oil line that goes between the turbo oil outlet and the oil reservoir? Mine is cracked and leaking
2013 DGM BRZ <-current
2006 WRB STi <-sold 2004 ES1 Civic <-sold |
#1557 | |
Drives: 2014 FRS
#1558 |
Drives: None
I thought anything bypassing 300whp was in the danger zone for 93oct
Sent from my LG-D850 using Tapatalk |
#1559 |
Could be. I just got it finished and it's not a daily driver. Have about 100 miles on the car after the dyno tune. But in that 100 miles the only problems I have had is very high engine bay heat.
#1560 |
Drives: 2013 BRZ limited WRB
How are you monitoring your engine bay heat? How much hotter than stock is it running?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
#1561 |
Drives: 13' AVO Whiteout
Looks like I'll be joining this "club" as of next week.
Is there a Facebook group for you guys? Any tips or suggestions - I'll need to replace the gaskets, I read there's issues one the grimmspeed ones? Having a local shop install and tune on ecutek, will have a spec2+ Clutch going in as well. I'll post pictures after the install Last edited by bryan767; 08-02-2015 at 10:44 PM. |
#1562 | |
Drives: 4-Runner Sport - 13' BRZ SportTech
What's the cost on the Stage 4 turbocharger? Also, will it bolt directly into an existing AVO install
Top Tier Imports - Check out my build journal HERE
#1563 | |
Took about 1" off of the BOV hose and everything seemed to slide into place much better.
#1564 | |
Cost really depends on how far you are going + what you already have. |
#1566 | |
Just got a new long block out of another car. had it up and running that weekend ![]() @AVOturboworld Let's just say turbocharger only. Do you have a cost on that?
#1567 |
Drives: Pearl White '13 ZN6
So I've been going through the forced induction forums for days now trying to decide on which kit will best suit my needs and have almost entirely settled on the AVO stage 1 kit but have some questions/concerns.
1) can this kit be tuned to pass an OBD II NY state inspection? 2) does anyone know of an oil cooler kit or oil cooler radiator combo that fits well alongside this kit without a mounting position that limits my ability to have/use fog lights or an aftermarket bumper (was looking at the robispec oil cooler/radiator but it seems some people have fitment issues with the intercooler?) and will function in a place like NY an environment that sees both 0 and 100 degree weather (i know those are close to the extremes but it happens) 3) does anyone know the boost limitations on the stock N/A engine with a 2.5" exhaust. I'm currently on the TRD D-tip exhaust and would rather keep it (love the tone and the ability to not get exhaust tickets because OEM goodness) 4) would the down pipe and catted front pipe exhaust pieces used effect gains in any dramatic or noticeable way (been looking at the AVO ceramic coated overpipe and catted front pipe vs the motiv overpipe and thats a $300+ difference that can be used for almost anything else) 5) has anyone developed a foolproof method of an exhaust leak free install? 6) a list of sensors/gauges needed to safely run and monitor a boosted set up (oil temp gauge, afm, boost meter, oil pressure, ect?) Any information would be greatly appreciated (whether answered or linked through to the right content). I don't plan on boosting until late spring / early summer but would really like to get all my ducks in a row you know. Last edited by CxG; 08-04-2015 at 04:11 PM. Reason: grammar |
#1568 |
Drives: None
Which injectors would one recommend for 300-350 hp? Preferably something cheap but reliable.. Also which flex fuel is everyone here running? I'm thinking about raising the boost
| Tags |
| avo, avoturboworld |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
