Old 08-03-2015, 05:03 PM   #57
qqqqball
qqqqball's Avatar
Originally Posted by 8R6 View Post
driver-side airbag?
ehhh correction - I bought the wrong resistors...my B. works perfectly
qqqqball is offline   Reply With Quote
The Following User Says Thank You to qqqqball For This Useful Post:
8R6 (08-03-2015)
Old 08-03-2015, 11:32 PM   #58
TCR
Drives: 2013 Toyota 86 GT
I'm considering purchasing a race seat to install for track days only, as I need to have a seat with functioning air bags for street legality here. If I set the race seat up correctly with mounts fixed to suit my seating position, it should be a pretty straight forward swap, but I don't want to have to keep inserting and removing a resistor from the plug each time I swap.
Does anyone know if you could buy a spare plug to wire a permanent resistor to, so that all I'd have to do was switch plugs so to speak?
Something like this maybe?
http://www.sportseats4u.co.uk/recaro...prod_3950.html
TCR is offline   Reply With Quote
Old 08-04-2015, 02:19 AM   #59
TCR
I guess what I'm after is this plug here:
Old 08-05-2015, 02:34 PM   #60
Jake_86
Jake_86's Avatar
$5 seat belt insert. If you remove all that system yeah I'm sure this one work but for everyone wanting to turn that alarm off. Here. Ebay
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 08-05-2015, 03:24 PM   #61
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
The airbag sensor would still chime, tho. Right?
tigermack is offline   Reply With Quote
Old 08-05-2015, 03:37 PM   #62
Jake_86
Jake_86's Avatar
nope, makes it think that the set belt is on. so theres no Chime at all or anything at all.
Old 08-05-2015, 03:40 PM   #63
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Right on, gonna need that. Thanks!
Old 08-07-2015, 04:11 PM   #64
ft86me
ft86me's Avatar
Drives: 2013 FRS
What is the consensus on taking care of the passenger side ? My drivers side is no problem with a resistor and using the OEM seatbelt. No lights or anything. I will be installing the passenger side soon and have a resistor, but what else is needed or what else do I need to do to keep the airbag light from coming on? Appreciate the help.
ft86me is offline   Reply With Quote
Old 08-09-2015, 10:03 PM   #65
bacon_cheese_beer
bacon_cheese_beer's Avatar
Drives: Fr-S
From what ive read, you need the resistor, the passenger sensor from the oem seat plugged in and tucked, then a seatbelt head attached to prevent any light.
"mr.Balloon hands, no way, get real..."
bacon_cheese_beer is offline   Reply With Quote
The Following User Says Thank You to bacon_cheese_beer For This Useful Post:
ft86me (08-10-2015)
Old 08-10-2015, 07:57 PM   #66
TCR
In regards to this below, I can get a passengers seat with a popped airbag. Would the plugs be the same for drivers and passengers sides, or are they wired differently because of the sensor in the passengers seat?
Old 08-11-2015, 02:26 PM   #67
qqqqball
qqqqball's Avatar
This is correct- however your passenger airbag light will always be on and the passenger seatbelt will always chime. You will need to have someone turn that chime off or you'll rip your ears off
Old 08-11-2015, 06:48 PM   #68
bacon_cheese_beer
Drives: Fr-S
Even with the male end of the seatbelt connected?
Old 08-11-2015, 06:50 PM   #69
ft86me
ft86me's Avatar
Drives: 2013 FRS
It'll stop. If you get an insert
The Following User Says Thank You to ft86me For This Useful Post:
bacon_cheese_beer (08-11-2015)
Old 08-12-2015, 12:40 AM   #70
ft86me
ft86me's Avatar
Drives: 2013 FRS
Can anyone verify the part number for the occupancy sensor ? Should be on the sensor itself. This will keep me from flipping my seat over and all that.
Light Weight Seats sw20kosh Tracking / Autocross / HPDE / Drifting 23 11-06-2012 11:15 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 05:09 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
FR-S / BR-Z Racing Seats!!! vividracing Interior Parts (Incl. Lighting) 8 06-19-2012 08:07 PM
