#15 | ||
I Love custom Turbo kits
Drives: Limited BRZ
I agree 1000%
Agreed 1000%
#16 | |
Drives:
I mainly keep track of my coolant temps with my p3 gauge, I guess I have to pay more attention to the oil temps. Perhaps I have reached higher temps but wasn't monitoring the oil temps at the time. projekt zeal86 build Last edited by zeal86; 08-04-2015 at 10:01 AM. |
#17 |
Drives:
Another forum member @spdbydesign created a thread in which he reported the following: (his oil temps with oil cooler were consistent with my reported temps with oil cooler.)
__________________________________________ 88-89F Outside Temperature Clear, Sunny Skies Without the cooler, we saw 104-105 Celsius or 220F after a few 3rd gear highway pulls. Cruising we saw 98 Celsius or 208F. With the oil cooler installed, 88 Celsius or 190F the highest we saw after a few 3rd gear highway pulls. Cruising we saw 84F Celsius or 183F. __________________________________________ Getting curious about all this, I guess I'll have to dive into some more research. projekt zeal86 build |
#18 | |
Drives: 2013 Ultramarine FRS
UPDATE: After doing a whole coolant flush of the system. The car oil, and coolant temps dropped into the same range as zeal86 stated in his post. I did test the new thermostat to make sure it worked. The verdict was it just didn't have enough coolant in the system. A very low amount of coolant for the matter. Thank you everyone for the assistance. |
| The Following User Says Thank You to ChiTownFrs For This Useful Post: | zeal86 (08-04-2015) |
#19 | |
Drives:
I've always learned or understood more through troubleshooting than just reading instructions... some people can get away with just reading how to do something. The scare you got from having a low coolant level just made you more knowledgeable about your 86 or cars in general... that's a positive! Last edited by zeal86; 08-04-2015 at 10:02 AM. |
#20 | |
Drives: FT86
really ? What viscosity oil on 0w20 i would be getting a bit concerned re pressures at 250F plus oil temps http://www.ft86club.com/forums/showthread.php?t=91820 above on unmodded car then on boosted car with oil cooler which drops a bit of pressure [ame="https://www.youtube.com/watch?feature=player_embedded&v=cDfFJ5s6IDg"]FRS - BRZ Oil Pressure and Temperature Tech FA20 - YouTube[/ame] STREET TEMPS 0W20 Redline 0w20 Redline 185F @ 800RPM 10PSI Oil Pressure 0w20 Redline 185F @ 2000RPM 35PSI Oil Pressure 0w20 Redline 185F @ 4000RPM 54PSI Oil Pressure 0w20 Redline 185F @ 7000RPM 65PSI Oil Pressure 10W30 Redline 10w30 Redline 185F @ 800RPM 19PSI Oil Pressure 10w30 Redline 185F @ 2000RPM 51PSI Oil Pressure 10w30 Redline 185F @ 4000RPM 65PSI Oil Pressure 10w30 Redline 185F @ 7000RPM 83PSI Oil Pressure 10W40 Redline 10w40 Redline 185F @ 800RPM 25PSI Oil Pressure 10w40 Redline 185F @ 2000RPM 64PSI Oil Pressure 10w40 Redline 185F @ 4000RPM 78PSI Oil Pressure 10w40 Redline 185F @ 7000RPM 91PSI Oil Pressure TRACK TEMPS AFTER 9 LAPS @ 1 Minute 15 Seconds Per Lap 0W20 Redline 0w20 Redline 225F @ 800RPM 7PSI Oil Pressure 0w20 Redline 225F @ 2000RPM 30PSI Oil Pressure 0w20 Redline 225F @ 4000RPM 48PSI Oil Pressure 0w20 Redline 225F @ 7000RPM 43PSI Oil Pressure 10W30 Redline 10w30 Redline 245F @ 800RPM 7PSI Oil Pressure 10w30 Redline 245F @ 2000RPM 35PSI Oil Pressure 10w30 Redline 245F @ 4000RPM 52PSI Oil Pressure 10w30 Redline 245F @ 7000RPM 46PSI Oil Pressure 10W40 Redline (12 Laps) 10w40 Redline 265F @ 800RPM 8PSI Oil Pressure 10w40 Redline 265F @ 2000RPM 31PSI Oil Pressure 10w40 Redline 265F @ 4000RPM 55PSI Oil Pressure 10w40 Redline 265F @ 7000RPM 45PSI Oil Pressure Last edited by steve99; 08-04-2015 at 08:10 AM. |
| What temperature do you put A/C on? | FRiSson | New England | 23 | 06-13-2016 08:55 AM |
| E85 and oil temperature | jvincent | Engine, Exhaust, Transmission | 11 | 11-12-2014 08:53 PM |
| RPMs rising while at a stand still | kpamir | Engine, Exhaust, Transmission | 13 | 10-29-2014 06:45 PM |
| WTT: XBox One Day One Edition w/ Dead Rising - SoCal | mattbookpro | Miscellaneous | 1 | 07-02-2014 04:22 PM |
| FS: XBox One Games - Forza 5, Dead Rising 3, Titanfall | nlowell | Miscellaneous | 3 | 06-29-2014 03:08 PM |
