Old 08-03-2015, 09:21 PM   #771
sidesleeper
Drives: BRZ series blue
Originally Posted by celek View Post
not my reality, it is simple physics and velocity. You see the same thing in the Honda world with the Acura GSR that has 2 different length runners and a butterfly valve to divert air flow to a shorter runner at a specified RPM for high horsepower.
The longer runners provide more TQ while the shorter runners provide less TQ at higher RPM resulting in more top end.
This is why the Type R has a really short straight runner for more top end but not as much TQ because its designed for road racing and staying in a Power band when it was a Spec car in the late 1990s.
Same can be achieved on the exhaust manifold.
https://www.physicsforums.com/thread...eaders.208674/
Same can be seen here in Lemans cars ITBs.
https://grassrootsmotorsports.com/fo...s/58727/page1/
The Crawford BPB have been proven by numerous 3rd party reputable sources who originally doubted the claims. If you had a different experience you may want to find a different tuner for the VVC maps and Injector timing since they have been moved up slightly.
His "perception" IS REALITY, therefore it is your reality too.
(unless you live in an alternate universe).
Perhaps what you meant to say was "My observations do not match your explanation"
Negative, this is not reality... this is a forum and he skirted around the most important thing I mentioned. He seems to be mired in the fluid dynamics of why it is supposed to work, which isn't the point at all.
You just added more thermal mass to the engine. Bottom line is they heat soak, which effectively decreases knock threshold due to thermal transfer to the intake charge, which in turn will cause the engine to knock and cause the ECU to pull timing, hence making the vehicle slower.
The examples you give are of engines that breathe, the FA20 does not.
I didn't see any reputable empirical data from 3rd party sources.
You can sit here and spin it anyway you want, that's what makes a good snake oil product.
sidesleeper is offline   Reply With Quote
The Following 2 Users Say Thank You to sidesleeper For This Useful Post:
FRSBRZGT86FAN (10-26-2015), Wayno (08-04-2015)
Old 08-03-2015, 11:01 PM   #772
steve99
Drives: FT86
Here is 3rd party testing on BPB.
http://www.ft86club.com/forums/showthread.php?t=62007
skip to summary at end
great on stock cars with good fuels
shift power lower in rpm range
benifits deminish as other mods added and tunes
not much good with E85 as they newter power over 6000 rpm
celek (08-04-2015)
Old 08-04-2015, 12:19 AM   #773
Impureclient
Drives: 2015 FR-S
Concerning the heat soak issue. Why aren't these made from plastic?
Old 08-04-2015, 02:01 AM   #774
steve99
Drives: FT86
Im not an expert on manufacturing costs but I believe its quite expensive to set up moldings ect for doing injection molded plastic parts. So you have to do runs of many thousands.
for small production runs was probably cheaper to get it milled from aluminum.
and it looks the goods and people are happy to pay a few hundred bucks.
People would probably arc up paying that sort of money for a piece of plastic.
Old 08-04-2015, 08:51 AM   #775
celek
Resident Gear Head
celek's Avatar
Yes because a mold for injection can run you $5k-$10k or more
Also because the left and right manifold flanges are not identical resulting in 2 molds.
celek is offline   Reply With Quote
Old 08-04-2015, 08:55 AM   #776
celek
Resident Gear Head
celek's Avatar
Also
http://www.ft86club.com/forums/showthread.php?p=1784979
http://www.ft86club.com/forums/showthread.php?t=62471
http://www.motoiq.com/MagazineArticl...d-Spacers.aspx
The Following 2 Users Say Thank You to celek For This Useful Post:
eddiev116 (09-04-2015), steve99 (08-04-2015)
Old 08-04-2015, 11:55 AM   #777
stugray
Drives: 2013 GBS BRZ Limited
So if you are all setup to machine them out of Aluminum, why not start with a block of plastic instead?
Old 08-04-2015, 12:00 PM   #778
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Machined plastic doesn't hold pressure as well as injection molded plastic, especially as you heat it up. Also I've never found a bit or speed setting that doesn't melt the edges of the plastic, but I haven't tried so hard.
Related note, Injection molds are PRICEY. Making two, you might as well mold a whole new manifold, and the kindly people at Velox have already discovered that's prohibitively expensive.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Old 08-04-2015, 01:41 PM   #779
celek
Resident Gear Head
celek's Avatar
Because the correct plastic to use is more expensive than aluminum and aluminum is more readily available locally
https://www.interstateplastics.com/D...ss=1.000&qty=1
http://www.grainger.com/product/GRAI...Code=P2IDP2PCP
Old 08-04-2015, 06:14 PM   #780
steve99
Drives: FT86
And unfortunatly the velox manifold provided no usefull gains on an NA motor and i suspect the fullblown intake manifold may be same NA, maybe they work FI ?
Old 08-04-2015, 07:02 PM   #781
DJCarbine
Thupercharged
DJCarbine's Avatar
Delrin machines good, never had a problem working it on the lathe/mill
Tends to snipe depending on how aggressive you are, and drilling it with large bits can be a pain
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 08-05-2015, 11:56 AM   #782
celek
Resident Gear Head
celek's Avatar
Because their math was wrong and the inlet was TOO big.
The stock ports in this head for NA purposes flow too much they went with a 54mm Inlet which is 4% larger than needed for stock flow, On top of that they put a velocity stack on an opening too large for a port design that already flows too much for stock.
People have had better results restricting flow in the ports of the head with epoxy which builds up more velocity producing more power.
Really odd reverse porting works better.
Velox Might as well of not put a manifold on to begin with basically same result.
FI it will work because forced air.
Old 08-05-2015, 01:14 PM   #783
Spartarus
...Just add nauseum
Spartarus's Avatar
Never thought of Delrin, I've had good success milling components for watercooled computers out of it, but the melting point is way too low. I wouldn't bolt it straight to intake ports on a cylinder head.
Was talking about the polyamides and others with lower rockwell and higher melting point / deflection temperature. Hard to machine that sh*t.
-Spartarus
Old 08-05-2015, 06:53 PM   #784
steve99
Drives: FT86
Makes sense especially if the same heads valves ect used on the forester and wrx turbo motors was probably optimised for that
celek (08-06-2015)
billet, crawford, magic blocks
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 05:19 PM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 08:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 02:29 PM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
